Question about Philips 37PF7320A 37 in. HD-Ready LCD Television
Part Idenfication I have the Philips 17PF8946A It has a heat sink on one of the boards with an IC or something connected to that heat sink. The heat is the biggest one on in the set. almost 3" long and about 1" high. It is the only one that large in the set, That 12 pin IC connected to it is burn so bad that I can't make out the numbers on the thing.
  • 1 more comment
  • mitchell239 Dec 21, 2007
    I need to to be able to read the numbers on that IC. I need it to be able to buy a replacement.
  • mitchell239 Dec 22, 2007
    This is what I need to replace. I can make out the AN7 H but nothing between. and the number below that which is 431. and on the board at pin 1, there is a number 7679. I need help to find out just what the other numbers should be on this device.
    I can post a better picture if needed.
  • 170 Answers
Hi,there is a notch or a hole on the top of the IC.
The pin adjacent to the notch is the pin number1
and the pin below no.1 is no.2
....no. the pins in the above fashion......all the best
happy christmas
take care bye & have a nice day
Posted on Dec 21, 2007
  • bharath m
    bharath m Dec 22, 2007
    CAN YOU TELL IT MORE PERFECT
  • bharath m
    bharath m Dec 24, 2007
    if the ic is damaged its better to replace it by a new one
Distortion in clean channel in fender frontman 65r
If the IC is MC1436, Pin one is not connected.Pins 2, 3 and 6 are the signal carriers, 6 is out 2 and 3 are inverting and non inverting inputs. CR13 and CR 14 would be simply something on the order of a 1N60 or a !N914 depending on body size,
If it works fine with heat snk screws removed, check to see if they short something out. Also look for small cracks in the board with the screws in place and snug. It also would not hurt to reflow the solder on all component leads and headers that are in the vicinity of the heat sink. Just because they "look" okay, does not mean they may not be faulty. Reflowing eliminates a cold solder joint as a possibility- which by your description is actually the most probable issue. Followed by cracked board and inadvertant short. Esepcially if the heat sink is supposed to be electrically isolated. If it continues, try using nylon mounting hardware for the heat sink, Also when powered up tap each IC, electrolytic capacitor and transistor with a pencil eraser- those that make noise may be the source of the problem. The applied stresses of the screws might deflect the transistor just enough to make a contact intermittent internally in the device..
Oct 13, 2012 | Fender Music
When you try to turn the tv on, all you get is a blinking red light, if you unplug for awhile, sometime it will come on.
Symptom: tv turns on, tv clicks once, red light comes on. Then, tv either works for a while, followed by a click, no video, normal sound and flashing red light; or, tv immediately clicks, no video, no sound, red light flashes. If that is the problem, you need to replace the convergence ICs. I had to do this twice. The two convergence ICs are mounted on palm-sized aluminum heat sinks. The heat sinks are soldered to the main circuit board. There are 4 pins soldered to the board for each heat sink, and 18 pins soldered to the board for each IC. Some of the heat sink pins are a bit difficult to desolder. The pins for the ICs are not difficult to desolder, but you must be careful not to overheat them. The heat sink and the IC come out as a unit, after all pins are desoldered. The IC is screwed to the heat sink. The correct replacement IC is a Sanyo STK392-110. I got mine from B&D Enterprises. They were not expensive. The new ICs need to be mounted to the heat sink with a heat transfer paste. I used Arctic Silver from my computer processor heat sink. Installation of the heat sink/IC assembly is a bit tricky, since you have to align all 18 IC pins and the 4 heat sink pins. When all the pins are visible through the holes in the circuit board, resolder everything. The TV should now work. Be sure to replace both ICs. My first repair was done by a technician, who obviously only replaced one. That repair only lasted a couple years, before the problem returned.
Mar 22, 2011 | Toshiba TZ55V61 55" Rear Projection...
