Question about HP Photosmart R727 Digital Camera
HP R727 stays on 2 seconds then flashes contact HP
I've tried resetting it, removing the battery & MEM card. It does the same
flashing HP, after 2 secs., whether on Battery, or not.
Try holding in the reset button longer then the recommended 6 seconds.
I've fixed many of these Photosmart series this way.
Dagra
Posted on Dec 23, 2007
How do you reset an HP R727 camera?It comes up saying it has experienced an error 5555AAAA-61EE-14B-031 as soon as you switch it in. Battery is fully charged.
Normaly the repair service reset camera by using special file on the SD card.This file is impossible to find it on the internet.But you can try to update FW maybe it will help to this error message.You can try download lates FW for R727 from google.(Last FW version is 3.02.15).
Then extract exe file and copy FW file to the SD card.Put SD card into the camera and close battery door.Hold Shutter button and power on camera.After FW update is complete just power off camera.Then try it again to swith on.If it will not help the only way is send camera into the repair service.
Best Regards
AIOS
Apr 17, 2010 | HP Photosmart R727 Digital Camera
00000018-4489-957-000
The erorr code 00000018-4489-957-000 which you can see on the LCD is problem connected to the lens block.You can try download lates FW for R727 from google.(Last FW version is 3.02.15).
Then extract exe file and copy FW file to the SD card.Put SD card into the camera and close battery door.Hold Shutter button and power on camera.After FW update is complete just power off camera.If the problem still stay you can try to remove covers and disconnect and connect again Flexi Print Cables(connection between Lens and main board).Then you can try again FW update.If this solutions will not help you will need to send camera for repair to the repair shop.As your camera will be probably out of warranty repair will not be economical and maybe will be better to buy new camera.
Best Regards
AIOS
Apr 13, 2010 | HP Photosmart R727 Digital Camera
Photosmart R727.Camera has experienced an error 000000018-4489-957-000 please reset your camera I don't know how to reset the camera. help!
Two ways: 1. Go into the menu and find "reset"...follow the on-screen instructions. 2..Remove the card and battery...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on.
Jan 30, 2010 | HP Photosmart R727 Digital Camera
How reset this camera
Dec 02, 2009 | HP Photosmart R727 Digital Camera
HP Pavillion dv6700 - black screen
Do the following without the battery inserted.
Let the computer sit with no battery for 24 hours. Do not put the battery in at all. Try using your original memory stick ONLY, with no hard drive and see if it will POST. If it does, insert the hard drive and try again. Could be the new memory...
Another thing you can try is reseating the processor. Turn the ZIF screw, take the processor out (WATCH THE PINS!!) and put back in GENTLY. Leave the memory in the computer, hard drive removed, try to power on.
These models have been known for bad motherboards. Contact HP and arrange to send it in. If you do enough digging on HPs website, you'll find the service advisory.
-Dell & HP Certified Technician
Oct 29, 2009 | HP Pavilion DV6700T Notebook PC
Hp photosmart R727 reset problem
The reset button is located next to the battery release tap. Here is a picture (sorry for the lousy quality, it was taken with a ten dollar web cam.)4f16c6c.jpg
Mar 28, 2009 | HP Photosmart R727 Digital Camera
Hi, thanks for responding
Please remove your battery and polish the terminals with a dry cloth and make sure the terminals are clean. If the terminals are covered with oil from your skin or similar matter, this may cause poor contact and power may not be fully supplied to the camera.
Also, polish the battery charger terminals with a dry cloth before charging the battery. If the terminals are covered with oil from your skin or similar matter, this may cause poor contact and the battery may not be fully charged.
Next please remove your memory card and format in your pc using card reader and then use it on your cam.If you have another mem card then use it in your cam and see if you face the same problem.
Also try removing your mem card and battery from your camera and allow it to reset for 20min,then just insert the battery without the mem card and see if you face the same problem.
If you need any more help let me know..
Please don''t forget to rate or accept the solution no. 2 in the premium problem.
Jul 27, 2008 | Cameras
Reset
In order to reset, open the battery compartment on the bottom of the camera, take out both the battery, and the memory card. There is a small pinhole, this is the reset button. Use a small paperclip or a needle to push down the button for 3-6 seconds. Your camera should now be reset! Replace your battery and memory card and try to power it on.
Jul 01, 2008 | HP Photosmart R727 Digital Camera
Battery Won't Charge
Hey Guest9,
You can try resetting the camera by removing the memory card and the battery, pushing a straightened paperclip into the reset switch inside the battery compartment, and reinstalling the battery. If this works put the memory card back in. Another option you have is to try formatting the memory card.
Sincerely,
Allan
Go Ahead. Use Us.
Apr 16, 2008 | HP Photosmart R727 Digital Camera
Lens stays in and camera will not power up.
hello, first of all try one thing, remove the memory card from camera and try to turn the camera on with fresh battery. if problem still remain try with another memory card. if your problem not fixed reset the camera. still not fixed run to olympus shop. good luck....
Jul 28, 2006 | Olympus D-460 Zoom Digital Camera
HP Photosmart R727 Digital Camera Logo
110 people viewed this question
Top HP Cameras Experts
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
