Question about Frigidaire FRT18B4A Top Freezer Refrigerator
Fridgidaire Model FRT18B4AW6 seems to always be running. Cooling coils are clean, everything is clean. Cool setting is set at under half. Any reason for it to be running all the time??
SOURCE: Frigidaire frs24zrh refrigerator not cool enough
Check out partselect.com. need to replace defrost timer and defrost thermostat. good luck.
Posted on Sep 26, 2008
SOURCE: freezer freezing over
We have the same problem: We own a Fridgedare FRS26ZXH that's about 10 years old. We went to the following website: http://www.refrigerators.com/refrigeratortroubleshooting.aspx
and found a solution.
A refrigerator self-defrosts about four times a day. If a part of the self-defrosting system stops working, the refrigerator keeps cooling. This causes frost and ice to build up on the evaporator coils, which keeps air from the circulating fan, which in turn prevents the refrigerator from cooling properly. It sounds contradictory, but if there's ice building up in your freezer, your refrigerator probably isn't cold enough either. We could not see the coils in the back of the freezer compartment (should be shiny aluminum color). All we could see was ice build up over what might look like a vent.
We carefully blew warm air on these coils with a hair dryer until we could see the coils. Time will tell the cause of this problem if it happens again. It may be coincidence that the outside temp went into the teens and my 4 year old flipped off our house's heating system overnight, causing the issue.
If the problem is with the defrost system, it's either the defrost timer, defrost heater, or defrost thermostat.
Posted on Dec 23, 2008
Testimonial: "thank you.i bought a defrost timer switch..and for the last year it has ran well..now the compressor isnt kicking in..all i get is the fan to come on"
vanni7
  • 163 Answers
SOURCE: Uline 15RBK not cooling
hi!! make sure that the inside evaporator fan is on and that the compressor and condensor fan motor is on. if they are all on then you have a seal system leak of refrigerant..Good luck..
Posted on Jan 20, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Frigidaire Side By Side Not Cooling
That sounds like the start relay is buzzing. Unplug and lets check the compressor to see how hot and if too hot to hold your hand on the top of compressor we need to leave it unplugged until we find out if the start relay, start capacitor, overload or if the condenser fan stops after running a short while. Sea Breeze
Posted on Sep 13, 2009
milten1
  • 1304 Answers
SOURCE: RERIDGERATOR NOT COOLING-FRIGIDAIRE FRT21S6A MODEL
listen for the freezer fan
you may have an ice build up in the air channel
close the freezer door you should feel a good cold air flow of air in the center top shelf
Posted on Oct 08, 2009
Testimonial: "Everything he mentioned helped..THANK YOU!"
My whirlpool fridge (model ED22TOXGW00) does not keep the food cold enough.I have the temperature settings set to MAX and it's still not cold enough. Seems like the motor is not running as often as it...
Have you checked the cooling coils to make sure they are clean and air can flow through them? Are the coils in the freezer frozen up? full of ice?? Must have air from from freezer to cool refrigerator.
Aug 20, 2017 | Microwave Ovens
I have a bottom freezer model that also freezes on top! I've cleaned the coils underneath (and it was pretty bad), and that seemed to work for about a week, but now the unit seems to run alot even though...
cleaning the coils is always a good idea, that's how the unit disipates the heat it pumps from the inside of the box. clean coils make it work more efficiently. Frosty suggests a door gasket leak, allowing fresh, moisture ladden air in, that turns to frost. Runs all the time- check door gaskets. they are replaceable. Could also be a bad thermostat. thermostat is running the fridge, trying to reach the set temperature but won't shut off when it reaches it. Unplug the fridge or shut off the breaker is easier. (good wiring practice mandates a dedicated circuit for refrigerators). change the thermostat.
Does the model cool by allowing cold air from the freezer into the refrigerator or does it have separate cooling equipment like some sub zero's? Is there something blocking air flow from the freezer to the refrigerator?
spencer
Oct 07, 2010 | Amana Refrigerators
ED25DQ refrigerator: will not stop running; find
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Oct 28, 2009 | Whirlpool ED2FHEXN Side by Side...
Our Kenmore Refigerator was purchased July 1992. Model # 363-9524720 Serial # L220-16905. Problem: Refigerator runs but freezer section does not freeze and ice cubes are not forming. Food storage area does...
As a start, try cleaning the coils and fan under the refrigerator.
You would not believe how many refrigerators and freezers I've worked on which required nothing but a good coil cleaning. The dirtier these coils get, the less efficient the unit becomes until it reaches a point that it almost appears as if the refrigerant unit is not working at all when all it really needs is a good cleaning.
While you're under there, be sure the fan is running to pull air over the coils to cool and condense the freon inside them.
Sep 11, 2009 | Refrigerators
Quits running after it starts to warm up under 1 mile
Try your ignition coil. That year model chevy has a dry running coil and it does not go out all at once. It will spark and run while cool but just as soon as the everything starts to heat up the resistance in the coil begins to build and it quits firing. After letting the vehicle set a little while and cool off it will fire off and run just fine untill it starts to heat up again.
Jul 20, 2009 | 1994 Chevrolet Suburban
Topr of Refrigerator too warm
heatman101
May 03, 2009 | Amana ARB8057CSL Bottom Freezer...
Not cooling enough per the display
I have this same model which I think I bought in 1988. My frig was overheating also and the compressor was extremely hot. I too cleaned the condensor coils again and have been cleaning them at least annually for a decade and a half by putting an adapter on my small vacuum cleaner. This time I took my 6 hp shop vac and a long bottle brush and scrubbed the coils clean running the brush over the coils many times and using a trouble light to help identify where all the accummulated dust was. Frig is working perfect again. Exhaust temperature is substantially reduced. Hope this helps.
Apr 30, 2009 | Kenmore Refrigerators
Running but does not get cold enough
feel the sides or the coils on back if it has any see if they are hot or cold
Feb 20, 2008 | Maytag 15 cu. ft. / 425 liter Upright...
Refrigerator/freezer gets warm intermittently
sounds like your thermostat is faulty
the thermostat reads the temperature of the cabinet and controls the temperature
the 1 thing to check on the uprights is the evaporator is in the freezer and that makes the cool then there is a fan that blows the air around the fridge and freezer to freeze things
now there is a cycle that hapens to cycle usualy every 12 hours and that is the defrost cycle
this cycle turns off the compressor and fan turns on an defrost element on the evaporator and heats up the coils to get rid of the ice
the ice turns to water and runs through a drain to a evaporator tray and when the cycle is finished the fridge stars up again and goes into the cooling state again
when the thermostat decides that the fridge is cold enough it turns of the compressor and so on it goes through the cycles as required
if the drai is blocked or the defrost system is not working the evaporator will get choked with ice and the fan will not beable to let air through to cool things off
Jan 25, 2008 | Refrigerators
Kenmore side by side not cooling: The compressor seems to be running (it's hot), the compressor cooling fan is running, the freezer circulation fan is running, but not the least bit cool anywhere.
If everything is working, that you can see and hear, then I think you are low on coolant. A set of gauges will show you for sure or if you take the back panel off in the freezer and look at the cooling coils, they should have a light coat of frost all over. If it is low on coolant then they might have some frost on a few coils or none at all.
Dec 03, 2007 | GE GBS22HCP Bottom Freezer Refrigerator
Frigidaire FRT18B4A Top Freezer Refrigerator Logo
228 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
