Question about Garden
Erratic idle, goes up and down constantly
I have a homelite 160cc engine and the idle is erratic, going up and down constantly. It has only been used about three times. The carb is spotless. Any ideas?
  • 437 Answers
You may try mixing up some fresh fuel mixture at 40:1 ratio(3.2 oz 2 cycle oil to 1 gallon of gas). It sounds like old fuel mixture. The schools I have been to this year all manufacturers have told us gas over 30 days old is considered bad gas.
Posted on Oct 03, 2009
1994 Honda Civic DX I Replaced Idle Air Control Valve Because Idle Was Jumping Up And Down The New Valve Jumps And Down To And when i Disconnect The Valve Car Idles Fine ?
Erratic Idle On Civic - YouTube
? 0:53
https://www.youtube.com/watch?v=sEiTi5GAcrQ
Jan 29, 2010 - Uploaded by stikkyp
My 1994 Honda Civic SI has an erratic idle. It stays at 3000-3500rpm when started cold till it warms up then ...
High idle and constant up and down idle on my 94 civic ex? ' Yahoo ...
https://answers.yahoo.com/question/index?qid...
Oct 27, 2011 - Okay so im learning lots about Honda's, i have rebuilt motors and put them but i cant ... It has a constant up and down idle between 1200 and 2000 rpms. ...to a near stall for a fraction of a second, then jumps back up, like clockwork. ... No coil packs on your 1994, of course - just one coil and a distributor. Rpm jumping up and down at warm up 1k to 2k 97 honda prelude ...
Jan 11, 2014
why does my honda civic idle up and down?
Apr 22, 2010
1994 honda civic Idle problem?
Dec 17, 2009
rpm of my honda accord goes up and down when in park or ...
Mar 8, 2009
More results from answers.yahoo.com
Idle goes up and down! HELP! ' ClubCivic.com - Your Online Civic ...
www.clubcivic.com > ... > Engine Tech / Drivetrain
Jan 09, 2016 | Honda Cars & Trucks
2012 skidoo tundra 550f
water damage, short, wonky software. bleep bloop blorp
Mar 12, 2014 | Winter Sports
Idle goes up and down when aircon is on
This is pretty much normal as the AC engages and disengages. Though it should be subtle and not erratic. Is it causing your engine to stall? Does your AC work efficiently or is the air not real cold. It should output around 40 degrees. The compressor may be going out or it needs oil. When the AC turns on the car idle sensor should raise the idle so the AC does not drag the idle down too far. If you turn AC off and try pounding on the brake & turning the wheel violently at the same time (in park of course) if you still have an erratic idle it's not the compressor. It will probably be the IAC or a vacuum leak is suspect.
Jun 29, 2013 | 1995 Mitsubishi Lancer
REPLACED THE EGR VACUUM SOLENOID NOW IDLES RUFF AND RPM GO UP AND DOWN AT IDLE
It can be issue with IAC( idle air control valve) causing the problem.
There are many other possibilities causing these idle issues.Engine idles rough.There are few help links with solutions to troubleshoot such idle issues.
I suggest you refer the link below and follow its troubleshooting details:------Click the link below:-----Bad miss at idle? http://technoanswers.blogspot.com/2012/01/bad-miss-at-idle.html
Stumbling and stalling at idle after engine rebuild? http://schematicsdiagram.blogspot.in/2012/03/stumbling-and-stalling-at-idle-after.html
1999 Ford F-150 Idles rough and quits when gas pedal is pressed less? http://technoanswers.blogspot.in/2012/01/1999-ford-f-150-idles-rough-and-quits.html
--------- Engine stumbles coming off idle when warm?
http://repairhelpcenter.blogspot.com/2012/01/engine-stumbles-coming-off-idle-when.html
Erratic idle on car?
http://schematicsdiagram.blogspot.com/2011/12/erratic-idle-on-car.html
Cold start problem and vehicle shudder around 2500 to 3500 rpms
http://repairhelpcenter.blogspot.com/2012/10/cold-start-problem-and-vehicle-shudder.html
---------- Low idle when cold out side?
http://repairhelpcenter.blogspot.com/2011/12/low-idle-when-cold-out-side.html
GMC Sonoma Stalls and idles low http://technoanswers.blogspot.com/2012/10/gmc-sonoma-stalls-and-idles-low.html
GMC Idle Air Control (IAC) Valve Replacing?
