Question about SVP DC-12D Digital Camera
Use batteries faster than anything. Can't get 2 or 3 pictures without killing batteries. Been this way since new.
Battery will not charge
Not much to go on with your description ;-]
Generally if a rechargeable battery will not charge or the charge does not last long you need to replace it. This is true for laptops or camera batteries and anything else. Very rarely is it a problem with the charging circuit.
Rechargeable batteries like Lithium Ions are good for about 500 charge cycles. If you dischagre it to zero all the time or leave it on the charger and never really use the battery you can kill them off quite a bit faster. You can make them last longer by never using more than a half charge. By charging only when needed, and by discharging it to zero about once a month. Then you can get 2-3 times the use out of the battery.
Sep 02, 2011 | Computers & Internet
Hi. I have a HP Compaq 6820S, Intel Pentium T7250, 2 Gb RAM, 160 Gb HDD, i have a problem, Laptop won't charge battery. I let the laptop in sleep mode, around 7 days, when i come back, battery was 0%,...
try a new battery yet? (brand new fresh)
sleep mode. so you want it to run for 7 days in sleep.
ive no idea how long this laptop runs in sleep
and hibernate is longer.
no idea at all.
you do know that the speed features are programmable
right?
including what chips do and do not go to sleep'
like USB ports, WIFI, and all wake on , features. like Ethernet chip.
and more.
why not just turn it off, and let the battery last longer..
this mode sleep kills batteries faster. way faster.
leave it plugged in all the time to the wall pack.
so the battery never drains unless you need to use it, on battery.
Jul 18, 2017 | HP Compaq 6820s Notebook
I got this camera a few years ago for Christmas and unfortunatley it is the worst camera I've ever had as far as battery life. I can take 2 or 3 pictures and then it shows low battery. I've replaced new...
It seems there is some where inside the camera leakage.. Are you using Li-ion rechargeable batteries or AA batteries For previously cameras, always comes with AA batteries, and most of the battery are with low capacity.
Jan 08, 2011 | Canon PowerShot A540 Digital Camera
I have sx100 camera. when i am using to take a picture with flash i cannot take the next picture immediately. some times it take more than 30 sec. without flash no prob. this is not a memory card problem.
It depends on your battery condition, flash capacitor will charge faster if battery is freshly recharged. Or battery has larger current capacity. You can shoot pictures with flash faster if its fill-in or closer in distance. Which means capacitor recharge is not totally depleted for each flash duration.
Aug 26, 2010 | Canon Cameras
How do I determine or - with 24 volts system/ I want to wire in the existing system to a new battery charger ith a different cinnection.
it is 24v and the best way to do it would be direct to the batteries but with a switch to isolate it from the scooter controlls when charging to prevent damage to the scooter also you do not want to charge faster than 2 amps or you will kill the battery life
Jun 30, 2010 | Elite Pride Go Go Traveller 3 Wheel
What is the proper technique for replacing batteries in the 2005 GMC Sierra 2500 HD 4WD Diesel pickup, without messing up the computer in the system?
disconnecting the batteries will not mess up the computer the only thing it will do is erase the kam which the computer will relearn within three times of driving, if you are worried about erasing the kam most diesels have more than one battery and they are usually connected so you can replace only one at a time and have no worries if the vehicle only has one battery they do sell power savers that you can plug into your cigarette liter and keep the computer "alive"
Sep 08, 2009 | 2005 GMC Sierra 2500HD 4WD
Help!
yes....but it would have to be alot......what kills starters faster than anything is dirty battery cables, and weak batterys,
Feb 11, 2009 | 1996 Nissan Maxima
Car will not start
yes...but it would have to be alot...what kills starters faster than anything is dirty battery cables, and weak batterys
Battery charge
Dave you are correct. You should never over-charge anything like a Roomba, Cel Phone, etc. That will kill a bettery very quickly.
Jan 11, 2009 | Roomba Robotic Floor Bagless Vacuum
SVP DC-12D Digital Camera Logo
18 people viewed this question
Top SVP Cameras Experts
Steve Sweetleaf
Steve Sweetleaf
Jaime Hernandez
Kazim ERGUNEY
Kazim ERGUNEY
Are you a SVP Camera Expert? Answer questions, earn points and help others
