Oct 08, 2009
- Press [2nd][MEM][7:Reset][1:ALL RAM][2:RESET] [ENTER]
Memory cleared appears on screen.
If your angles are in degrees you should make sure calculator is configured correctly. Press [MODE] Here is what you see on my calculator.
Everything in white-on-black has been selected. If you work in radians, screen should be as above. But if you work indegrees, highlight degrees and press [ENTER]
You said above that you press [2nd] then the function. No. To calculate the trigonometric functions you enter them directly.
[TAN]35 [)] [ENTER] gives 0.7002075382. Do not forget the closing parenthesis.
[SIN] 180/3 [)] ENTER gives 0.8660254038. Do not forget )
[COS] [(-)] 57.065 [)] ENTER . The minus is the change sign next to the enter key. Do not forget the )
Hope it helps.