Sound stopped coming out from teh tv speakers. i have to run it through my stereo system
Hello, I am John at J. D. Electronics. You have a D4 model. This is caused by a defective spacer under the A / V board. This is not recommended for owner repair, since it involves removal of other PCBs, Sheilds and "spacers" and connectors. On the A / V board ( the one with all the jacks ), is an audio IC that normally runs fairly hot. Therefore, the MFG had to use an aluminum heat sink on the top and bottom of the IC. The problem is that there is a "clay like " spacer pressed between the bottom PCB at the audio IC and an aluminum plate, or heat sink, underneath that sets against the metal back of the LCD panel. Here is what happened; The "spacer " turns into a "sticky goop" causing the whole pcb move towards the Heat Sink under the A / V board. This causes the connections at A / V pcb at the audio IC to come in contact with the bottom aluminum heat sink, thus shorting out the audio IC and then no sound or popping noises. This is common on the D4 and D6 models.We charge about $325 for this repair since it is very time consuming. I have repaired dozens of these sets with this problem. I hope this helps! John
Jan 27, 2011 | Sharp Aquos LC37D44U 37 in. LCD HDTV
When I first put my tv on the volume is fine, after a few minutes a click sound is made and i lose the volume completely.
Sep 26, 2010 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Philips 50P8341 50 in
Board location 7550 on the LSB ( Large board on the right) Its a TDA4861 its not like the convergence IC its mounted to a black aluminum heat sink with a metal spring clip
Aug 21, 2008 | Philips 50P8341 50" Rear Projection...
How hard to replace ICs?
Remove the 4 screws going through the IC's, unsolder the 18 pins each IC, take a small flat head screw drive place it between the heat sink and IC and pound gently until the IC breaks free, wiggle the IC's to make sure all pins are free and remove them.
Take rubbing alcohol and a Q-tip and clean where you need to resolder. "So you can see the pads better." Put heat sink compound on the heat sink, slide the IC's back in, secure them with the screws, solder the pin's making sure you don't blob pin to pin.
Jul 18, 2008 | Philips 60PP9202 60" Rear Projection...
Hello again!!!! model# is FP5251 G105
There should be three circuit boards on that model a small board on the right then a larger board in the middle and another large board on the left the vertical IC will be located on the middle board it will be attached to a aluminum heat sink.
Jun 01, 2008 | Philips Magnavox 51MP392H Rear Projection...
How do you install the convergence part on a Mitsubishi WS55511 big screen tv? The part has prongs on the bottom but I don't know how to attach it.
you must de-solder the output IC first. Then I would suggest that you remove the heat sink by removing the philips screws holding it to the pc board. you will find white heat sink compound on the bottom of the heat sink. clean this off and remove the output IC. put some heat sink compound on the new IC and install in in the holes on the pc board. be careful removing the solder on the pc board. I like to use solder wick. Install the new IC and solder it up as the old one was. remember to check the convergence in both analog and digital, as you have to converge both for it to remember the settings. Hope this helps. TV repair guy :)
Jan 31, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Philips 17PF8946A/37 burned IC.
That sounds like the vertical sweep IC. Can you see a reference designator for this IC?
Dec 21, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips 60pp9202 sound but no picture
Sorry no pic, but if you look from back of set on deflection board(board with HV transfromer)big part with about 4 wires coming out going to your picture tubes. Looking close to leftside of board the last IC with heatsink shield standing up has a small 7 pin ic if looking on it you should see TDA8177 or something to that affect. This is the verticle IC. Since you have found the IC's (convergence) then the only thing left is to look for open fuses like 1300, 2004, 1900 etc and see if open. Concerning cost if you buy from www.bluestaronline.com these part are inexpensive so it wouldn't hurt to buy all. Rule of thumb, if set has color problem then Convergence IC, if no problem just went out one day while playing fine then Vertical, then the alternative if no sound the audio area, which is not common for this set. Hope this helps!
Sep 03, 2007 | Philips 60PP9202 60" Rear Projection...
Philips 37PF7320A 37 in. HD-Ready LCD Television Logo
43 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
