Question about Metrologic Instruments MS7120 ORBIT Barcode Scanner
Ring bell when power up. no sign of light in scanner
Seems inner motor spins but gives up with in few second and green + red light on top blinks.
any suggestion?
My Sony kf-50e200a blinks red 5 times after 30 seconds of the green light blinking plus the fan is spinning then can hear it stop please help
Power supply board seems to be the problem, but there are many components and is better to change with a new one.
Sep 11, 2017 | Sony Televison & Video
Why does my Mitsubishi XD221U projector have a power light blinking red and green?
Reset the lamp timer by holding power and menu button down for 25 secnnds
If you need further help, reach me via phone at https://www.6ya.com/expert/gary_693301a25d57d47d
Sep 03, 2014 | Mitsubishi XD221U New
Beeps red light hp pc
The blinking should be in a pattern.
Power Green On (S0) Computer on
Power Green 1 blink every 2 seconds (S1) Suspend Mode
Power Green 1 blink every 2 seconds (S3) Suspend to RAM
Power Green Off (S4) Suspend to Disk (if applicable)
Power Clear Off (S5) Computer off
Power Red 1 blink followed by 2-second
pause - Repeat
Power Supply failure
Power Red* 2 blinks 1 second apart CPU thermal shutdown
Power Red* 3 blinks 1 second apart CPU not installed
Power Red* 4 blinks 1 second apart Power supply overload (crow bar)
Power Red* 5 blinks 1 second apart No memory
Power Red* 6 blinks 1 second apart No graphics
Power Red* 7 blinks 1 second apart System board failure (detected prior to video)
Power Red* 8 blinks 1 second apart Invalid ROM
Hard Drive Green Blinking Hard drive activity
*Blinking
Aug 17, 2013 | HP Computers & Internet
Belling 665 halogen ring faulty
You would need to study a circuit diagram for the stove to figure out where the fault is probably to be found and how it works or alternatively take it apart and follow the wires making notes as you go.
It is true, obsolescence and unreliability and a shorter lifespan is often built in to appliances and other things. Part of the reason is sensible designs using quality parts and engineering are too expensive and so good designs are production engineered (corners are cut) to save money, usually introducing problems and unwelcome "compromises". Often sophisticating the design using cheaper methods are used to overcome problems caused by production engineering.
One of the big problems with stuff designed to have a shorter life is the replacement parts needed to make them last a bit longer are usually priced not to sell.
Apr 05, 2017 | Kitchen Ranges
The red light is blinking and when i turn it on it goes to green for a few seconds and then beeps and blinks red again.
You have "The red ring of death" If 1 corner is blinking: Turn it of and wait a few days for it to cool off. If 2 corners are blinking: Do the same, but check after 3-5 days to see if it works. If 3 corners are blinking: You HAVE to see a xbox repairer, because you can't wait after 3 rings. Saddly, a complete ring of red: You can't do anything about it, it can't be repaired, but check the power wire and reattach it, there's a little glitch where if you loosen the wire, it does that. Good luck!
Sep 04, 2011 | Sony Playstation 3 (PS3) Console
Scanner stopped in middle of scan . green light in front went out. later red light came on. message on screen said that the carriage was locked. I tried turning scanner on and off and green light comes on...
test the power supply to the scanner also test the leads that attach from the power supply to the scanner if its connected to a computer you might have to uninstall it then reinstall it this applies the driver aswell you can do this control panel admistrive tools,computer management,device manager scroll down you should see a yellow question mark? right click to reinstall drivers or ports(com&lpt)ECP printer port right click update driver
hope this helps
Oct 27, 2010 | Computers & Internet
Powers on for only a few seconds
if the power light blinks and the status light is off, check the lamp door. if the power light blinks and the status light is steady red or blinking green, you have a power supply/ballast issue. you may have to send it in for repair. try www.avsolutionsny.com.
Dec 09, 2009 | Mitsubishi XL8U Multimedia Projector
Sony kdf50e 2000- green power light turns red what to do
Does red light blink? if yes, please count blinks as there would be pause of 3 seconds between blinks and let me know to help you out.
Feb 12, 2009 | Sony Grand WEGA KF42WE610 42" Rear...
Error 5
I can't seem to find a error code 5. What software are you using to scan? Did the error start right after your first? Had the scanner been working?
Jul 12, 2007 | Kodak i40 Path-Through Scanner
SCANER BEEPING
hello,
I have a same issue with my MS-7120, how ever mine is in worse stage, when i power up, it beeps and u can see green/red light blinks on top, and it tries to spin the inner motor + tries to turn inner light on, but after several seconds it goes dead. how ever red/green light blinks on top.
i contact the company which i purchased from, he told me these scanner has life expectation of approx 3 years, after 3 yrs they die.
i was told cause is from heavy/light voltage transfer from outlet.
and they have to be repaired by orbit support.
i am afraid to tell your, sounds like urs is ready to die. just beware !!
i hope this information helps you.
Jun 23, 2007 | Metrologic Instruments MS7120 ORBIT...
Metrologic Instruments MS7120 ORBIT Barcode Scanner Logo
163 people viewed this question
Top Metrologic Instruments Computers & Internet Experts
xak_tay98
Level 1 Expert
Daniel Dollive
Daniel Dollive
jackcity
jackcity
Level 1 Expert
Are you a Metrologic Instruments Computer and Internet Expert? Answer questions, earn points and help others
