Question about Maytag MER6772 Gemini Electric Kitchen Range
Maytag 6770AAB dual burner will only go hot and temperature will not adjust
    President:
  • 1,304 Answers
You have a bad sensor on that burner,
do not let them charge you for the whole burner
the sensor can be replace as an indiviual item
Posted on Oct 03, 2009
I have a Better Chef model # IM-335 and the heating element just went bad. Is there a place I can get a new one?
apparently not. They are $31 new.
1500W Burners Hot Plates eBay
better chef model im 335 spare parts Google Search
Better Chef IM-302DB Stainless Steel Dual Electric Burner - Free ...
https://www.overstock.ca > ... > Kitchen Appliances > Cooktops, Burners, & Hot Plates
Rating: 4.5 - ‎17 reviews - ‎US$38.75 - ‎In stock
Shop for Better Chef IM-302DB Stainless Steel Dual Electric Burner. ... Stainless steel brush finish; Dual self-cleaning coiled heating plate; Safety on/off switch; Adjustable temperature thermostat control; Indicator ... Model Number, IM-302DB.Missing: 335
Better Chef Dual-element Electric Countertop Range - Free Shipping ...
https://www.overstock.ca > ... > Kitchen Appliances > Cooktops, Burners, & Hot Plates Rating: 4.4 - ‎30 reviews - ‎US$30.99 - ‎In stock
Shop for Better Chef Dual-element Electric Countertop Range. Free Shipping on ... This countertop range features 1,500-watts of total power and adjustable heating controls. 1500-watts total ... Model Number, IM-306DB. Country of Origin ...Missing: 335
Jun 04, 2018 | Dryers
My Maytag Gas Oven MGR5750ADW preheats on certain temperatures and not others. For example it wont preheat at 350 degrees but will preheat at 380 degrees. At 350 we smell gas.
What you have is an ignition problem get this corrected before you experience a delayed ignition, the hot surface ignitor pulls enough amps 3-3.4 to power up and open the gas valve but ignition did not take place reason you smell gas don't know how old unit is ignitor may be weak good on draws 3-3.5 amps burner ports may be dirty or the bracket that the ignitor mounts too may have bowed away from the burner
Jan 29, 2015 | Maytag MGR5750 Gas Kitchen Range
Maytag washer will not get warm
1) the temperature coming from your house determine how is the temperature. You can get hot, cold or mix of hot and cold available to your machine.If the water is too cold affect the machine,and if is too hot, the warm temperature colapse.
If you live Northern are, unless you adjust the cold and hot verywell affect the temperatur of your machine.WARM water is better in summer and Colder during the winter.
God bless you
Jun 21, 2012 | Maytag Washing Machines
Grill/griddle burner not getting hot enough.
are you able to adjust the flame ? has it always been this way?
Dec 29, 2017 | Jenn-Air JDS9860A Dual Fuel (Electric and...
Basically my gas oven is not heating up properly, the temperature is not hot at all, and food is not getting cooked properly
this is a milti burner unit / and sounds like the ignitors or weak / look below the oven door edge for a glow if orange there bad they need to be white hot .. burners may come on but not all the time .. ****
Dec 05, 2009 | Viking 48" 6 Burner, Griddle Professional...
Jennair model # JDS9865BDP Dual-Fuel Modular slide-in Range Pro Style Burners are too hot to do regular moderate cooking. Wife says the left side burners (where grill goes)can't be adjusted low enough to...
pull off your selector knob and shine a flashlight down the shaft, depending on your model, you may have the adjustable mmodel
at the bottom of the selector shaft, you may see a flat head screw adijudt it at ver small increments
i believ a 1/4 turn in should turn your flame down quite a bit
hope thsi helps
Nov 02, 2009 | Jenn-Air JDS9865BDP Stainless Steel Dual...
Maytag oven will not get hot
the ignitor is bad, the ignitor opens the valve when there is enough amperage. the ignitor isn't pulling enough to fully open it
Sep 08, 2009 | Maytag MGR5870 Gas Kitchen Range
Oven won't stay hot
You probably need to replace the baking igniter, (Igniter,bake burner
Part Number: AP4102011 made by MAYTAG
Feb 12, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Gas range top burners too hot
Get the installation manual for your range, and find the part on adjusting the low heat for the burners. On my Whirlpool, I found there is an adjustment screw inside the control knob shaft of each burner. The manual says turn the burner on low, remove the knob, then turn this screw until the flames are 1/4" high. Super-easy, it took me 5 minutes to do. I am sure all ranges have similar adjustments, might be in different locations - check the manual.
Feb 05, 2008 | Kitchen Ranges
Maytag MER6772 Gemini Electric Kitchen Range Logo
73 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
