Question about Refrigerators
The temperature in the fridge is too high aprox 11C but freezer is working OK
  • 4,059 Answers
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Posted on Oct 02, 2009
  • ddalzell84 Nov 23, 2010
    when this vent is open and triggers are depressed should u feel air transferring over from the freezer to fridge? fridge worked fine last week nice and cold now its in the danger zone 51f not good...
Miele KFN8993SDN Freezer temperature to high
Temperature displays
During normal operation, the temperature display shows the temperature in the middle of the refrigerator section and the temperature in the warmest part of the freezer section.
Aug 20, 2015 | Miele KFN12923 SD-2 Stainless Steel 369 l...
Rm4400 freezer working fridge not
move temp sensor that's mounted in coils down or let hang if same replace sensor
Jan 19, 2014 | Dometic Refrigerators
Beko CDA751FW/1 mostly on all the time - fridge 4 degC, freezer -30degC
there is no thermostat in cda751fw/1. apparently the pcb controls fridge temperature. which pcb, the main one or the one behind the temp dial I dont know which.
Apr 11, 2012 | Refrigerators
Fridge not cold frezer working ok
check the temperature settings in the fridge.
Feb 19, 2010 | Freezers
Faulty Freezer & Fridge
You have a defrost or temperature control issue or both. I will be back soon with photos and solutions. Thanks, Sea Breeze
Jul 13, 2009 | LG LRTBC1825T Top Freezer Refrigerator
Hi I've got fridge/freezer Whirlpool ARC7470. The fridge stopped working despite the freezer being ok. If I want to make it work a have to turn the thermostat wheel to "off" (even the fridge...
hey hunnie,
well you have set the thermostat wheel to the minimum temperature due to that your fridge will work till some extent after that it will automatically off so set the thermostat wheel to the high level
Sep 03, 2008 | Refrigerators
My frost free fridge freezer is set to high and still only gets down to about 11c and is usually at about 15c
You may have ice blocking the opening in which your freezer air passes through to go into there refrigerator .Try this,unplug the refrigerator for for at least 14 hours ,that should allow all of the ice to melt.Then ,plug it back in and take the temperature of both freezer and fresh food sides.You should find a temperature that will hold at or very close to Zero degrees in your freezer side.Start with this for your first step in repairing this and get back to me.
May 12, 2008 | Refrigerators
Frigidaire frf170ff alarm keeps going off, but has been no powercut and door has not been open but temperature will not go down to -18 oc it is at -9 oc and superfreezer does not alter temperature!
We have same problem. Its stored in a intergal garage had it since Jan 08, no problem until now. The last 3-4 days its been beeping the alarm, temperature according to the display varies between -9c and 11c/ Despite doing the fast freeze over night temperature hardly improved at all around -1c. to 12c. Its quiet a cold night tonight 14c in garage yet temperature of freezer remains at -11c
May 05, 2008 | Refrigerators
ARISTON FRIDGE FREEZER MBA 3842C PROBLEM
It should work the same as before. Does the compressor get really hot after running a while? If so it could be low on charge, or there could be a restriction inside the refrigeration system. Either way a professional would have to look at it.
Jan 07, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
FRIDGE/FREEZER MODEL: SR42NMB Multi Frost
You have a clogged defrost drain tube. best way is to thaw unit out. Your vents are being blocked so no air flow is pushed down.
Jan 05, 2008 | Refrigerators
Refrigerators Logo
874 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
