Question about Bosch SGV56A13 Built-in Dishwasher
Fitting a Bosch SGV46M43Q integrated dishwasher
How do I remove an old one and fit the Bosch?
4 Suggested Answers
  • 10865 Answers
SOURCE: remove the top from free-standing-dishwasher bosch sgs43c12
hello martin - yes you can remove the top. And no, it will not harm the dishwasher funcion.
Posted on Aug 02, 2009
SOURCE: My Bosch integrated Dishwasher SGV5303 has stopped filling with water. An Aquastop unit is fitted but the filter in that is not dirty/blocked. Any ideas? Regards, Bob
The same thing happened to mine in March 2010
Posted on Apr 06, 2010
  • 1140 Answers
SOURCE: Hello there, I have a Bosch
Hello Deepak,
You can definitely fix this yourself, but I'm not entirely sure from your description which part is "dropping off". It may be a simple fix where something needs to be clipped back into place or you may need to replace something. Please can you take a look at the images below and identify which part you are having trouble with.
Below is the back of the upper spray arm which clips on to the upper rack. It has a grey plastic cover behind which is a large white plastic washer / gasket. The washer simply slots in to the back of the spray arm and the grey cover clips in over the top.
Your description suggests the grey plastic cover and/or the white washer are dropping off. If the grey plastic cover is missing, it may have fallen into the bottom of the washer under the lower rack, in which case you should be able to find it and clip it back on. If it's missing or wont clip back on, you will need to replace the upper spray arm as the cover and washer are not available separately.
This is the water delivery tube which clips to the back wall of the washing compartment. There is a metal clip which secures the tube to the wall. The open hole and one of the spigots slot in to the two holes in the back of the upper spray arm above. The spigot used depends on which height setting the upper rack is on.
Basically, everything simply clips together. If nothing is broken, you should be able to fix this at no cost by simply clipping the offending part back into place.
Hope this helps. If you need further assistance or help locating replacement parts, please let me know what needs to be replaced. Nearly all Bosch parts are available and in stock direct from Bosch.
Posted on Apr 13, 2011
  • 37 Answers
SOURCE: we have a bosch dishwasher
If the supply line is leaking it could be a 3/8 supply line maybe the rubber washer built in the line is shot try replacing the supply line.they are about 15.00 at home not over tighten the new line you could damage it.some times people cross the thread types on these connection you have pipe thread and compression threads that is the best way to explain it I know of.Just make sure you pay attention to the threads.
Posted on Apr 24, 2011
0 characters
1 Points
Dimensions for tecnik 795/2
This dishwasher was made for tecnik (moben/kitchens direct) by bosch. Any Bosch, Siemens or Neff fully integrated 600mm dishwasher will replace this machine.
Apr 08, 2013 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
How do i fit smeg integrated smeg dishwasher
Not sure I understand the question. Are you asking how you fit your new dishwasher into the old dishwasher's hole, or are you asking how you get the actual measurements of the dishwasher because you're building a new set of cabinets and need to build it to fit?
Sep 02, 2012 | Smeg Dishwashers
Water not draining from the machine
If it IS the pump, it’s often because some relatively minor item (piece of cocktail stick/bit of nutshell/etc) has found its way past the filters and is blocking the blades of the pump. It is relatively simple to remove the inlet hose to the pump and clear the blockage (a pair of grips to pinch and remove the retaining clip, then the hose will slide off the fitting on the pump). I did this several times on my previous (Hotpoint) machine – and suspect it is no harder on the Bosch (which I now have). If that doesn’t work, you are half-way to replacing the pump, which is not a difficult DIY job and I’m surprised any competent professional repair man wanted to write off a machine where the pump had failed. A new pump should cost around £40-£50 – less than a quarter of the cost of a new machine. DIY fitting would maybe take a couple of hours; a pro ought to do it in less than an hour.
Mar 08, 2009 | Bosch 24 in. SGS43C12 Classixx...
Fitting a new front panel to the NEFF 54432 integrated dishwasher
My Neff integrated dishwasher has two holding screws in the top corners and then two hidden screms half way down the side behind plastic covers. Loosen these side screws, remove the top two corner screws and then the door cover/panel should lift out of two lugs at the bottom.
Aug 13, 2008 | Neff 24 in. S5443X2 Built-in Dishwasher
Bosch dishwaasher installation
I have overcome the problem by fitting a old style hose fitting (non threaded taps) for garden hoses (rubber end with built in clamp)and clamped it on to the hose and then onto the drain pipe. Available Bunnings for $10.00
Jun 28, 2008 | Bosch 24 in. SGS43C12 Classixx...
Bought the display unit and water will not work.
hi there the low humming noise that you are getting sounds like the fill valve, this could be due to you perhaps not turning the water back on after fitting the new dishwasher or the fill hose being kinked when the dishwasher was put back ,hope this is of some help to you.
Dec 02, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Integrated dishwasher door fitting
open the front door. On each side of the inside of the door are various long screws, unscrew these and the old door will fall off. discard the old door and follow the same steps in reverse to put the new door on. It took me 10 mins to do. Hope this helps
Apr 12, 2007 | AEG 23 in. Favorit 50750Vi Built-in...
Bosch SGV56A13 Built-in Dishwasher Logo
53 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
prem mathew
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
