Question about Akai DC6371 Digital Camera
I put new batteries in and it shows the batteries are no good and turns itself off, I have tried several different NEW batteries and it does the same thing,if I open it and shut it (the battery cover) a few times SOMETIMES it it will work but not very often?
3 Suggested Answers
  • 13 Answers
SOURCE: tv shuts off when you turn it on again it will play a minute
I think this might be bad/swollen capacitors in your power supply, or something odd in the +5VDC circuits of the power supply, but I am posting all of the things I have found so far with these TVs.
Here are few possible solutions:
If you have no red light and you have a Megmeet MLT386 power supply, check these parts:
1) Swollen caps on the PS secondary circuit (may cause the red light blink or shutdown problems).
2) Blown fuse F1 (5A/250V) this is caused by a shorted FET at QA1 (20N60), you may also find that SMT cap CX23 is burned up (.001uf) which is in parallel with diode DA2 which may be damaged/shorted, replace these components.
If the power LED goes from red to green when powered up but no picture, then it might be lost +24VDC from the power supply:
3)Check fuse F2 (3.15A/250V, I put a 5A in), if it is blown, replace FET at QA2A (9N50C), replace QA2 as well (9N50C). Check SMT resistors at R233,R234,R235,R236 (.47 ohm). If open, replace with .1 ohm 1W or 2W resistor (easier to source). Also replace SMT transistor QF1 (2X4 or 2N4401 NPN transistor). And replace diodes at DS2 and DS1 (HER207), DS2 was shorted, DS1 was ok but I replaced it anyway.
I dont know as much about the Megmeet MLT169A, but it has similar problems and similar components.
4) I had to replace all of the capacitors in the secondary circuit (there are six in a 3x3 row marked EC9 (1000uf35V),EC10(1000uf35V),EC14(470uf35V) and EC18,EC19,EC20 (all 1000uf35V).
OK for the Megmeet MLT169A with red flashing LED when turned on we found that IC7 was bad. This is an SMT component on the solder side of the power supply. It is a 4407P (P channel 30V MOSFET). For testing purposes, we jumped across it to feed +5V to the TV permenently instead of allowing +5V to go into standby.
Posted on Sep 21, 2009
SD Tech
  • 14553 Answers
SOURCE: Akai pt5492 shut off by itself this morning,
First is the Akai name is owned by Samsung--and here is a general answer:
Red light is shutdown or means only standby light is on.
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.
Posted on Mar 29, 2012
I have a kodak z650, this is "new" machine in the original box but we never used in the past six years. When then i turn on in the LCD showed "Kodak easyshare logo" then turn off by itself... The le
If you really left the batteries alone for 6 years without regularly charging them, they won't work anymore. I still have two KLIC 500 batteries from Kodak, which I bought in 2005, Both are in very good condition, because the both get a charge every 3 months, even in periods I did not use my camera.
You could try. charging the batteries several times, but don't have to high expectations.
Jan 03, 2014 | Kodak Cameras
Hello I have Pentax IST DL just took out of case put new batteries in did not work battery light came on. Tried again came on but did not take photo. Then turned of again, tried lots of new battery. ...
The early ist cameras had a battery indicator problem which Pentax never addressed. Most owners learned to live with it by turning it off and on several times until it showed full power.
Dec 15, 2010 | Pentax Cameras
NAVIGON 7100 WON'T TURN ON
your battery is gone requires new one.
Aug 20, 2009 | Navigon 7100 GPS Navigator GPS Receiver
2002 PT cruiser trying to start with no keys!
I would check your wire harness. The starter is close to where you would be working on the radiator. I have not had the pleasure to put one in but i know its a tight squeez in there.
Jul 22, 2009 | 2002 Chrysler PT Cruiser
Cannot turn on my Kodak easyshare c713
Hi I had the same problem with my daughters c713. Tried several bateries found out that the camera is specific with its bateries brand. When i put in new ones from kodak itself from my sons camera a c913 the c713 turn on again. Tried a new pack local brand checked them first and voltage was ok but didn´t work again. Back in those from kodak and ok again. Tried philips also ok.
So try different brand and find out. Good luck.
Jaap Davids The Netherlands
Jun 17, 2009 | Kodak EasyShare C713 Digital Camera
Camera turns off by itself after taking a picture
A friend of mine had the same prob after putting in brand new batteries, it was i bit wierd but i tried some different batteries and it started working , try some new batteries. hope this helps.
Feb 28, 2009 | Panasonic Cameras
Cannot see through the monitor screen
If you cannot find a solution to your problem you may want to email fixityourself@gmail.com. He has good advice and good used parts at a fair price.
May 16, 2008 | Casio Exilim EX-S600 Digital Camera
Camera won't turn on
flip over the batteries...that happened to mine. also ....not all new batteries any good. make sure they wok in some thing else.
Mar 30, 2008 | Canon PowerShot A520 Digital Camera
Vivitar ViviCam 3615 Digital Camera
i have a vivitar vivicam 3720 digital camera need sofewear
Nov 13, 2007 | Vivitar ViviCam 3615 Digital Camera
Akai DC6371 Digital Camera Logo
26 people viewed this question
Top Akai Cameras Experts
Steve
Are you an Akai Camera Expert? Answer questions, earn points and help others
