Question about Dryers
Why doesn't the dial move on my dryer? it dries, but the dial does not advance and the dryer does not shut off.
  • Dryers Master
  • 2,605 Answers
Hi, This could be a timer issue. Does the timer not advance on any cycle, or just the "automatic" cycle. If it won't advance on either the "timed", "air fluff", nor the "auto" cycle, it is the timer. If it does advance on the other cycles and just not the auto, it is very likey a venting problem, i.e. kink in vent, obstruction in blower housing. However I doubt the later based on the claim the close ARE drying. Hope this helps, let me know and leave feedback, that way I know if you got looked after. good luck
Posted on Oct 02, 2009
  • 80 Answers
You will need to replace the timer dial on the dryer.
catriver
  • 878 Answers
SOURCE: kenmore dryer
Jeff, almost sounds like a timer issue, but I was fooled on this once. Under the consol is a inline resistor from the main plug. If this resistor is bad, dryer keeps running in timed dry. Part number for the resistor is 3401076. Look it up on the web so you know what it looks like. Just splices in.. Catriver..post back.
Posted on Sep 14, 2006
docjohn174
  • 943 Answers
SOURCE: DBXR453ET3WW Electric Dryer Won't shut off unless on timed cycle.
hi thanks for the question in the ge dryer theres 2 elements so if one is not working you only get half heat i would check the heater thanks the appliance doc
Posted on Sep 27, 2008
TheMobilian
  • 8220 Answers
SOURCE: Dryer Timer dial will not move but dryer works
Will the dryer move forward in timed dry? if it does not then you need a new timer. If if will advance in timed dry but does not advance in auto mode then the high limit needs to be replaced on the heater.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Apr 10, 2009
  • 2699 Answers
SOURCE: Amana Gas CLothes Dryer Mod#NDG7800AWW dryer will
if your clothes are damp because you say it does dry some what then it sounds like it could be the gas coils,the coils will work for awhile but then they fail and the timer will not move if there is no heat on the more or less
Posted on Oct 30, 2009
  • 77 Answers
SOURCE: It takes hours to dry the clothes. The dial moves
sounds like a bad timer. if it sticks every time replace they are expensive
Posted on Mar 25, 2010
Gas dryer dries sporadically. dial for automatic dry doesn't move
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ...Replaced outlet, cord, and moved the outlet so we don't have the same ... Whirlpool LER4634EQ0 110 v timer motor, when timer contacts TM .... David Villa 7 months ago ... 3 years and now thedryer won't heat and the timer doesn't advance, ...Missing: cu
Nov 17, 2015 | Whirlpool Dryer. Gas Dryer. 7.0 cu. ft. in...
Set dial in automatic dry option onmore dry. When start dryer comes on but dial never moves and there is barely any heat. Dryer only shuts off manually or when open dryer door.
if there is no heat, there is no drying and the dryer will not shut off until the clothes are dry. Sounds like you have an electrical problem, bad heater or thermostat. we do not have sufficient information to help you, you will need specific tool to determine the problem and for performing the repairs.
Jul 29, 2015 | Dryers
The dryer is not heating up and the dial stops at the cool down so the dryer will not shut off by it self. Its a kenmore 70 series dryer.
you need to send the model number,open the door and look around the opening where you put the clothes into the dryer and you'll see the tag with the model number.it will start with 110. or 417.because you have no heat that's why the timer won't advance,when the heat shuts down then the timer advances when the heat comes back on the timer stops moving or advancing,no heat the timer won't move.send the model number
Jan 16, 2011 | Kenmore Dryers
Apr 10, 2009 | Roper REX4634KQ Electric Dryer
MAYTAG SDE3606AZW ELECTRIC DRYER
Does the dryer dry fine? If your dryer is taking too long too dry you might have a venting obstruction that is not allowing the dryer too sense that the clothes are dry so the timer won't advance. Try disconnecting the vent from the back of the dryer and dry a load unvented and see if the timer advances.
Jun 11, 2008 | Maytag SDE3606A Electric Dryer
Kenmore dryer
Sep 14, 2006 | Kenmore 62602 Electric Dryer
Dryers Logo
281 people viewed this question
Top Dryers Experts
