Question about Dell Inspiron 6400 Notebook
We Dont Kno!!!
Hey Yall Im Confussed We Have One That We Purchased In 2005 And The Battery Slowly Went Dead And Want Charge Back Up So Is It The Battery Or The Mother Board? Any Solutiong Hit Me Up (706)986-9024
    Problem Solver:
  • 14 Answers
To check the battery charge, press and release the status button on the battery charge gauge to illuminate the charge level lights. Each light represents approximately 20 percent of the total battery charge. For example, if four of the lights are on, the battery has 80 percent of its charge remaining. If no lights appear, the battery has no charge
To check the battery health, press and hold the status button on the battery gauge to illuminat the level lights. If it has no light theres about 100% - 80% charge performance, one led light 79-75%, two led lights 74-70 %, three led lights 69-65 %, four led lights 64-60 % and five led lights 59- less% charge performance. If this is the case, you need to purchase the battery.
If the battery charge and health is ok, then the failure would be on the motherboard
Posted on Oct 02, 2009
  • 93 Answers
Hi frnd..
Normally battery has one year life .. so its better to Purchase a new battery from dell.. try calling dell tech support and get the battery replaced...
take care...
  • Dell Master
  • 32,281 Answers
Check your mains adapter plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop power it up then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. I suggest you get a quote first.
My CDI burnt out, the Rev counter went mad, CDI smoked, nd bike stopped with blown front & rear bulbs and a dead flat battery. I replaced all the above. a month later it's happened again, smoking CDI,...
Your regulator may have went bad. The regulator converts the ac charge produced from the alternator into the DC volts required to charge the battery. When they fail they can put out 5 times what the battery needs. Depending on your bike the regulator may be separate from the alternator. You should pick up a cheap volt meter. Once you get the bike running, use the volt meter to see what the bike is charging at. If you find the charge is above 14.8 V or that the voltage fluctuates to the extreme, ex. 14.2v, 8.2v, 12.7v all within a few seconds. then the regulator is probable. Another problem I have found is that the ground wire for wiring harness does not get hooked back up. This is a smaller ground wire that may plug into the main ground cable or sometimes is a separate lead connected to the battery. This will fry an entire system.
Oct 30, 2013 | Honda Motorcycles
AUDIO FUSE
you have a wire Conn so were from the switch to the battery
Apr 22, 2017 | 2005 Kia Sorento
I bought a car with a kenwood kvt 715dvd the battery went dead an now its asking for a password but i dont kno it how would i reset my kenwood kvt 715dvd/cd player
Did you look online or do you have a owners manuel? There is usually a factory set password such as 1-2-3-4 etc, unless you purchased it second hand and the previous owner custom set - then you have to contact the previous owner or Kenwood. Most people dont change the factory passwords. TRY KCAR (5227 ON A KEYPAD) uf that doesnt work read the forum post on: ecoustic.com. Good Luck
Apr 15, 2011 | Kenwood KVT-617DVD Car DVD Player
Battery was dead and tried to start after charging, starter solenoid clicked and engine turn over slowly without starting. Now engine will not turn over. Battery is charged have power to all accessories...
okay,think of it this way,you tried starting,engine turned slowly,no start.....then you charged battery,engine wont turn over(although accessories work)WHY WAS THE BATTERY DEAD TO START WITH.Try a jump start(another battery)if it starts then you know what im going to say.....
Nov 06, 2010 | 2005 Ford Explorer
My 2005 altima 3.5 just went complelely dead over night.
Fit a new battery ,5 yrs you have done well
Aug 22, 2009 | 2005 Nissan Altima
Brand new motorazr V3s. draing batteries. only 3 hours of use
HEY THOSE CHINESE CHARGER ARE NOT GOOD.. THEY SUM HOW NEVER CHARGE THE BATTERY PROPERLY ND THE BACKUP IS LESS. CHARGE USING UR MOTOROLA CHARGER ND IF U STILL EXPERIENCE PROBLEM THEN U BETTER GO TO MOTOROLA
Aug 16, 2009 | Motorola Mobility RAZR V3
Battery going dead
The battery regulator may not be functioning properly. At times it will send a charge to the battery and at times it won't. This is normal, but if it is not allowing the battery to receive current when it should then there is a problem. Another possibility is a loose connection in the wiring. I would check the connections first.
Aug 12, 2009 | 2005 Honda VTX 1300 C
Cell phone went dead and wont recharge
sometimes when battery becomes full discharged it takes time like hours to come up but over night charge will do it , if it dont check ur battery first if it is ok then ur set is dead there might be software issue seek help from support in ur country
Feb 19, 2009 | HTC Touch P3450 Smartphone
2005 Honda Civic wont start. Just makes a clicking sound
This sounds like a starter problem, does it click when you hit the key? are the battery cables ok, not corroded?
Nov 06, 2008 | 2005 Honda Civic
Dell Inspiron 6400 Notebook Logo
247 people viewed this question
Alun Cox
