Question about Whirlpool LER4634J Electric Dryer
Have problem with it drying turn it on two or three times to dry
  • Whirlpool Master
  • 8,404 Answers
Check your exhaust system, I dont think it can breathe. I suspect a clog somewhere between your lint filter and the vent out of doors. Check the whole thing.
I hope you are able to get your machine to operate.
Posted on Oct 02, 2009
Dry takes a long time to dry cloths
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes, or the heating element has gone bad, burnt in half and is making contact with the case to provide it just enough power to barely heat. The second thing is a very rare occurance. I would turn the dryer on, find out where the air vents out to, and with the dryer running, go to where it vents and check to see if there is a strong flow of air. 9 times out of 10 that is going to be your problem. Another way to check air flow is to just pull the vent off the back and let the dryer run and see if your clothes dry faster. If you do it that way and they still take a long time to dry, then you'll probably need to replace the heating element
May 28, 2012 | Kenmore Dryers
Light is on for heat dry but won't allow me to run a cyle or turn on
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad.
Hope this helps... Please post back if you need more information.
Daniel
Apr 17, 2011 | Frigidaire Professional Series 24 in....
On a 40 minute drying cycle, it will have to be restarted two or three times to finish the drying cycle.
take the exsaust off the back of the dryer and dry a load
what happens does it dry better?
Aug 24, 2010 | Kenmore 700 6972 Dryer
Not drying
Many times your lint filter is plugged or the exhaust is plugged
Try cleaning both and see if it helps
Apr 01, 2010 | Maytag 7.0 Cu. Ft. Electric Dryer
When i turn dishwasher on it goes to 1 and just stays there.one time a tech reset my old one by pressing three of the buttons but i cant remmember which ones. its a queit partner 1v
Normal-Heated Dry, Normal-Heated Dry, Normal-Heated Dry, Normal-Heated Dry.
OR (depending on the model)
Hi-Temp-Heat Dry, Hi Temp-Heat Dry, Hi Temp-Heat Dry.
Hope that work`s. Keep in mind there is a underlying problem to cause the "1" to appear in the display repeatedly, so this is only a short term cheat.
Good luck.
macmarkus :)
Dec 08, 2009 | Whirlpool Dishwashers
My samsung hdtv got wet and now will power up peep three times then turn off
dry it inside with a hair dryer before using it. hopefully it will dry out
Jul 27, 2009 | Samsung LN46A650 46 in. LCD HDTV
Ge dishwasher not drying
1 make sure heated dry is on.
2 run your cycle and when it says drying open the dishwasher. see if it has steam coming out.
3 give me your whole model number.
4. if heater is not turning on then you may have one of three issues.
1. Bad door switch
2. Wire off element or bad thermistat
3. No power going through the control. to the heating circuit.
Jan 07, 2009 | GE ADW1100N Built-in Dishwasher
Rolling into balls
There is nothing you can do about this. the disadvantage of sheets and blankets.
May 07, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
GE Dryer DDE7200SBLWW doesn't dry quickly
it sounds like it could be your vent turn dryer on go outside and feel your air coming out of vent if not a good air supply clean your venting system
Dec 13, 2007 | Dryers
Whirlpool LER4634J Electric Dryer Logo
52 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
