Question about Microsoft Windows Vista Home Premium with Service Pack 1: Windows
Monitor says check signal checked the monitor on another computer works fine changed mother board same problem only things still left memory and hd and dvd rom drive.
The problem is something you have recently changed( i.e. new memory, processor, video card) does not agree with your board. Good place to start is to remove ALL memory sticks and pci adapters and try it then. Try one component at atime and start putting them back in. Restart and run every time you put something new in thew board. Hope this helps
Posted on Oct 02, 2009
MONITOR Dell older model says no signal
The first thing to check is the cable between the tower and the monitor. If you have done this, then hold the power button until the computer shuts off...wait 5 seconds and then turn it back on. If these two things do not work, then it is likely that the integrated video part of the mother board has failed.
Feb 25, 2013 | Dell Computers & Internet
Intel 845 GL mother board no display ;processor memory & SMPS are working fine in another mother board
Does it have any beep sounds on switching on( some computers won't produce beep sound) or does your monitor is not getting any signals from computer even though it is ON and has shown any message or menu screen of Monitor functions then,
You will be having a faulty RAM or your Graphic port has some hardware malfunction.Or it can be also from a new unsupported hardware installation that will prevent computer from booting up.
If your monitor does not provide any of the above monitor functions successfully then
It would be a monitor problem. Check wires or cables of monitors or contact nearby technical support
Sep 06, 2010 | NEC Galileo 845GL (N4-IBFGL) Motherboard
No Display on Mother Board
Have you try troubleshoot with working monitor, display card or your matherboard and processor,
Usually no display problem occur becouse of one hardware between monitor, ram, motherboard, displaycard and can be your processor problems.
You can try troubleshooting one by one of your computer hardware to get problem occur
Jul 21, 2010 | Intel Desktop Board D845WN Motherboard
Not gettin any signal from cpu
When the monitor shows no signal it means either the data cable going from the monitor to the computer or the computers graphics card needs to be replaced.
Sep 07, 2009 | Computers & Internet
No beeps or monitor signal
Sure, a motherboard can be a dud out of the box like any other part. If you have a known good power supply, processor and memory installed, and the machine doesn't boot and you have no video, the only thing left is a non-working motherboard. Return it to the vendor and get it exchanged as defective.
Jun 20, 2009 | ASUS M2N-VM DVI - Motherboard - micro ATX...
Black screen
unplug evry thing and check out the cmos battery on *********** board .remove that cmos battery and reinsert that.also remove the ram (the memory)from the mother board and refit it properly and then reconnect every thing as it was and start the pc it will work.
Feb 26, 2009 | E-Machines eMachines Desktop PC
No signal to monitor when booting.
(1) Remove memory from mother board and start the system if you happen to listen long beep then RAM is not working properly.
(2) Clean RAM conducting area on mother board with clean cotton cloth, put one peice of RAM and test and check the othe peice also, if working you could any sign display . Before doing all these check mother board any LED is glowing if so your SMPS is working after you turn on UPS.
(3) Check for all proper connection for all cables. Have you connected video cable of monitor to mother board VGA (it will not work because it is disabled as soon as you installed XFX GeForce 8800 GT), your viedo output only will come through XFX GeForce 8800 GT VGA port.
(4) If propelm persits Deassmble complete the system and reassmble & do n't connect HDD, DVD, floppy. Cehck with bare mother baord, processor, RAM (put one picese at a time) by connecting viedo cable of monitor
Apr 19, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
No Boot
if u didn't get any thing on display even check signal cable the problem is in the monitor
or you are getting check signal cable the problem is in the mother board or Ram first change the ram even thou you are not getting display change the mother board
Apr 16, 2008 | Computers & Internet
Monitor not getting signal
Check your cables.
If the cables are fine then there is something
wrong with your comuter.
Do you hear any beeping sounds?
Mar 07, 2008 | HP Compaq d530 SFF PC Desktop
Monitor displays signal cable disconnected
Check if motherboards you connect the monitor into has a video signal frequency range that the monitor supports.
Feb 01, 2008 | Dell UltraScan P1110 21" CRT Monitor
Microsoft Windows Vista Home Premium with Service Pack 1: Windows Logo
23 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
