Question about Hatco Kitchen Appliances - Others
Can I put a higher watt heat tube in my TQ-10 converyer toaster
    Scholar:
  • 68 Answers
Your toaster is rated at 1800watts which is the power rating.
Your toaster is rated at 15amps which is the current rating.
Your toaster is rated at 120v which is the voltage rating.
Electrical Load,Power Rating and Current Drawn through the Main Supply is Calculated By: Power = Amps x Volts
1800=15x120=.........1800w.
Manufactures work out what size of cable and protectio to incorporate by using this design principle.
If you try to increase the bulb size it will alter everything and the internal wiring was not designed to take this extra load.
So, NO...
Posted on Oct 06, 2009
Model TQ-800H gets toohot and shuts off.
i've found this to be a common problem.... typically, people will clean out the crumb tray at the bottom of the toaster, whilst other crumb bits remain elsewhere inside the toaster, especially close to the heating elements, and alot of newer models today have a safety sensor. try giving it a good thorough cleaning and visual inspection to rule out a little excess building getting in your way...literally. lol. hope this helps
May 09, 2016 | Hatco Kitchen Appliances - Others
Breville bov800xl wont turn on. Reset option?.
If the screen turns on and looks like it's working but there is no heat, then the problem is the thermal fuse. It takes reassembly and a $5 replacement fuse. I replaced mine with one of the same specifications and it lasted a month. I replaced it again with one that trips at a 10 degrees higher setting and it's been good for a couple of years now.
Feb 25, 2015 | Breville BOV800XL 1800 Watts Toaster Oven...
HEATING ELEMENTS
The heating elements are inside on the top and bottom
Jun 08, 2013 | Bella Cucina 13049 1500 Watts Toaster Oven...
How many watts does a toaster use?
The average toaster uses around 1500 watts of power.
Jul 15, 2012 | Franklin Machine Products DIAL, THERMOSTAT...
One of the knobs cracked in half- I believe its from the heat, how can I replace it?
Here is an address to put in the address bar that will bring up a list of places that carry parts. The easy thing to do will be to copy&paste it in.
netshoppers.com/search/index.php?phrase=oven+parts&uid=d5d00793c96dccbcaa9b5f3ca3d412cd&kuid=4c4a6ef184c15b7eeffee322a7d94921&src=7s
<a href="http://www.toasterandconvectionovens.com">ToasterandConvectionOvens.com</a>
Feb 02, 2011 | Euro-Pro TO160L 1380 Watts Toaster Oven...
My toaster oven stopped heating all together.
your heating element has gone bad or there is some bad wiring in the oven itself
to check open up the toaster oven and look at the wires coming from the heating elements inside to the timer on the front panel if there is no bad wiring then the heating elements are bad and the toaster oven needs to be replaced
Jan 02, 2011 | DeLonghi XR640 Retro 1500 Watts Toaster...
Bottom heating element warped then stopped working
can you get in to replace the element?then do so if you can it is easy just look how it was put in as you take it out to replace it!
Sep 28, 2010 | DeLonghi AD699 Airstream Digital 1500...
Toastmaster Toaster Oven 357 is not heating when door is closed?
Mine just broke too - it won't heat - everything else works - lights, timer ect. but no heat can't cook
without it - love my oven - any solutions ( I guess it's the heating element ) Hope I can get a new one.
Aug 29, 2009 | Toastmaster 357S Cool Wall 1400 Watts...
Lower heating eliments don't heat or glow. Only top ones work
The elements are not orderable, but you can call Cuisinart with your serial number - the product has a 3-year warranty, and that is definitely a defect - will they glow if you put them on Toaster setting?
-Tha Mp3 Doctor
Aug 03, 2008 | Cuisinart TOB-175 1500 Watts Toaster Oven...
Kitchen Appliances - Others Logo
103 people viewed this question
Top Hatco Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Hatco Kitchen Appliances - Other Expert? Answer questions, earn points and help others
