Question about Whirlpool Washing Machines
Machine makes a clicking noise during agitation
    Problem Solver:
  • 6 Answers
Most likely broken suspension bands allowing the drum to move freely within the housing.
Use a putty knife or something similar and on the front of the machine you will see a slight gap between the top of the machine and the face of the machine. If you look into the gap you may be able to see two clips there that hold the fron of the machine in place.
Use the putty knife to disengage these clips. it may take a few tries. once its loose swing the face out and off.
Looking into the housing, you will see the drum. near the top, in front yo u will see two black rubber straps, which will most likely be broken.
there are two more in the back in a similar position.
remove the screws that hold the ends of them in place you will need a 5-16 in nut driver.
make sure you unplug the machine there is some nasty voltage in there.
You need to replace these straps.
If you take them to a reputable appliance parts dealer they will be able to sell you a replacement for about 3-4$ a piece.
Reinstall the same way you took them out.
Without seeing the inside of the machine I cant offer any other suggestions. This is the most common issue with this machine.
Posted on Oct 02, 2009
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Washing machine making banging noise intermittently during agitating
your loads are unbalanced during the time that it is making that noise, when it starts you may wish to make sure that the clothes are all evenly distributed in the drum so that all the weight isn't on one side. when the clothes all bunch up in one spot it throws the balance off of the drum just like a car tire that's lost a weight makes the wheel bounce, same principal
Dec 30, 2014 | Washing Machines
Know when clutch going bad
Needs agitator dogs in agitator.
Mar 13, 2014 | Whirlpool Washing Machines
Loud clunking noise during wash cycle
Hi What machine is this? and is there play on the stainless steel inner drum?
Mar 11, 2013 | Washing Machines
Washing machine knocks and dims lights only during rinse cycle
Possible that the bearings are a suspect, if the machine seems to wobble around. Also if the load is high, does the noise go higher, if so check the suspension, check the mounting and the counter weights.
Please check this link: Wobbling machine
Jan 24, 2013 | Washing Machines
Very annoying squeaking / creaking during agitation
sounds like trnsmission and brake assembly they are not cheap. you can see one at www.repairclinic.com scroll down to the red(100) click it and look for part number 279566.
Apr 06, 2009 | GE WHSE5240D ENERGY STAR Super Plus 3.2...
Load squeal when it in the agitation cycle.
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
for detailed help with diagrams and step by step instructions click the link http://www.applianceaid.com/washerspinnoise.html
Dec 29, 2008 | Admiral AW22 Top Load Washer
Washer make a clicking noise
Zoobs, you could have something stuck under the agitator. The agitator will pull straight off. Grip it on each side and pull up hard, but don't hit yourself in the face. If that don't work, try slipping a belt under it and pull. Check for something caught under it. Another possibility could be the nylon suspension rod socket supports in the back. They will make a noise during agitation if they are dry. Put a little 3 in 1 oil to quite them down. Take the front panel off and check the pulley and belt, see if anything is out of whack. I also often find the motor support hitting the bottom panel during agitation making noise. Take the front panel off and observe during agitation. See if the support is striking the bottom. If so, just bend the bottom panel down. Catriver..post back.
Nov 30, 2006 | GE WHSE5240D ENERGY STAR Super Plus 3.2...
Washing Machines Logo
Dan Webster
Dan Webster
Sal DeAngelo
