Question about IBM ThinkPad 600 Notebook
I Have a IBM Thinkpad 600 and the error code comes up 00192 and then makes me set the time, and then reboots, what do I have to do to use my laptop
  • 104 Answers
Buy a new coms battery and install it the coms is not keeping time so wont boot
Posted on Oct 02, 2009
Error 00161 and 00163 on my IBM Thinkpad 770
Please find below the error on your laptop, i read it on other forum and it says that error 161 is a dead battery while 163 is a timer that was not been set properly.
161
(Dead battery.) 1. Go to Checking the Backup Battery
2. Backup battery.
3. System board.
163
(Time and date were not set.) 1. Set time and date.
2. System board.
Numeric error codes index - ThinkPad 600/E/X
hope it helps..
Aug 23, 2011 | Computers & Internet
What is error 00173, 00192, and 00163
Error 192 means a fan error, to test this measure the voltage of the backup battery. If the
voltage is not correct, replace the backup battery. Check the fan and the system board.
Error 163 means the time and date is not set, to set the time and date hit F1 when you see the IBM logo and set the time and date.
Error 173 means the configuration data is lost, to sort that select OK in the error screen and set the time and date.
In most case its the CMOS battery that's run low and need to be changed for a new one, so for the time being you will have to keep setting the time and date and it will boot to windows.
Good luck
Jun 15, 2009 | IBM Thinkpad 600 System Board Motherboard
IBM THINKPAD 600 - How to fix error codes 161 and 163
START WITH THE MACHINE OFF
HOLD and CONTINUE TO HOLD "F1"
WHILE STILL HOLDING "F1" TURN ON THE MACHINE
AND
This will go into bios, you'll get a green and white screen.
Set time and date there, save and exit.
Should work.
Mar 17, 2009 | IBM ThinkPad 600 Notebook
Numerical Error Code 161 and 163
have you tried doing it in BIOS? coz the battery causes that
Mar 17, 2009 | IBM ThinkPad 380ED
Starting ibm 600e
Hi there.
Errors 161, 192, 163.
All three of these errors are connected to the back up battery.
To resolve this problem:
1. open memory flap on base of laptop (small philips screwdriver required)
2. find the small connector with 1 black & 1 red wire coming from it.
3. disconnect above connector and gently pull the Red&black wires. The backup battery should just pull out from under the casing.
4. get replacement battery. Either
a. call IBM spares (07900 247 490 in UK) and ask for FRU:
02K6502. UK price is about £8 + £15 delivery + VAT.
b. if comfortable with soldering iron: Carefully open the packaging on the backup battery using a sharp knife.
Remove the solder tags from the battery (these are spot welded so need to be cut/broken off). Buy a new CR2025 battery from any computer shop, jeweler, or camera shop.
Using electrical tape, insulate all round edge of battery
Solder the leads onto the new battery - note polarity. Red wire to +, black wire to -.
Using more insulating tape, wrap battery so that all exposed metal is covered.
5. put new battery into laptop (reverse steps 1-3)
6. start up computer, error 192 has gone, but still shows 161, 163. Select OK.
7. reset date & time, and OK
8. when screen shows 'O / I' restart laptop using on/off switch at side.
Good luck and thanks for using FixYa!!
Mar 05, 2009 | IBM ThinkPad T21 Notebook
IBM ThinkPad 600E 2645 PC
the following data is from the hardware maintenance manual for the thinkpad 600 series and is readily available from http://www.lenovo.com/support
Symptom or error FRU or action, in
sequence
161
Dead battery.
1. Go to “Checking the
backup battery” on
page 12.
2. Backup battery.
3. System board.
163
2. System board.
173
Configuration data was lost.
1. Select OK in the error
screen; then set the
time and date.
2. Backup battery.
3. System board.
192
Fan error.
1. Go to “Testing the
computer” on
page 7.
2. Measure the voltage of
the voltage is not
backup battery.
3. Fan.
4. System board.
Oct 03, 2008 | IBM ThinkPad 600E 2645 Notebook
Open Questions:
IBM ThinkPad 600 Notebook Logo
126 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
