Question about Leapster Learning System
Leapster will not recognize the pen ...first it was stuck at the Canada/USA screen...now at the name screen? When I try and get to the Calibration screen I press ? and the on button but when it gets to the sign in screen I can't do anything the touch screen doesn't work. Even pressing A doens't do anything.
Answer If your Leapster2 does not respond to the stylus pen, it needs to be calibrated. Calibrating the Leapster2 is easy:
1) Ensure that a cartridge is not inserted 2) Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER menu appears. 3) When the LEAPSTER menu screen appears, press the A button 4) Touch each of the crosshairs that appear with the stylus 5) Restart unit
Posted on Oct 11, 2009
  • tpmitchelmor
    tpmitchelmor Dec 29, 2012
    Nothing is happening. Does this mean I need to put it in the garbage?
  • 7 Answers
If you don't see any X's then you have to clean the screen very well with some Windex and dry it well. Take any crumbs out of the screen edges and then "milk" the screen with the thumb gently. What happens is that the digitizer gets pressure areas built up so you want to dislodge it. You might need 3-4 "milking" tries. By milking I mean pressing on the screen with the thumb (gently) till you see the screen "bleed."
Posted on Nov 16, 2009
I'd like to emphasize on Quebol96's instructions to hold down the hint (?) button at the same time that you start the power up mode..if you wait till the screen starts up it doesn't work. Others were saying to hold down the home, hint and B button and that wasn't working at all for me.
Posted on Nov 22, 2009
The pen on my sons leapfrog leapster won't work
Push the "A" button to enter the calibration.
There will be a little plus sign. Touch it with the stylus and continue to touch the plus signs with the stylus until you return to the calibration screen.
Turn the Leapster off and then back on again without a cartridge.
Sep 05, 2012 | LeapFrog Leapster 2 Learning System
The pen wont work
hold down the question mark key, while still holding the question mark key turn on the leapster explorer. it will bring you to calibration screen, Calibrate and you should be ok
Aug 07, 2012 | LeapFrog Leapster Explorer Learning Game...
I recalibrated the leapster2. It recognizes the stylus on the calibration screen. When I reboot it still doesn't recognize the stylus at all. Please help.
If your Leapster does not respond to the stylus pen, it needs to be calibrated.
The following are instructions below on how to recalibrate the leapster.
1. Insert a cartridge, turn the unit on and wait for the sign-in screen to appear.
2. Hold down the Home, Hint and B buttons simultaneously.
3. When the screen changes, press the A button.
4. Using the Stylus, touch the center of the targets.
Thanks for using Fixya.
Feb 06, 2011 | LeapFrog Leapster Electronic Book:...
Just replaced batteries. Screen won't responsed to pen touch.
Look at the link below under "Calibration." My daughter's Leapster did the exact same thing, and this fixed it immediately.
Apr 05, 2010 | LeapFrog Leapster 2 Learning System
Leapster 2 asking to choose usa or canada but unable to select
Try calibrating the screen:
(1) Insert a cartridge, turn the unit on and wait for the sign-in screen to appear.(2) Hold down the Home, Hint and B buttons simultaneously.(3) When the screen changes, press the A button.(4) Using the Stylus, touch the center of the targets.
Aug 06, 2009 | Leapster Learning System
Leapfrog Leapster touch screen
Press the ? button and hold it while turning unit on.
Press the "a" button to select touch calibration
Press each + with the stylus
Restart machine
Apr 10, 2009 | LeapFrog Leapster 2 Learning System
Leapster 2 broken screen
We had a similar problem leapster turned on but would not let us chose a name for sign in. We held down the ? button when switching on then wen tthrough the stylus calibration and re-bootted. All started working again. Hope this helps
Jan 10, 2009 | LeapFrog Leapster Electronic Book:...
Leapster can't read input
You need calibration
Touch Screen Calibration is as:
1.) Ensure that a cartridge is NOT inserted.
2.) Hold down the Hint (’?') button while turning the unit on.
3.) When the LEAPSTER menu screen appears, press the ‘A’ button.
4.) Touch each of the crosshairs that appear with the stylus.
5.) Restart the unit.
Dec 25, 2008 | LeapFrog Leapster Electronic Book:...
Leapster not recognizing the pen??
Restart machine
Nov 25, 2008 | LeapFrog Leapster Electronic Book:...
Leapster with broken pen
My daughter did the same thing to the tip of her Leapster 2 stylus. I called Leap Frog at 1-800-701-5327 and was able to order a replacement stylus directly from them on credit card for $5.00 shipped.
I also took her old stylus and sanded the broken tip down with 100 grit and then 220 grit sandpaper to get rid of the sharp, cracked point and it works just fine. I figure I'll keep the sanded one as a spare in case she does something silly with it again.
Jul 27, 2008 | LeapFrog Leapster Electronic Book:...
Leapster Learning System Logo
1,048 people viewed this question
Top Leapster Toys Experts
thegtw
Michael Vincent Cruz
Dennis Crouse
Are you a Leapster Toy Expert? Answer questions, earn points and help others