http://schematicsdiagram.blogspot.com/2011/12/gmc-idle-air-control-iac-valve.html
1996 Camry intermittent engine failure while idle?
http://repairhelpcenter.blogspot.com/2011/10/1996-camry-intermittent-engine-failure.html
Engine quits at idle?
http://repairhelpcenter.blogspot.com/2011/10/engine-quits-at-idle.html
Car overheats and Air blows hot at idle?
http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
High Idle Problem
http://repairhelpcenter.blogspot.com/2012/10/high-idle-problem.html
While stop engine idles like cylinder missing?
http://schematicsdiagram.blogspot.com/2012/01/while-stop-engine-idles-like-cylinder.html
Idle flair is noticed on car? Rough idle? car will not idle? Erratic idle speed?
http://technoanswers.blogspot.in/2012/02/idle-flair-is-noticed-on-car-rough-idle.html
High rpm in neutral? Inconsistant high RPM in neutral?
http://technoanswers.blogspot.in/2012/02/high-rpm-in-neutral-inconsistant-high.html
Vehicle stumbling at idle and shows code 54?
http://schematicsdiagram.blogspot.in/2012/03/vehicle-stumbling-at-idle-and-shows.html
Rough idle, staling and Erratic shifting? http://technoanswers.blogspot.in/2012/03/rough-idlestaling-and-erratic-shifting.html
-----------While stop engine idles like cylinder missing? http://schematicsdiagram.blogspot.com/2012/01/while-stop-engine-idles-like-cylinder.html
---------These details will help.Thanks.
Nov 23, 2012 | 2001 Ford Escape
I have an 02 wrangler and the oil preasure goes down when Idling is that an oil pump going bad?
First we would need to know when this occurs. Asuming the oil level is at the full mark!. If the pressure goes up during acceleration and down at idle when engine is fully warmed up, then this is normal. An engine requires 10 psi of oil pressure per 1,000 rpm ( ex. 20 psi at 2,000 rpm, 25 psi at 2,500 rpm, and so on ) . If the gauge is moving back and forth erratically at idle , i would say the gauge is bad. If it drops to 0 while accelerating I would say your oil pump is bad. If from time to time it seems to work and other times it seems not to work, I would say the oil pressure sending unit for the gauge is bad. If the pump failed you would start to here a Knocking noise from the engine in a short period of time. Use the above scenario's to narrow down what it may be.
Oct 16, 2010 | 2002 Jeep Wrangler
Engine revs up at start up and idle goes up and down, after awhile it settles down but idle is erratic
try cleaning your idle air control valve. located on or around the trottle body.
Sep 30, 2009 | 2004 Dodge Ram 1500
Idle irratic
Here are some of the causes of surges, stalls at stops, slow idle speed, erratic idle speed, rough idle and engine hesitation (and other problems), it is in most cases the idle speed control air-bypass valve and or throttle valve and upper intake, these area's get full of gunk and combustion residue over the miles and cause idle issues (stalls, low idle) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake
Apr 11, 2009 | 2001 Chrysler PT Cruiser
Idle goes down when headlights turned on
Possible weak alternator output or weak battery.
Apr 01, 2009 | 1993 Toyota Corolla
My 1998 900S run fantastic until you come to a red light. While applying the brakes the engine seems to shudder (idle up and down). Now I have an automatic transmission so the idle should be constant...
try the following it usually cure s this kind of problem
Here is the most common cause of surges and stalls at stops and low erratic idle speed and rough idle, it is the idle speed control air-bypass valve and throttle valve (IAC for short), they get full of gunk over the miles and cause idle issues (stalls, low idle) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake
Mar 06, 2009 | Saab 900 Cars & Trucks
Runs erratically
The idle air valve (located below the throttle body) provides the control for constant idle speed. In order to set the correct air valve opening to achieve constant idle speed, the fuel injection control unit uses information from the air mass meter, throttle valve switch and the ignition control unit (RPM signal) to regulate the output current to the idle air valve. This means that the idle valve is not affected by air leaks or a jammed throttle valve.
Nov 03, 2008 | 1986 Volvo 740
Garden Logo
101 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
