Question about Zodiac Pool & Spa
Fuse blows when switched on - Zodiac Pool & Spa
    Top Expert:
  • 12,113 Answers
Possible burnt out heating element with unit off open cover and will see a long silver tube with two wires on top disconnect the wires cover with tape so they dont accidentally touch anything and cause a short and turn on unit if it doesnt blow the fuses turn back off and order a new one
Posted on Oct 02, 2009
2004 Ford Ranger 10 amp fuse keeps blowing no brake lights,abs, turn signals?
Fuses blow because there is an overload on the system. If the fuse blows when you step on the brakes then there may be a short in the wiring from the brake light switch to the lights, abs module or turn signal switch. If the fuse blows when you turn the key on then there is likely a short in the wiring to the brake light switch. Basically you will need a wiring schematic to check the wires at the switch and at each of the loads. Also verify that the fuse is supposed to be a 10 amp fuse. Hope this helps
Mar 27, 2017 | Ford Cars & Trucks
Tip
Indicator fuse blow Mitsubishi L300 wagon
Fuse blowing on Mitsubishi L300 2.4l motor, manual gearbox. Fuse 15, indicators, fuel guage, tacho. Found to be short in reversing light switch in gearbox. Initial disconnect of switch stopped fuse blowing, renew switch restored reverse lights
on May 29, 2014 | Cars & Trucks
My crank fuse keep blowing what cause it to blow
Ignition Switch / Starter Fuse keeps blowing. - CarGurus
www.cargurus.com > Questions > Ford > Focus
CarGurusAug 14, 2010 - Ignition Switch / Starter Fuse keeps blowing. - I own a 2002 Ford Focus, 2.0l SPI engine. 5-speed manual trans. Recently bought from a friend's ...
Jul 28, 2015 | Cars & Trucks
Brack lights wont light up on my 1988 ford ranger we keep blowing fuse and put in new brake switch
If you keep blowing the brake fuse than you have a short in the system. Unplug the brake switch. Install a new fuse. If it did not blow than the problem is after the brake switch. Next unplug the turn signal switch, then plug the stop light switch back in and press the brake pedal. Did the fuse blow. If not than the wiring is good in between the two switches. With the turn signal switch disconnected use a jumper wire in between the light green wire (power from the brake switch) and the orange with light blue wire (power to the right brake lamp). If the fuse blows than there is a short in the right side brake circuit between the plug in and the rear socket assembly. If the fuse does not blow than jump from the light green wire to the Light green with orange wire (power to the left brake lamp). If the fuse blows than the problem is in the left hand brake wiring circuit.
Sep 04, 2013 | Cars & Trucks
Why does my mower keep blowing the 20 amp fuse
could be the safety switch for the pedal
Apr 23, 2012 | Husqvarna Garden
Wiper motor montora sport suv keeps blowing fuse
dis-connect wiper motor and replace fuse and try switching wiper motor on if fuse does not blow motor faulty and shorting out and causing fuse to blow.if still blows fuse must be a short in the wiring from wiper motor plug back to wiper motor switch.
wiper motor proberly faulty
May 01, 2011 | 1999 Mitsubishi Montero Sport
1986 RV blows instrument panel fuse when switch pulled
The headlight switch has a rheostat built into it to dim your dash lights, it may have shorted out. As soon as you turn on the switch this rheostat comes into play and is probably whats blowing the fuse. I think if you replace the headlight switch, it will solve your problems.
May 28, 2009 | 1986 Ford Econoline
1995 tahoe 4x4 fuse just started blowing last night?
Its most likley the switch causing the fuse to blow, but you should start by disconnecting the front axle switch first and see if the fuse blows, if it doesnt blow, that switch is bad, if it still blows, plug it back in and disconnect the front axle acuator and see if it blows, if it doesnt blow, replace the acuator, if it still blows, then do the same with the relay, if it still blows, the short lies in the transfer case switch.
Dec 14, 2008 | 1995 Chevrolet Tahoe
Fuse
The Interlock Monitor Switch is an added
safety check on the Primary and
Secondary Interlock Switches. If the
Primary and Secondary Interlock Switches
allow the oven to operate with the door
open, the Monitor Switch will blow the
fuse.
You can get more information about adjuting the interlock switch from this link
http://136.166.4.200/contents/Microwave/LMVM1935xx/LMVM1935xx_Service_Manual.pdf
sections 7-11 thru 7-12 discuss the door interlock adjustment that will cause the 20A fuse to blow if it isn't set up right. I hope this helps you...
Aug 03, 2008 | LG LMVM1935 Convection/Microwave Oven
Pool & Spa Logo
96 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
