Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Oil pump gear tooth shredded . so the chain sticks during a job . need oil pump to be replaced . however not enough info on chainsaw , only poulan wild thing , no model # or anyhing . Can you help
    President:
  • 2,220 Answers
If it is a Poulan Wild Thing your IPL can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
Wild things have a LE suffix ie 2375LE. HTH
Lou
Posted on Oct 02, 2009
    Problem Solver:
  • 18 Answers
Sears craftsmans chainsaw's are poulan. might be able to get part info from sears store or website.
My poulan pro chainsaw dies when I give it gas and I think the bar and chain oil is leaking out during storage.
try and run it with the muffler off the build up with carbon and restricted the exhaust flow as for the oil leak mine the screws became loose behind the clutch for the oil pump
Sep 17, 2012 | Poulan Pro 20-inch 2-cycle 50cc Gas...
No oil getting to bar and chain..
The oil pump is run by a worm gear that will strip easily if the oil pump becomes clogged. You'll have to remove the bar and do some disassembly on the saw, but it is possible to fix. You can buy the replacement parts kit (that comes with an instruction sheet) from poulan for about 20 bucks, just call the number on the saw.
Sep 05, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
My poulan is not sending oil to the chain, i tried taking air to it and cleaned it out.
The oil pump has a worm gear that strips easily if the oil line clogs. You will likely need to replace it.
Aug 30, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Chain oiler does not seem to be putting out enough oil,what can i do to increase the flow?
This model does not have an adjustable oiler. If the ports are clean and the pickup is clean, you may need to replace the pump. This is generally an inexpensive repair.
Feb 20, 2011 | Poulan Pro PP4620AVX 46cc Gas Chainsaw...
Poulan 2300 Firewood chain doesn't oil
She is long of tooth. Some oiler parts are NLA. Item 17 on the "Power Unit" print is the actual oil pump. Do not mistreat it; do not blow it out with air; they are no longer available.
http://www.ordertree.com/modelinfo/PWE/2300AV-Gas-Saw/75.2300AV-Gas-Saw.1.59.1.html
Please see this thread, post 5
http://www.arboristsite.com/showthread.php?t=120981&highlight=poulan+xxv+oiler
The *.pdf is your oiler. I suggest you read the entire thread. and save the *.pdf to your hard drive. HTH
Lou
Feb 10, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Chainsaw bar is dry. Chainsaw is full of oil.
my best guess is that your oil pump has gone bad.
Mar 12, 2009 | Garden
Poulan 210 Pro not oiling chain
Make sure the oil port doesn't have a chip of wood blocking it.
Jan 30, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Bar oiling problem
Just a thought: Is it cold where you are? At this saw mill where it is my job to keep chain saws running, learned years ago that you cannot use "bar oil" in winter. Need thinner oil, like motor oil. ....preferably a "non-detergent" motor oil, plain 30-weight is OK, HD30W will work, but the HD part causes the chain to stretch more so than standard bar oil. The bar oil literally is so thick in cold that it stripped the worm gear out of a Poulan Pro oil pump (plastic gear, anyways, wasn't much to begin with.) But thought you may want to try thinner oil, if it is cold where you are. Oh yea we also have 2-Husqvarna 359's with 20-inch bar, and use thinner oil in winter. Our Husqvarnas have an oil adjuster located on bottom, on clutch side. Straight slot screw adjustment.
Nov 18, 2008 | Husqvarna Chain Saw 20" Bar
Insufficient chain oiling
Sorry to tell you this but you need a new OIL PUMP but it's not a difficult thing to replace.
On the main shaft of the crank shaft under the centrifugal clutch is a spiral wound wire that matches a plastic part that is the oil pump. You can get the part from Poulan parts and it will take about 15 minutes to fix the first time eight minutes the second time.
Glad to be of assistance.
Oct 09, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
316 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
