Question about GE (PSS26MSRSS) Side by Side Refrigerator
Frost building up in ice maker exit shoot and
Frost building up in ice maker bin exit and the shoot entrance inside the door
  • GE Master
  • 1,606 Answers
Look into the dispensor , and see if the door flap is closing , or letting warm air in which will cause the frost buildup . If not closing completely , remove the top cover on the freezer door hinge , and unplug the plug . This will remove power to the door . Use a small screwdriver , and insert under the freezer door dispensor control board , and pry outward . Remove the 3 plugs on the board . Next , remove the 4 screws holding the white dispensor cover , and slide outward . At the top right , you will see a solenoid and plunger , which control the door flap . Usually , this plunger rusts on the solenoid . Replace both , the solenoid and plunger ( come together in kit ) Pt # WR62X10055 . Re-assemble in reverse .
Posted on Oct 02, 2009
Ice dispenser freezes up and will not dispense ice. It freezes so that I cannot remove the bin.
Your door on the dispenser is not closing and sealing. Probably have corroded linkage and solenoid and/or curled door seal that is alowing cold air to escape from the freezer which causes frost to build up inside the ice shoot.
Mar 29, 2011 | Refrigerators
I have frost build up where ice comes out of ice maker. The frost then clogs the shoot in door.
sounds like the ice flapper door is stuck open. Pretty common for GE refrigs to have the ice door solonoid and plunger get all rusty and need replacement
Nov 01, 2009 | GE Profile PSW26P Stainless Steel Side by...
Shoot door (flap) for ice maker wont stay closed causing frost
the gear that pulls it closed is bad. some have small plungers instead of gears
Oct 28, 2009 | Refrigerators
FROST BUILD UP ON ICE STORAGE BIN AND INSIDE OF
Most times this is caused by the dispenser door not shutting all the way. This causes moist air to be drawn in through the opening and the moisture will freeze in that area and also cause the dispenser door to have even more problems closing. Check the door and get me your model number so I can list the parts that are most likely causing this, Thanks Sea Breeze
Oct 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker works, fills door but doesn't come out
You have a bad dispensor flap solenoid . Frost due to flap not closing completely and ice will catch in the shoot .
Jul 25, 2009 | Whirlpool GS6SHAXLS Side by Side...
Freezer keeps running
yes,you need to pull the front panel on the ice maker off to get to the solinoid that opens and closes the flap,with the flap vranked open you are letting cold air out and warm air in and that makes frost,if you don't want to try and fix it your self put a cloth towel in the chute to block the air lose and call an honest local appliance repair person-mike
Nov 15, 2008 | Whirlpool Refrigerators
Ge profile refrigerator ice maker
I have a GE Profile PSW26P Stainless Steel Side by Side refrigerator that makes plenty of ice but will not dipense when the lever is pushed. The dispenser makes not sound when engaged. What do you think the problem is.
Sep 28, 2008 | GE Profile PSW26P Stainless Steel Side by...
Frost build up on the ice bin
the ice door is not closing or not sealing .. maybe a broken spring or lever...you will need to replace that broken part..
Sep 13, 2008 | GE GSS20IEM Side by Side Refrigerator
Frost on icemaker door
Most likely the ice door is not closing properly.
Clean out the ice chute and look down it from the inside while you shine a flashlite up from the outside. If you see light around the door then it needs to be replaced or something is wrong with the mechanism.
Post back and let me know what you find.
Nov 21, 2007 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
394 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
