Question about Frigidaire GLEH1642DS Front Load Stacked Washer/Dryer
Electrolux Gleh1642ds1 buzzer Problem How do you shut off the buzzer on the washer and dryer? It is very loud.
SOURCE: Frigidaire GLEH1642DS1
Check the thermal fuse, a small disc with two wires on it located at the top of the heater housing at the rear of the machine. If it's blown definitely check your vent system for restrictions
Posted on Dec 26, 2007
jumptrout51
  • 3361 Answers
SOURCE: Dryer buzzer is SO LOUD - How can I adjust volume/turn off?
Open the control panel and unplug it.
Posted on Mar 01, 2009
SOURCE: Trying to disable the dryer's loud buzzer
The wiring diagram is located in the slanted panel above the washer door
Posted on Sep 09, 2009
ElectricKris
  • 3 Answers
SOURCE: i would like to shut off buzzer in dryer
If you are trying to shut off the buzzer because it sounds constantly, there is a problem with the dryer timer motor, and that is an entirely different problem.
However, if you are like me and find it really annoying and loud - and are trying to disable/remove it this is how to do so:
Tools: #2 Phillips head, 8-10" long
#2 Phillips head, 3" long
Optional but recommended: Vacuum cleaner with flex hose. (Unless your dryer is new or you maintain regularly, it is full of lint that is a potential fire hazard - this is a great opportunity to clean it out)
Optional but recommended: Duct tape, the metallic sealing kind, not the elastic adhesive tape
Steps:
1. REMOVE THE POWER PLUG FROM THE WALL. TURN THE DRYER CONTROL TO TIMED DRY AND TURN THE START KNOB TO ENSURE THE POWER IS OFF (IF THE DRYER STARTS, YOU PULLED THE WRONG PLUG - TRY AGAIN)
Note 1: As you start removing panels, it would be a good idea to clean as you go, otherwise you will have a big dusty mess...
Note 2: As you remove the panels either screw the screws back in to where to took them out of, or screw them into the holes of the panels you are removing, they can get mixed up or forgotten easily...
2. Remove the 2 screws that hold the cover from the underside of the dryer tumbler (above the lid for the washing machine)
3. Remove the 7 screws for the tin sheet that covers the blower/tumbler motor
4. Remove the 2 screws for the front control panel with all the knobs for the washer/dryer
5. The panel can be lowered out slots on each end by applying some pressure inwards, then down. Mine was a little more difficult to remove because of all the lint/**** built up so I used a screw driver for a little prying action. If you try this, pry on a side the that is not exposed in case you cause any dents, scratches, etc... for aesthetic reasons.
6. Once you have the panel down, vacuum this area very well, there are exposed contacts and terminals here that will be a source of ignition if a contactor goes bad and there is a lot of lint build up.
7. On the left side where the dryer controls are, there is is a little black rentangular box with two wires going into it - mine was between the dryer cycle knob and the start knob. It is the only component on the backside of the panel that will not have a corresponding knob on the front of the panel. Remove the screw that is holding it in place, and pull it up at an angle to clear a metal clip that holds it in on the side opposite the screw.
8. Once you have the buzzer free, follow each wire from the buzzer to its termination point on the dryer cycle controller. The buzzer should have black a wire going to the "common terminals" labeled either B or C, the other black wire is for the switch terminal of the dryer cycle controller. There should be "female" connectors on the wires from the buzzer, connected to the "male" terminals of the dryer cycle controller.
9. Remove these female connectors, which will disconnect the buzzer from the dryer. Be sure that you do not accidentally pull off an incorrect wire - and if you do, make sure to reconnect it before removing any other wires to avoid confusion as to what goes where.
At this point, get a flash light and take a look around the inner dryer housing. With your vacuum - if you have a brush attachment, use it - clean out all the built up lint from everything you can reach, especially around electrical connections, wires, the dryer motor windings, etc... Take your time, do it right - you spent the time taking the thing apart, it will not kill you (and actually may save your life) to spend 15 minutes cleaning the inside of your dryer.
If you have some duct tape, tape the blower exhaust connections from the plastic blower housing to the metallic duct and the flexible duct. I also taped the plastic piece that the lint screen inside the dryer door sits in because the foam rubber stripping had come apart. There areas are the main places that lint escapes into the inner parts of your dryer.
10. When you are done cleaning, reassemble the dryer in the reverse order you took it apart in.
11. Once reassembled, plug the unit back into the wall.
12. Turn the dryer control knob to as close to the end of a cycle as you can, turn the start knob to start the dryer. If the dryer starts, then stops at the end of the cycle without a buzzer - you were successful.
Posted on Mar 06, 2010
  • 4 Answers
SOURCE: I have a 27 inch
pull the control panel off and behind there will be a black box with 2 wires disconect them and tape them up . also the box does not come through the front
Posted on Oct 25, 2010
The buzzer does not sound at the end of a drying cycle. I've replaced the buzzer but the problem of no buzzing still remains. How is this remedied?
About 21,300 results (0.60 seconds) Search Results
    Dryer Buzzer Replacement - Whirlpool/Kenmore Electric ...
    ? 1:11
    https://www.youtube.com/watch?v=vsLyHfJLfqk
    Jul 15, 2010 - Uploaded by RepairClinic.com
    Dryer Buzzer Replacement - Whirlpool/Kenmore Electric DryerRepair ... Additional dryer repair, troubleshooting tips, help with finding your ...
    Questions and Answers for Whirlpool 694419 Adjustable ...
    www.appliancepartspros.com/questions-for-whirlpool-adjustable-buzzer-...
