Question about Lakewood (5500) Oil Filled Radiator Heater
I need a switch for lakewood model 7000a
The switch burnt out on my lakewood heater and need a new one and i need the product number for that can u help me
SOURCE: lakewood 7096 heater
Some of the newer models have a thermal fuse which may be blown. It doesn't look like a normal fuse at all. It is similar to a transistor in looks and should have continuity from one end to the other. It will be tied in to the incoming power cord inside the heater, and may be covered with rubber coating within the wire. It will look different when you notice it. Sometimes its too far down inside where the heat causes it to blow prematurely. The purpose is to cut the power to the unit in case it overheats. You can get one at radio shack for less than a couple of bucks. The older models don't normally have one, but I would suggest you put one in it if that's the case.
Posted on Jan 01, 2008
  • 4 Answers
SOURCE: I need the switch for Lakewood 7096 oil heater
This might be the switch,
Defond DRH-2415 15A 125VAC Lighted Dual Heater Switch
Posted on Jan 14, 2009
  • 744 Answers
SOURCE: need new electric cord for model 7000/a lakewood
Depending on handy you are, the power cords for heaters can be replaced, but may require soldering or other electrical and mechanical skills. You MUST replace the cord with one that has the same amperage and heat ratings.....that goes for the plug too.
Posted on Mar 19, 2009
Natemane
SOURCE: ROCKER SWITCH DIAGRAM
On the top of the switch (inside the heater) there is a common connection.....even though it looks as if it is connected (electrically), it isn't electrically affected by the switch; it's just used as a post. It's just the place where the striped wire connects to the "common" point for the heater coils (they are in a parallel). Also, while you're in there you might want to put some electrical grease on the exposed conductors.....mine had quite a bit of corrosion (which was the reason for the failure). I had to replace 3 of the female connectors.
Posted on Jan 01, 2010
  • 3 Answers
SOURCE: Lakewood space heater thermostat source
If it is a Ksd31 thermostat you need, you are in luck. I found what I needed for my model 5600/7 on ebay. The store Larksining sells the for as few as five/pkg in various temp. settings. I got 5 ea. in two temp settings for less than $11.00 USD with shipping from Hong Kong.
Posted on Jan 26, 2010
Model 7000a
Hmm I think you are talking about the exterior. Cover the controls with a sealed plastic bag then apply some kitchen cleaner with bleach to a damp cloth and avoid squeezing it on the appliance. Wearing rubber gloves helps avoid contact with the bleach. when finished leave foe 30 mins then wipe clean
Dec 05, 2013 | Lakewood Oil-Filled Electric Radiator...
Bad Odor on the Lakewood Oil Filled Electric Radiator Heater
Pull the 4 small screws from top & bottom of plastic cover (2 under plastic tab on top, pry off) and then check ALL connectors and all wires. Chances are one of the leads has been overheating and smoldering (mine burnt wire off on lower Thermal switch.) You may need a KDS 301themal switch matching the one in your heater. Google for sellers.
Jan 16, 2012 | Lakewood Oil-Filled Electric Radiator...
Lakewood radiator heater model number 5101. The heater just stopped working all of a sudden. The buttons still light up when switched on but there is no heating. please help as I dont have any other...
Sounds as if the element is burnt out or the tstat is broken. the tstat is the more common as they use very cheap ones. Unfortunately you can't get these. My suggestion is to buy a new one.
Jan 27, 2011 | Lakewood Oil-Filled Electric Radiator...
Model #70001A controll switch melted
you can go to this web site to purchase a new control board. You will need to test the heater element to make sure that it's not shorted to ground. If you need more help with this just respond to the e-mail you receive also be sure it is unplugged before testing and short out the end of the plug if it's not hard wired into the wall. here's the site.
http://www.officeworld.com/-/70001a-lakewood-heater
Jan 27, 2010 | Lakewood Heating & Cooling
Switch burned out on Lakewood radiator heater.
Hi, go to amazon.com and you can get a switch for the Lakewood model 905 heater.Best of luck,
Shastalaker7
Nov 24, 2009 | Lakewood 905 Radiator Heater
Lakewood (5500) Oil Filled Radiator Heater Logo
113 people viewed this question
Top Lakewood Heating & Cooling Experts
Mack Baxter
paulcarew
jdthefixer
Are you a Lakewood Heating and Cooling Expert? Answer questions, earn points and help others
