Question about Samsung HT-Z310T Theater System
Help installing Yamaha home theatre system.
I installed my home theatre system and the front right and left speakers are not working. I follow the instructions. It is the YHT-380
  • 3 Answers
Does it have two sets of main speakers? on my yamaha amp i had front A and B. in the front of the unit there will be a push switch to select the speakers. in for on, out for off.
Posted on Jan 21, 2009
    Problem Solver:
  • 13 Answers
This is probably a setting problem on your remote-the unit will ony give full surround sound on Movies like dvd-on TV you may not get all speakers going as the cable does not provide signals to drive all speakers-check your manual and change to the appropriate setting-pro-logic is bad for this-will not give sound to all speakers unless the signal tells it to.
Posted on Dec 20, 2007
Panasonic SC-HT730 home theatre has no centre or surround audio. Front right and left work, nothing else. What could it be?
First thing is to check the wiring. a simple flipping of the positive and negative at the back of the theater box can fix this. I know they have the color coded wires and suppose to be plug and play but I see these reversed all the time right from the factory. If that does not work repost and I will follow up.
Nov 12, 2012 | Panasonic SC-HT730 System
Onkyo HT R520 Home Theatre reveiver/amplifier problem
If you have isolated the problem to the receiver/amplifier, it will be necessary to find out why that output is dead
Oct 04, 2012 | Onkyo Audio Players & Recorders
How do I hook up my home theatre system?
As I understand it (& how I've got mine) is, center speaker under the TV (or over), left and right front speakers close (about 2-3 foot) to the TV and to the left and right respectively and the rear left and right speakers just slightly in front (2-3 foot) of the main viewing position and left & right respectively, for maximum bass resonance put your sub unit in the corner of the room (easy if your TV is in the corner) as it will have 3 surfaces to resonate off for better depth.
Jan 08, 2012 | Audio Players & Recorders
Trying to install my new home theatre
Are you sure the wire is not damaged somewhere? Are you sure that you are connecting the wire to the correct terminal on the receiver? Is the speaker OK?
To test all of this, try different combinations. With Right speaker working, disconnect the wire from speaker and connect it to the left speaker. If it doesn't work, then the left speaker is faulty.
Now disconnect the wire from receiver's right-front terminal and connect to left-front terminal. If it doesn't work, you are either connecting to wrong terminal or the terminal/receiver is faulty.
At last, try using the "left" wire to connect the rigth speaker to right terminal. If it doesn't work, the wire is faulty.
P.S. The +/- doesn't matter for testing, the sound should go either. It is just needed to have all speakers connected in the same polarity, because else the sound waves would eliminate themselves.
Oct 31, 2009 | Yamaha Rx-v365 A/V Home Theater Receiver
Left Speaker not working
if you swap the speakers and the dead one moves,than it is the amp that is missing a channel,in your case,it is the speaker.
if you try the good speaker in both speaker outputs,it should work on both to confirm the dead speaker theory.
there may be a broken wire in the speaker from shipping.
Sep 04, 2009 | Bose 3·2·1 II System
What is wrong with my theatre system?
have you tried all the sound settings from your dvd player? i have a 'sound' button to change from raw to surround etc. Press buttons and try it.
Some dvd's dont have the channel outputs, so try it listening to classic fm or radio 1.
AndystUK
Aug 30, 2009 | JVC THS55 System
Installing a pioneer home theatre dvd/speaker system.
On page 36 of the Pioneer users manual, it describes how to set your audio for HDMI interconnect. Follow the directions, and hopefully it will work. You can down load the manual from the Pioneer web site. Google "speaker system HTZ171 DVD". Click on the Pioneer site for your system and look for the download on the right side of page.
I hope this was helpful...
Jul 25, 2009 | Pioneer 45X4 DFS BLUE LED CAR CD
4.1 speaker setup
So basically if im guessing right you have four satellite speakers(left, right, left surround and right surround) and a sub woofer.
it is reletively easy to setup any sort of surround solution.
the front speakers shoud be set at ear level or angled towards the listening position and the rear speakers shoud be set in a straight line to the ear at a max height of two feet. or at the rear of the room, same height agled towards listening position.
The sub can be place anywhere in the room.
if you give me specific details like size of room type of speakers power handling of speakers, type of amp you are usuing seating area etc i could help you out futher.
all the best
cheers
Jul 15, 2008 | Audio Players & Recorders
Installation Help
This means that you have purchased a three piece home theatre system. Two tweeters and a sub-woofer. Assuming you are using a Stereo player (Tape/CD/DVC)you have to connect the Left Output of the Stereo placer to the Left Input at the back of the Sub-Woofer and the Right output to the Right input of the subwoofer by cables. Then take tweeters and connect them to Right speaker and Left speaker output at the back of the sub-woofer ( note if the speakers are marked L/R, then connect them to the subwoofer output accordingly. In case you are using a 5.1 player, then only connect the front right and front left to the Right and Left input at the back of the subwoofer. You are and you can now start playing your music or movies and and you will get theatre quality sound.
Aug 22, 2007 | KLH (AT2100) System
Samsung HT-Z310T Theater System Logo
128 people viewed this question
Top Samsung Audio Players & Recorders Experts
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