    Customer Questions and Answers for Adjustable Buzzer Kit by Whirlpool ... At theend of the dryer cycle the buzzer sounds but does not time out and shut off.
    Whirlpool 694419 Adjustable Buzzer Kit ...
    www.appliancepartspros.com > ... > Washer > Whirlpool Washer Parts
    $27.64
    Adjustable buzzer kit 694419 / AP3019850 made by Whirlpool. ... At the end of thedryer cycle the buzzer sounds but does not time out and shut off.
    Whirlpool® Duet® 7.3 cu. ft. Front Load Electric Dryer with ...
    www.whirlpool.com/-.../WED80HEBW/
    Whirlpool Home Appliances
Feb 08, 2016 | Whirlpool Dryers
Why won't the buzzer alarm go off at the end of a drying cycle
Search Results
    Why does my Kenmore dryer model 417.94802/94862 end ...
    www.shopyourway.com > Manage My Life > Questions
    Why does my Kenmore dryer model 417.94802/94862 end of cycle alarm go off ...washer/dryer unit I do see that it is normal for the end of cycle buzzer to go off ...Why won't my Kenmore dryer model 110.86872100 shut off at the end of the ...
    Why won't the buzzer shut off on my Kenmore 80 Series ...
    The buzzer won't stop buzzing after the load is complete. ... or turn on the timer and the dryer will start just by selecting a cycle and closing the door. ... The dryer should continue to run and at the end the buzzer should only stay on as long as ...
    FIXED The Buzzer At The End Of The Dryer Cycle Comes On But Won't ...
    www.applianceblog.com/.../21739-The-Buzzer-At-The-End-Of-The-Dry...
    Dec 11, 2010 - 10 posts - ‎2 authors
    My maytag dryer has operated wonderfully until today. All of a sudden the buzzer that goes on at the end of the drying will go on but will not shut off unless I open the door.... To test it: by-pass the push-to-start switch and see if when you turn the timer on and close the door, the ... VERY annoying dryer End of Cycle Signal
    Jun 29, 2012
    Maytag DE8410 electric dryer - End of cycle buzzer stuck ...
    Mar 27, 2011
    Kenmore 80 series, buzzer won't shut off
    Sep 10, 2005
    More results from www.applianceblog.com
Buzz when clothes are done drying is too LOUD!
The buzzer on your model is not adjustable.
Dec 19, 2011 | Amana Dryers
Kenmore stackable washer dryer. Dryer buzzer is
Just solved this problem for a Kenmore stackable washer dyer! Sorry I don't have the model number. I have a baby on the way and a small house. I was pretty sure I would get no sleep between the baby crying and the baby crying because of that darn buzzer!
The buzzer is attached to the timer with a quick connect post. Access the controls by unscrewing the large panel above the washer door. You will need a square screwdriver or a very small flathead and some vice grips to get it started. The panel will fall forward onto the washer. In mine there was a pouch with an electrical diagram of the unit. To release the controls, two more screws must be removed from the sides of the small panel housing the controls. Once again you need a square screwdriver or a very small flathead and some vice grips to get it started. Once these are out you should be able to lift the control panel up and it will fall forward. Get a small box or stand to put on the washer. This will support the panel as the wires are not that long. On the left side of the timer controls you will see a quick connect post marked with an "H". Disconnect this wire and your problems are solved. Beautiful silence! I put electrical tape on the quick connect wire. Not sure if I needed to as I'm not an electrician. Hope this helps.
Apr 09, 2009 | Dryers
Turn off buzzers
I had the same problem and the buzzer was one of the worst sounds ive heard. But, I found the buzzer and turned it off for good. Open the front panel and look for a small part in between the 2 main curcuit boxes.I have a Fridgidare stackable combo FLEB8200FSO. On mine this small part is number 144547100. Look for two black wires, one goes to H and the other to C. Disconnect both wires and no more buzzer!! Good Luck
Mar 29, 2009 | Frigidaire GLEH1642DS Front Load Stacked...
Buzzer mounted to back of control panel.
**UNPLUG POWER BEFORE REMOVING CONTROL PANEL OR TOUCHING -ANYTHING-!**
Located on left side of control panel, bolted to back. Small rectangular device with two connections and no associated button or dial.
Remove the panel and disconnect one of the leads. Fold the connector back against its wire, carefully and securely tape the connector with electrical tape so it cannot touch anything. Also tape the connector on the buzzer that you removed the wire from.
Re-assemble the control panel.
As with anything mechanical, hours of frustration trying to take something apart can be avoided by taking a few minutes at the beginning to look closely at how it is assembled.
Mar 01, 2009 | Frigidaire GLET1031 Top Load Stacked...
Kenmore Oasis
THE ONLY OTHER WAY TO TURN OFF THE BUZZER IS TO REMOVE IT UNFORTANETLY.OR COVER THE BUZZER WITH A PIECE OF CLOTH TO DAMPEN THE SOUND.GOODLUCK. MOHAMED
Sep 18, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Check the door switch on the dryer to make sure the leads are all on.Check your thermal fuse .Its likely that its one or the other.
May 20, 2008 | Frigidaire GLEH1642DS Front Load Stacked...
Loud buzzer Model FEX83...
SIMPLE! behind the dash board are screws simply take screws out ane the buzzer shouid be hooked to the timer. there are two ways to do it either cut the wire if you plan never to use the buzzer again or if you want to just unplug it!
Jan 20, 2008 | Frigidaire FEX831CS Top Load Stacked...
Dec 26, 2007 | Frigidaire GLEH1642DS Front Load Stacked...
Frigidaire GLEH1642DS Front Load Stacked Washer/Dryer Logo
180 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
