Question about Dynex 6' 3.5mm Stereo Extension Cable
I just bought the dynex stereo audio cable for mp3 and their is a faint hiss in the background, but more annoying is the volume level. I have the car radio and my ipod turned up to the max and its not very loud. If you're on the interstate you can't really hear it. Should that be the case. The radio on its own is much louder.
    President:
  • 570 Answers
Any 1/8" cable will do. You can get them from anywhere from RadioShack to WalMart. I believe this cable has some sort of damage or is defective. Return it asap because hissing should not happen. I worked at RadioShack over a year, this should do the trick.
Posted on Oct 02, 2009
I have to turn the volume up all the way just to hear it. Even then theres a hissing sound. How do I make it clearer.
turn the volume down on the remotes all the way, then adjust with your hand on the actual tv, or if you are playing a dvd, might have the audio video cables wrong
Mar 30, 2015 | Dynex 32 in. LCD Flat-Panel HDTV
I have a Harmon Kardon HK 3370 Stereo Receiver and a Samsung LCD LE40C530F1W. When I connect the stereo Aux jack to the LCD Audio jacks ( red and white rf cables ) I get no sound out via the receiver.
Obviously make sure your stereo mode selector is set to AUX and the volume on the stereo is turned up at least a little when you test it.
If you still have no luck then try increasing the volume on the TV as well. You may have it set so that the level of the audio signal leaving the rear output connectors on the TV varies with the TV volume. That way if your TV volume was turned down or muted when you tested it, then you would not hear anything coming through your stereo.
There should be a setting in the AUDIO OPTIONS menu of your TV where you can switch between a VARIABLE AUDIO OUTPUT and a FIXED AUDIO OUTPUT level.
With the FIXED audio output level, you control the volume of the TV audio coming through the stereo speakers with the stereo remote only.
Otherwise it should work.
Good luck.
Jul 16, 2011 | Harman Kardon HK 3370 Receiver
I have a problem with hiss coming from the sound bar (ZBase 550 HSD) when using my digital cable box. It is not an issue with PS3 etc. I have the sound on the cable box turned to max, but I still hear a...
Hello ZVOX Owner,
The hiss you hear is generated by the analog audio output of the cable box. The best way to eliminate this hiss to use the digital output of the cable box. The preferred way to do this is to connect the digital audio output of both your cable box and your PS3 to the your TV (I presume your TV has two digital audio inputs.)
Your TV has a digital audio output. You should connect the digital audio output of your TV to the digital input of the ZVOX.
This should reduce or eliminate the hiss and provide convenient video source selection via the TV.
From Fred P. at www.zvoxaudio.com
fred@zvoxaudio.com
Jan 27, 2011 | ZVOX ZBase 550 HSD Lowprofile SoundBase...
Just bought a dynex 24 inch and it only plays in mono, no stereo audio . no able to switch to stereo
A lot of time the stereo/mono is automatic. Try using a DVD player instead of your regular cable and see if it changes.
Apr 20, 2010 | Dynex 24" Standard-Definition Digital TV
We have the stereo hooked up to the dynex 42'' tv, as we did our other tv, we can not mute the complete sound and also sometimes we cant turn the volume up and down whats going on?
Since you have it hooked up to the stereo system, you need to go to on screen audio set up and turn off the TV built-in speakers (you will be listening the TV sound through your stereo system speakers), then go to the audio output set up and set it to 'variable' so the audio output of the TV's RCA audio out put will vary with the volume control of the TV (not all TV will alow this function), you will need to set the stereo volume to certain level (around 9~10 O'clock setting) since the sound coming from the TV will be controlled by the TV remote volume control. You can otherwise set the TV output to be at 'fixed' level, which means the sound output of the TV will not be controlled by the TV remote volume control, you will use the stereo remote volume control to adjust the sound level instead. I hope this is clear to you.
Nov 19, 2009 | Dynex DX-L42-10A 42 in. LCD TV
No audio from mini input jack on Pioneer SupertunerIIID 50w x4
The mini jack was not designed to work in the manner in which you are trying to use it. The stereo output is always going to be at a higher output rate than the amplifier output. if you want to use an MP3 player with your stereo you will have to purchase a head unit with a built-in MP3 input or deal with the lower rate of volume.
Aug 13, 2009 | Pioneer DEH-P690UB CD Player
When i try to record a vhs tape from leadtek pvr tv card, i can record the video, but the audio makes a loud hissing noise, although i can hear the original soundtrack very faintly in the background. how...
in your line-in socket it is grounded try to use a new cord connecting to PC n your camera,.
at this time the ground of your line-in cord socket it short, and the volume of your line-in put it in 50%...
Jun 20, 2009 | Microsoft Windows XP Professional
No Sound Issues
Hello!
Try the audio out. Run the audio to a receiver to see if the audio is there. If it is, then I'd leave it hooked up to the receiver and save yourself some money. If there is not any low level audio out then I'd fix the set. The only Sony set I've ever seen that was not worth fixing was a 32" model from the early 1990's that had bad picture tubes after only 5 years. I am a Sony factory trained tech. Good Luck!
barneyluc
Oct 13, 2008 | Sony KV-32FS13 TV
My panasonic sa-ak58 home stereo, it turns on o.k. but after a couple of seconds i loose audio, on all speakers, but the led screen shows normal volume level, no matter if is high or low on volume.
go on the back of the stereo take a aux cable and hook to the back and touch the end were it plugs in to the mp3 r what ever you use and if its still making the nosie your amps fried
Aug 28, 2008 | Panasonic Audio Players & Recorders
Hissing
Sounds like you're connected to a cable, satellite, or DVR box ("set top box"). Many times these units have their own volume controls.
Try reducing the volume of the set top box to 80% or below, preferrably somewhere between 50% and 70%. When the volume is set too high, the background noise will be amplified as well, which then gets amplified by your receiver and becomes audible.
You will need to adjust the volume level of your receiver to compensate for the lower input level, and keep in mind that some channels may have more noise than others. It'll be a balance between having all your input sources are relatively-similar input levels (so you don't have to adjust the volume a lot when switching between sources) and how much noise you can hear or ignore.
Apr 06, 2008 | Denon AVR-2801 Receiver
Dynex 6' 3.5mm Stereo Extension Cable Logo
81 people viewed this question
Top Dynex Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Dynex Audio Player and Recorder Expert? Answer questions, earn points and help others
