Question about Logitech Harmony 880 LCD Remote Control
Base of Harmony 880 is plugged in and lit up. When I put the remote in the charger nothing happens. It doesn't even light up. I have cleaned the contacts. Remote will not turn on anything.
    Novelist:
  • 76 Answers
Generally there are three possibilities (apart from the battery going bad and the remote cradle not getting power, both of which are infrequent) that can cause your battery not to charge:
1) Some folks have reported that the battery is not sitting tightly enough in the battery compartment. You can try folding a small piece of thin cardboard and place it between the battery and the back of the compartment. This will push the battery towards the front of the compartment and create a tighter connection against the contacts.
2) There have been reports of problems with some of the charging cradles in which the remote does not make sufficient contact with the contacts in the cradle. To ensure that the remote begins to charge, place it in the cradle and listen for a single beep. The slide show should start and then, after a few moments the screen should darken. If you hear two beeps at any time, it means that the remote has lost contact with the charging cradle and has 'woken' and is no longer in charging mode. Wiggle the remote to ensure that it is sitting in the cradle and making contact. There are also some fixes that can be done of the cradle itself, including opening it up and adjusting the height of the contacts. Others have had luck cleaning the contacts on the remote and the cradle with alcohol or a contact cleaner like DeoxIT. Still others have actually sanded down the plastic surrounding the contacts on the outside of the remote in order to bring them closer to the cradle contacts.
3) If you still have trouble after you have tried everything above, there may be a loose connection inside the remote itself. There is a very small plug that connects the charging terminals on the remote to the battery compartment. In some cases, this plug can become loose (especially if the remote has been dropped). If all else fails, you can open the remote and check to make sure that the plug is completely seated or attempt to push the terminal contacts slightly farther out. However, most people have found that altering the height of the contacts on the charging cradle is a better way to go. If you want to open the remote, do the following: remove the two screws - one in the battery compartment and one at the top of the remote. Then, using your thumbnail (this is really the best, unless you have a thin, rigid piece of plastic. A part of a credit-card may work), force your nail between the two halves of the clamshell casing near the bottom of the remote on the left or right side. Once you get your nail (or plastic) into the remote, angle it down at about 45 degrees and simply slide your hand up one side. This will release all the locking tabs very nicely without marring the surface of the remote. Then do the same on the other side. Once you are done exploring, simply realign the two halves and snap them back together.
Posted on Mar 06, 2010
Harmony 880 not charging
If your Harmony remote is not charging on the base, try pressing down on the remote, and wiggling it around. It's just that the pins are not making contact.
If pressing down helps, you can fasten it on with a elasitc band or something so that it keeps charging. If that does not work, then you will probably need a new charger. Good news is that they are only about $10 if you buy it right from Logitech. You can call their sales line at 1-800-231-7717.
Hope that helps you out.
Apr 05, 2010 | Logitech Harmony 880 LCD Remote Control
Tip
Harmony 880 Manual Download
Download Logitech Harmony 880 Remote Control Manual
Have you misplaced your Logitech Harmony 880 Remote Control Owners Manual?
Would you like a digital, searchable, pdf version of the Logitech Harmony 880 Remote Control Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
__________________________________________
Logitech Harmony Firmware Update
Harmony Mac Software Download
Harmony Win Software Download
Logitech Harmony Safe Mode Fix
Harmony Remote Glow Light Fix
on Apr 30, 2010 | Universal Remote Control Harmony 880...
Tip
I hope that helps.
on Apr 30, 2010 | Logitech Harmony 880 Universal Remote...
Logitech harmony does not charge
Mine does that on occasion. Is the blue light on in the charger base? If yes, check the connections on the charger base and the back of the remote to be certain they are clean. Does the remote do anything when you place it in the charger? If no to the blue light or the response of the remote, be certain the wall outlet is working, test the wall adapter, test the charger base. A voltmeter is handy for this. The only way to determine where your problem is, is to check to be certain all connections and pieces are doing their jobs. Test one at a time, divide and conquer. I hope this gives you some hints that lead you to a solution to your problem.
Nov 16, 2009 | Logitech Harmony 880 LCD Remote Control
The remote charger isn't working
If pressing down helps, you can fasten it on with a elasitc band or something so that it keeps charging. Also, if it is still under warranty, I woul advise contacting Logitech's wonderful support team to get replaced.
Hope that helps!
Oct 29, 2009 | Logitech Harmony 880 LCD Remote Control
Tip
I hope that helps.
on Apr 30, 2010 | Logitech Harmony 880 LCD Remote Control
Remote still says battery low, and its on the charger all day.
Product: Logitech Replacement Battery for Harmony 880/H890 Remotes SKU: 994-000033 UPC: 097855049476 Brand: Logitech Availability: Phone Orders Only Condition: Brand New Factory Sealed with Full USA Warranty Price: $24.99 Shipping: Click to Calculate!
Apr 17, 2009 | Logitech Harmony 880 Universal Remote...
Logitech harmony 880 won't charge
Clean the leads on both the charger and on the remote itself with rubbing alcohol.
We had this problem (it would lose connection periodically for no apparent reason, then eventually wouldn't even register that it was set down). The leads sure looked clean, but shining them up with rubbing alcohol (recommended on one of the Logitech boards) got it to start charging again.
Mar 31, 2009 | Logitech Harmony 880 LCD Remote Control
Remote control could not be charged at its base
I have the same remote. Clean the contacts on both the remote and the charger base. Then place the remote in the charger. If it does not start charging, wiggle the remote back and forth in the base while pushing down gently. It should begin charging. I have found I must clean the charging contacts every few months.
David
Mar 26, 2009 | Logitech Harmony 880 LCD Remote Control
Harmony 880 universal remote re-charging problem
I took the rubber feet off(4) from the underside of the cradle - removed the four screws and separated the top half of the cradle from the bottom. This exposes the two long thin charging arms and points All one piece). I then took some doubled sided tape, similar to what you use to put up temporary 3m picture hooks and cut four small pieces about 1/8th in square. Join two of the pieces back to back to make one piece (double original thickness), then raise one of the long charging arms gently and place the piece of double sided tape under the head of the arm (ie under the very end where the rounded point is, that sticks though the cradle when reassembled (there are two of these). Do this to the other arm.
Why - by inserting the doublesided tape you permanently raise the arms without bending them - ie they will now stay in that position and not bend out of shape, losing contact again . With the cradle reassembled, put the remote back in the cradle you will have more direct contact with the two charging pins. FIXED!!!!!!!! Good luck1
Nov 15, 2007 | Logitech Harmony 880 LCD Remote Control
Logitech Harmony 880 LCD Remote Control Logo
90 people viewed this question
Top Logitech Televison & Video Experts
Jerry Umali
ka4iup
ka4iup
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
