Question about Philips Magnavox 51MP392H Rear Projection Television
How do I repair my television. It is a rear
How do I repair my television. It is a rear projection one and it has a concave effect happening and the color is slightly off.
    President:
  • 1,922 Answers
Sounds like your horiz output transformer is shorting out
Posted on Oct 02, 2009
All of a sudden my 6 yr old samsung HCN653W has a
your cable box is effecting the component line in 1 or 2 in the back of the tv
Jul 12, 2010 | Samsung HCN653W 65" Rear Projection...
I have a Mitsubishi 55 inch rear projection tv, ws55819 on which the convergance is gone bad. I'm getting a concave picture with multiple colors and black lines with a blurred picture. this happens mutiple...
Your reference to concave picture suggests a high voltage problem and not convergence. If the raster can't scan from left to right , top to bottom, your having High voltage trouble. if your colors are not dropping on top of each other that is convergence. I would suggest it may be time to consider a purchase of the new HD set for the cost of this repair. good luck
Jul 03, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Picture on projection screen is concave in the middle
This set does not use IC's for convergence. Most other brands do use IC's.They use individual transistors in this one and honestly I don't remember ever seeing these go bad. Normally it is the power supply that runs the convergence transistors or more commonly known as the convergence board. It gets pretty technical with this type of problem. Have a repair shop check it out for you and avoid the headache. Thanks
Jun 07, 2009 | RCA P61939 61" Rear Projection Television
RCA P61960 Picture is concaved
this is the conversion chip or sometimes chips that cause these effects the chip or chips are about $30 each but labor is alot more $250 -$300
Oct 18, 2008 | RCA P61960 61" Rear Projection Television
Concave comvergence problem i believe
Unless you can solder and use a meter then yes you need to call a tech, this repair should run somewhere from $300-$500. Let me know if you need more info
Tim
Sep 09, 2008 | Sony KP-51WS510 51" Rear Projection...
Right and left side of TV concaved
CALL THE REPAIR PERSON THE ISSUE IS INTERNAL RELATED
Aug 11, 2008 | Akai PT5492S 54" Rear Projection...
Picture problem
Convergence circuit repair = replace STK392-570 IC's....
Located on center circuit board on heat sinks................T.
Please rate this solution............
Nov 07, 2007 | Mitsubishi WT-46809 46" Rear Projection...
Rear projection set
Convergence circuit repair = replace STK392-570 IC's........
Located on center circuit board on large heat sinks........T.
Please rate this solution...................
Concave picture with rainbow effect at the edges
Hello, Check and replace IC1606 (P/N: 875292571) and IC1608 (P/N: 875982987). Best regards, Arpi http://www.partstore.com/sl/2/418644-ic-cxp86448635q-875292571.html
Apr 23, 2007 | Sony KP-57HW40 57" Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
85 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
