Question about Frigidaire FDL50R1 Dehumidifier
I put a hose on my 50 pint drain and it still just fills the tank, what do I do? PS the hose is not plugged
  • Frigidaire Master
  • 8,404 Answers
Is there a actual hole in the tank where your hose connects? Is there a piece of dirt clogging the hole in the tank.
Water runs down hill ... if there is a hole in the tank for the water to get out and the hose is clear and it is going down hill ... it must drain. The entire length of the hose has to be flat or down hill and no kinks.
Let me know what you find please
a
Posted on Oct 02, 2009
I have a hose and it was perfect but now the water is leaking from the left bottom corner to the floor. What do I do?
Posted on Aug 27, 2012
Why is my Kenmore Energy Star 50 pint model 251-50501012 dehumidifier leaking water after I disconnected the drain hose
If you reconnect the drain hose, make sure that it lays flat from the dehumidifier and into the sump pump hole. I did that and it solved my problem of water leaking onto the floor.
Jun 15, 2014 | Kenmore 50 Pint Dehumidifier Electronic...
Hello, I need a dehumidifier of 50pint or more that stop when the humidity level is reach and will restart when is too high. I look for a lot of brand and model and I cannot find one thanks for your...
The fifty pint capacity might be a challenge ... think about this ... 6 + gallon tank @ 7+ pounds per gallon ... 42 pounds of water to drag from the dehumidifier to the drain? Who is going to do that?
All dehumidifiers run at some % of humidity (via Humistat), (like you are asking about) i.e. come on at some % above the setting and go off when the setting is reached. I suggest you find one that has a standard one or two gallon tank that also features a hose connection in the tank. Run the hose from the tank to the floor drain in your basement or a drain near what ever room you are trying to dry out. When you connect the hose --- you will have to put a hole into the fitting on the tank for water to flow. The idea of the tank is that the machine will run on the setting until the tank fills up ... at which time the tank full switch will not allow the machine to run again until you dump the water (and you want to drag a 6+ gallon tank, 42+ pounds, around?) . If there is a hose attached, the tank never fills up.
Some dehumidifiers feature a pump to which will pump the water to a near-by drain. You may be able to rig such a setup yourself using a small pump like a fish pond pump or similar.
You may want to consider using two dehumidifiers (with or without hoses) rather than one BIG machine. I run two machines from a major USA retailer (one in each end of the basement) and they run into the near by sump and the system works fine @ my house.Thanks for your
Thanks for your question @ FixYa.com
Jun 05, 2011 | Dehumidifiers
Have hose hooked up but it does not drain. Compartment fills with water and needs dumped manually. Want the hose to work so twice-a-day dumping in basement not needed. Thanks!
You connected a hose to the hose outlet on the catch tank ... right? The tank will not drain even though there are no kinks in the hose and the end is lower than the tank, right? Did you put a hole in the tank before you attached the hose? I will bet not ... and I will not laff at you ... I did the same.
Put a hole in the tank (where the hose attaches), reattach the hose and all will be well.
Thanks for your interest in FixYa.com :-)
Aug 09, 2010 | Soleus 30-Pint Dehumidifier
I cannot find my manual for the Westpointe dehumidifier. I need to know how to fix it so that it uses a drain instead of the tank. It is set up with the hose which is directed to a drain. However, I...
Make sure the hose is clear. Did you put a hole in the attaching place for the hose? Most tanks come with no hole even though there is a hose place in the tank.
Jul 05, 2010 | Midea MDC-45AE Dehumidifier
50 pint dehumidifier has drain hose connected but fills up the drain bucket and stops running....
safety switch is turning off the dehumidifier....you need to drain out the bucket more often....or put the drain hose into an actual drain....ive seen some people run a small plastic hose from the dehumidifier to the sump pump hole in their basement.
Jan 27, 2010 | Frigidaire Dehumidifiers
Help! Water keeps filling the tank instead of going out the hose
Had the same problem. Make sure you tighten the house a little with pliers. Also, make sure the dehumidifier is up a lot higher than where you're draining it into. Mine drains into a utility sink. But I have the dehumidifier propped up onto a dresser. I cut a small piece of hose to run into the sink. Seems to be working now.
It will take 5 min or so to establish a water flow, so be patient after you hook everything up. Good luck.
Jul 07, 2009 | Danby DDR586R Dehumidifier - 58 Pints...
Water will not go down drain tube
Sounds like you have a clog. Either try plunging the drain in the stationary tub or replace the line from the humidifer.. Just a thought
Jun 10, 2009 | Danby DDR586R Dehumidifier - 58 Pints...
Figidaire 25 pint dehumidifier
Check the point on the tank (Bucket) where the hose connects to. Make sure there is no obstruction at the outlet of the bucket to the hose connection. Next make sure the hose has no kinks or no loops that may trap air to the drain. If necessary for a long run to the place of drainage raise the dehumidifier to a higher level for better drainage.
Jun 20, 2008 | Frigidaire FDL45P1 Dehumidifier
Frigidaire FDL50R1 Dehumidifier Logo
825 people viewed this question
Top Frigidaire Dehumidifiers Experts
Lawrence Oravetz
mike cooper
Are you a Frigidaire Dehumidifier Expert? Answer questions, earn points and help others
