Question about Xerox WorkCentre XD125F All-In-One Laser Printer
Help When i turn on the printer there is a grinding noise close to the fuser... and i also get an error message on the lcd it say J1...What is it?
    Novelist:
  • 208 Answers
There is a gear on the end of the fuse that is bad.
Google a business called The Parts Drop.
You can order that part there, less then $20 from them. No I do not work for them LOL, But deal with them often.
If you need instructions on how to replace that gear let me know.
It's not difficult to replace. And that is the problem. Guarantee it 100 percent.
J1 is a different issue. J1 means your out of toner.
Posted on Dec 20, 2007
  • Rick Kasper Dec 20, 2007
    so sorry. The gear is on the end of the FUSER not the fuse.
  • davecorrie Aug 04, 2010
    Is it the fuser drive gear? I have the same problem.
HP Color Laserjet 8550 - Loud grinding noise near fuser
Hi Harden,
Thats an issue with the fuser assembly,try to check the teflon condition/ teeth gear might have worn out.
Jan 30, 2014 | HP Color LaserJet 8550dn Printer
Making noise then displaying error asking to turn printer off
Just we cant judge reading the sound if we hear the sound we can say the fault, any how check fuser assembly seated properly or not? open side doors then observe where you are getting the sound..
Jan 30, 2012 | HP LaserJet 4600 Printer
Panasonic UF-9000 Laser Printer/ Fax, E04-01 Error Already Replaced Fuser Assy. for Grinding noise & broken fuser gear.
Hmm, that is still a fuser error for sure, was that the same error you had before you replaced the fuser assembly? You did replace the fuser itself with the assembly, correct?
Let me know
Tim
Sep 24, 2010 | Panasonic Panafax UF-9000 All-In-One Laser...
My HP m3035 printer is making noise in the toner cartridge compartment on the right grinding sounds. I changed the Toner, still amking the noise any ideas?
Open the rear door. Power on the printer. Watch and listen as the fuser rotates. Does the noise occur when the fuser rotates? if yes - replace it. If you still think it's coming from the toner, remove the toner, close the toner door. When the motors start turning the noise should be gone. Insert the toner and listen again
Jan 28, 2010 | HP LaserJet M3035 MFP Printer
The screen reads paper jam error, but there is no visible paper jam and when turned on a grinding noise occurs
Most likely, there is a paper jam in the fuser unit....which is stalling the fuser rollers, thus causing grinding noise (accordian or fan folded jam)
Oct 24, 2009 | Canon imageCLASS D320 Digital Copier
I called Dell about the same problem. They said it's a motor error. They had me turn off the printer and remove the transfer belt, fuser and all the toner and then turn the printer on and replace them one-by-one, closing the printer door each time to see what the message was.
The printer then began printing before seizing up and reporting the same error message. They ran me through some steps and we realised that I need a new fuser and/or fuser motor.
Try the above. Otherwise call Dell, they were very helpful.
Dec 01, 2008 | Office Equipment & Supplies
Brother HL2700CN Noisy fuser
Shortly after I poseted the problem. I went back and "tricked" the top cover switch into thinking the top cover was closed by pressing the cover sensor with a pen and then tried printing a page. I noticed that the grinding was happening as the printer was spinning the black toner cartridge. By replacing the cartridge this stopped the noise. It could very well have been any of the cartridges, so you may need to do some trial and error.
May 10, 2008 | Brother HL 2700CN Laser Printer
Error message - won't function.
Usually it is the gears in the fuser asm. One of them is cracked or imbedded with toner and grease. Open the right cover and remove the two screws holding the fuser in place. First remove the back cover and unplug the fuser cables.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Aug 25, 2007 | Sharp AL-1641CS Laser Digital Copier
Xerox WorkCentre XD125F All-In-One Laser Printer Logo
191 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
