Question about Samsung RS2630SH Side by Side Refrigerator
Very hot between side side doors.
My Samsung RS2630WW refrigerator stays very hot between the side by side doors. I am very concerned because I think it is causing my electric bill to be very expensive. Why is it staying so hot and what can I do. Please help me.
  • lwalcott3020 Oct 02, 2009
    Thanks. I understand this is for keeping the frost from forming. But this is very hot to the touch. It just started getting this hot the last few months. I will check my fan on the condenser. I read that this might not be working which is causing this to be too hot.
    Sergeant:
    Champion:
  • 255 Answers
This unit is working just fine, do not be concerned.
it is part of the condenser side, of the refrigerant cycle, keeping frost from forming around the door seal.
Posted on Oct 02, 2009
Testimonial: " Thank you for the help. It's always nice to get advice from someone."
The outside center and out side corners are very hot. Everything else is working fine
Hot refrigerator I have a Samsung refrigerator RS2630SH ...
www.fixya.com/support/t322304-hot_refrigerator
Also the freezer side outside wall is very hot to touch. Ice maker does not work as well. Any suggestions appreciated, excluding the one "not to buy Samsung ...
Samsung RS2630WW Side by Side Refrigerator Divider hot ...
www.fixya.com > ... > Samsung RS2630WW Side by Side Refrigerator
Samsung RS2630WW Side by Side Refrigerator, divider hot related issues. ...Compressor/motor on mu Whirlpool frige is really hot. face of fridge/freezer ... centerdivider is hot to the touch, it means that the compressor is running hot. either your ...means there is inadequate air flow over the condenser coils outside the unit.
[PDF]SAM0059 Samsung Side-by-Side Refrigerator.pdf
applianceassistant.com/.../sam0059_samsung_side-by-side_refrigerator.p...
A newly developed SAMSUNG side by side refrigerator in 2004 has the .... Warranty service can only be performed by a SAMSUNG authorized service center. .... SUB-CONDENSER. Hot Pipe. Hot Pipe. Compressor. SIDE CLUSTER PIPE .... corner of the refrigerator. ... The CoolSelect ZoneTM thermistor is located outside.
Jan 25, 2016 | Samsung RS2556 Side by Side Refrigerator
How can I turn the door alarm off in my samsung fridge?
the alarm indicate that the door is open
check the door switch and check if the door press the switch or not
I think the door latch didn't reach the switch
Jun 07, 2014 | Samsung RS2630WW Side by Side Refrigerator
Samsung rs2630Ww. internal refrig fan blower not working and water dispenser not working.
This problem could be caused by the motherboard having defective relays, bad fan motor=> DA31-00103A Fan Motor Sounds like someone will need to examine the fan motor and test the voltage to the fans inside and outside the refrigerator. You will need to have this done to eliminate what the cause is. Both condensor and evaporator fan motors are the same part=> DA31-00103A Fan Motor Let me know and I will explain how to remove, test or replace the freezer/evaporator fan motor, wiring or motherboart. Thanks Sea Breeze
9_16_2012_3_30_31_pm.jpgDA31-00103A
Sep 14, 2012 | Samsung RS2630WW Side by Side Refrigerator
Pull back cover and check condenser motor. Big issue with fans locking up. Be careful they will burn you
Sep 12, 2012 | Samsung Refrigerators
We have recently noticed that the part of the refrigerator that separates the freezer from the refrigerator is very hot to the touch on the Samsung RS2630WW Side by Side Refrigerator. It also seems hot on...
This is a sure sign of pending compressor failure (high heat and head pressure, Since that 2 inch section comes directly from the compressor.For verification,
Remove the back cover, and place your hand on the compressor.(careful,may be hot) should be able to leave your hand on compressor without burning.
Check condensor fan in that same area , It may be not running
causing all the trouble
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Sep 09, 2010 | Samsung RS2630WW Side by Side Refrigerator
I have a Samsung RS2630WW Side by Side refrigerator. The center column dividing the freezer from the refrigerator is very hot to the touch. The freezer and refrigerator are working fine. Is this a...
Hi, Welcome to FixYa.
I`ll start by letting you know first the heat between the doors is normal...to a degree, and done by design to help prevent moisture along the "breaker strip"/divider.
If all else appears fine, temp. Ok, fans running, no significant frost build up on freezer back wall, it's likely nothing to be concerned about.
**Just be sure the condensor fan isn't jammed and still turning.** The fan at the back next to the compressor.
The amount of heat can be determined by several factor's such as,
1) temperature setting - lower ( colder ) the temperature is set the more the run time the hotter the strip.
2) The ambient temperature - hotter the environment the more the unit runs to compensate, hence the hotter the strip.
3) The amount of "fresh" content added to the unit ( especially freezer section if unfrozen items added ) - new items add a lot of warmth thus demanding the unit to run more to remove this heat (btu`s or british thermal unit`s )causing the strip to be hotter.
4) Build up of dust & dirt on the condensor coils - this also causes the unit to run excessively which in turn makes for more heat on this strip.
These are all things which can and do determine the amount of heat between the doors.
Another factor to always consider is of course If it is hot where you live the unit may just be running more to compensate as with other factors I mentioned.
Hope this answer's your question and let me know if I can assist you further. Thank's for coming to "fixya" and good luck moving forward.
Please take a second to rate the info provided here.
macmarkus :)
Aug 13, 2010 | Samsung RS2630WW Side by Side Refrigerator
Motor is making a loud noise
if you can get to the sticky paper that hides the bairings, drop some oil in the hole and seal it back up, problem fixed for another year.
teflon oil is better.
Aug 09, 2009 | Samsung RS2630WW Side by Side Refrigerator
Freezer making a loud noise.
Sounds as if the evaporator fan has shaft play or the blades are out of balance or striking something. When you open the door the pressure is equal but with the door closed the fan needs to push the air through the evaporator and return again and circle through fan again. I think soon would be a good time to unplug the refrigerator and remove the back panel covering the evaporator and fan motor to inspect the fan, shaft play and the evaporator for frost buildup or any obstruction of air flow. Thanks, sea Breeze
Jun 17, 2009 | Samsung RS2630WW Side by Side Refrigerator
Water is not coming out from Samsung RS2630WW Side by Side Refrigerator. I realized there was no filter. After installing filter I reseted and light when off, but water still not running
the water resevour is proberbly frozen inside of the refrigerator. Open the door and remove the bins in the refrigerator and you will see a resevour tank. take a hair drier and heaqt up the tubing that comes out of it until the water flows again.
Jan 17, 2009 | Samsung RS2630WW Side by Side Refrigerator
Samsung RS2630SH Side by Side Refrigerator Logo
1,324 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
