Question about Intel D845GBV (BOXD845GBVL) Motherboard
I have an Intel D845GBV Motherboard that suddenly stopped working
Hi, I have an Intel D845GBV that has been working fine for over 2 years now. Today, it simply will not start. I can power it on but I see nothing on the monitor and both the power light and the HDD light are on. I checked and replaced the memory, but that seemed to make no difference. I did the same with the video card, but that made no difference either. I tested the power supply and the hard drive on another computer and they are both fine. I finally decided to reflash my bios, I did, and my computer started and booted for a brief minute. After the process of flashing my bios was over, I restarted my computer, and it would not start again. I'm pretty sure the problem is from the motherboard since I've tested all the components on other computers and they work fine.I can't seem to find assistance on this motherboard anywhere since it is almost obsolete. Please help :(
sandrew
  • 2961 Answers
SOURCE: Intel Desktop Board D815EEA2
Leave the connection to graphics card in, and take the left side panel off the pc and on the motherboard, you will see either a terminal marked CLRCMOS,JBAT1, CLRRTC, RTC, this is the cmos clearing jumper to revert back to default and the need to reset the time and date. If it's JBAT1 3 pin terminal, the cap will need to be taken off pins 1-2 and put across pins 2-3 then back to pins 1-2. If it is one of the others and only a 2 pin terminal, use a jumper cap like the one on the back of your hard disk and cdrom drive and put it over the 2 pins. start up pc and you should get the screen a beep and it will say press f2 for cmos setup, correct the date and time and the bios should be reset to vga, so change to pci again.
Posted on Apr 18, 2007
SOURCE: Motherboard D945GCL Problem
i need for d945 gcr intel driver
Posted on Feb 14, 2008
SOURCE: no display on screen and solid amber light on pcs' power button
shitless
Posted on Jul 04, 2008
SOURCE: Intel d945gnt bios won't load when power up...
there might be problems with the ram you are using.. try your friend's ram in your computer. if it works without the problem you specified , go for replacing your ram. if the problem persists contact us back. thanks for using fix Ya!
Posted on May 26, 2009
  • 1019 Answers
SOURCE: Intel Desktop D845PEBT2 could not boot up
i,d suggest that the power cut may have been a surge or spike.
This May have blown your power pack, and caused possible motherboard Damage.
** Did you use the same lead for the PSU** and have you checked the (main fuse in the Plug ? )
If the monitor light remains orange, this is a possible graphics card fault, or driver that is not allowing the monitor to come out of standby mode. You could try installing a different graphics card, or swapping the monitor cable to the on-board graphics card if it has 1.
If none of the above works, assume the motherboard has suffered damage.
Mike @ Compurepair.
Posted on Jun 12, 2009
Windows 7 (or compatible) drivers for Intel D845GBV
Hello
Click Here to download the drivers for D845GBV
Please let me know if you have any further questions or concerns.
Thanks.
Apr 06, 2010 | Intel D845GBV (BOXD845GBVL) Motherboard
How to instal agp slot in intel Board d845GVFN
AGP graphics adapter is installed only to an AGP slots not on the PCI.pci-mb.jpg slots as shown. You should change your AGP to PCI type graphics adapter.
Hope it works,
geloaa
Oct 08, 2009 | Intel D845GBV (BOXD845GBVL) Motherboard
Sound driver intel D845GBV lost
i found the driver on intels website. it is here: http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProductID=825&DwnldID=12170&strOSs=45&OSFullName=Windows*%20XP%20Home%20Edition&lang=eng
this is the driver for 98 SE, 2000, XP home and XP pro. hope this helps
Jun 06, 2009 | Intel D845GBV (BOXD845GBVL) Motherboard
Suitable VGA for my Intel mother board D845GBV
U need to update ur VGA chipset driver as well as ur graphics deriver from http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=889
install & reboot. If still having problem then go to
http://downloadcenter.intel.com/Filter_Results.aspx?strTypes=all&ProductID=889&OSFullname=OS+Independent&lang=eng&strOSs=38
update ur BIOS version, but note this----BIOS upgradation is very risky task, because during update process power failure will result the abortion of ur motherboard. So do it with experts if u are a rookie.
Feb 21, 2009 | Intel Desktop Board D845GBV Motherboard
Audio vidoe formatting CD of D845GBV lost
you can get all the drivers you need for the motherboard here:
http://www.intel.com/design/motherbd/bv/bv_drive.htm
kind regards and please don't forget to rate us
Dec 09, 2008 | Intel D845GBV (BOXD845GBVL) Motherboard
Restarting computer frequently
yeah it is the generic problem of d845gbv, for boot setting change the motherboard battery.
Nov 08, 2008 | Intel D845GBV (BOXD845GBVL) Motherboard
Graphics card support to motherboard D845GBV
AGP 2.0 and 3.0 4x and 8x feed with the 1.5v spec. AGP 1.0 1x and 2x was fed at 3.3v. In short, you should be fine.
May 15, 2008 | Intel D845GBV (BOXD845GBVL) Motherboard
About graphics card
Your motherboard supports AGP graphics cards at 1x, 2x, and 4x speed only. You can find great prices on these cards here: http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010380048+1069609639&name=AGP+4X%2f8X
May 14, 2008 | Intel D845GBV (BOXD845GBVL) Motherboard
Intel D845GBV Motherboard RAM
You can use only DDR 266Mhz dimms maximum upto 2 GB. i.e. one DIMMS of 266Mhz of 2GB or two of 1GB each. For more details read bellow:
System Memory Features
  • The D845GBV board provide the following memory features:
  • Two DIMM sockets supporting 2.5 V (only) 184-pin 200/266 MHz Double Data Rate (DDR) SDRAM DIMMs with gold-plated contacts
    Unbuffered non-ECC DIMMs only
    Maximum total system memory: 2 GB; minimum total system memory: 64 MB
    Serial Presence Detect (SPD) DIMMs only
    Suspend to RAM
  • CAUTION:
    Do not use ECC DIMMs with the D845GBV board. Using ECC DIMMs could damage the Desktop Board.
For more details click here.
Thanks
Iqbal
Apr 01, 2008 | Intel D845GBV (BOXD845GBVL) Motherboard
Intel D845GBV (BOXD845GBVL) Motherboard Logo
113 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
