Question about Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDG5500AWW gas dryer ignites, then flame goes out
The dryer flame ignites -- it takes about 40 seconds -- then after the dryer flame starts, it goes out in about 1 minute....what could be wrong?
    President:
  • 1,714 Answers
The 'radiant sensor/ needs to be replaced. This sensor tells the system that the flame is lit and everything is good. Go to repairclinic.com
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg5500aww-%3d%3di2681&PartID=2681
Posted on Oct 02, 2009
Maytag Gas Neptune Dryer MDG5500AWW no heat
see this causes and fix it. God bless you
Dryer tumbles, but there is no heat
Sep 27, 2012 | Maytag Neptune MDE5500AY Electric Dryer
I have a neptune mdg5500aww dryer, goes on, glowing igniter... but does not turn on the gas... what is wrong
Their are 2 possible things wrong;
1) Does the igniter just stay on or does it glow and go off usually within 1 minute?..if the igniter just stays on and never goes off the FLAME SENSOR will be the problem
2) if the igniter does glow then go off but no flame..the coils that open the gas valve are bad
The part numbers are;
FALME SENSOR 338906
GAS VALVE COILS 279834
The parts could be ordered from your local appliance parts store or online at;
searspartsdirect.com
apdepot.com
partselect.com
apwanger.com
repairclinic.com
GENE..OldTech2332
Aug 30, 2011 | Maytag Neptune MDE5500AY Electric Dryer
My Maytag Neptune dryer model mdg5500aww has no heat when running . ignitor never gets red. there's gas to the unit and 110 volts. there really not much lint in there. is the problem the flame sensor?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 15, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Mdg5500aww lp gas dryer heating problem it fires once but dosent burn long clothes dont dry help
When a gas dryer starts and the burner does not stay lit more than one minute the flame sensor is not detecting the flame to as a by design safety feature the burner is automatically shut off. It is not sensing flame so it is shut off.
This is the most likely suspect. http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg5500aww-%3d%3di2681&PartID=2681
BEFORE you change this part make sure that the outside vent flapper and the ducting form the back of the dryer is free of lint. Disconnect the dryer vent and try it with nothing connected to the dryer. Also check around the lint filter area for lint especially in the bottom. If there is not a lint or ducting problem then by all means change the flame sensor.
Thanks for using FixYa!
Kelly
Mar 05, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Internal gas leak of Maytag MDG5500AWW
if the flame is not a clear blue,rather an orange/blue or orange, the gas is not being completely combusted, either the burner orfice tube needs cleaning or the air to gas ratio is off and needs more air intake and this can be adjusted also
Sep 30, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag MDG5500AWW gas dryer with inconsistent flame
the booster coil gets hot and stops working just replace all three and give me thumbs up...i get$60 for a house call
Aug 08, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Gas will not stay lit.
sounds like a bad coil
they are on top of the gas valve
Jul 03, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag dryer model # mdg5500aww sensor not working is just starts a 37 minutes
How do I lift the top panel of my Maytag Neptune dryer model MDG5500AWW?
Jan 13, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
1,115 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
