Question about Cameras
Need extra battery and charger for ge camera - Cameras
Battery charge
The GE X500 is a camera, not a battery charger. If you want to use rechargeable batteries then you must charge them outside the camera. Chargers for AA rechargeable batteries should be available at just about any department, electronics, or office-supply store.
Don't try to recharge nonrechargeable alkaline or lithium batteries.
Jan 19, 2014 | GE X500 Digital Camera
Battery power ac card optional
Proprietary? The GE A730 uses standard AA batteries. If you choose to use rechargeable batteries then you can charge them using any standard AA charger. Such chargers should be available at just about any department, electronics, or office-supply store.
Jan 13, 2014 | GE A730 Digital Camera
Should i leave my camera on the battery charger when i am not using it?
I recommend not leaving it on the charger, especially if unattended. Some chargers get pretty hot and in rare cases malfunction and catch fire. Better to be safe than sorry. I keep an extra battery charged in case I need it.
Oct 03, 2013 | Panasonic Lumix DMC-LZ7 Digital Camera
HOW TO CHARGE GE H1055 DIGITAL CAMERA
The H1055 isn't a battery charger. The camera should have come with a separate charger for the GB-40 battery pack.
Oct 22, 2012 | General Electric GE H1055 Digital Camera
My GE battery charger says its charging but after putting it back in the camera it hasnt charged
The battery sounds like it needs to be replaced, have the charger checked to be on the safe side.
Jun 10, 2012 | GE E1486TW Digital Camera
I Have A Nikon Coolpix s210 Camera And Everytime I Plug It In To Charge With The Wall Charger It Doesn't Work..But I Don't Have The Separate Battery Charger.Any Ideas Why This Happens?
HiIn order to check quick, you might need extra battery. In your neighbor some who has multimeter you get help from them. Or your local repair shop could help you easily.
Jun 02, 2011 | Nikon Cameras
My GE digital camera's battery charger (model E1055W) is not turning its light on and not charging. Where could I buy a new one?
You can get a replacement charger here: http://www.ebuybatteries.com/product/battery_chargers/GE/GE-GB-20-AC-charger.htm
Mar 13, 2011 | General Electric E1055W Digital Camera
I need a charger for my Samsung WB600. I somehow lost it. Still have the USB cable. Any suggestions?
The Samsung WB600 digital camera is also known as the Samsung HZ30W. (see the Samsung Product page.for accessories, manual, etc.)
pchpatti_5.pngpchpatti_6.png It uses the Samsung SLB11A Lithium Ion rechargeable battery. Several third-party compatiable chargers for this battery are available through retailers such as Amazon.com:
Add shipping costs for each.
An extra battery is usually a good idea, too.
Jan 22, 2011 | Cameras
MY BATTERY CHARGER IS NOT CHARGING THE BATTERY. THE LIGHT ON BATTERY CHARGER GOES OFF AFTER 3 SECONDS.
Replace the charger is what I would advise you to dofrom this point.
You could try another battery and see if that is not the issue first.
There is only 2 things wroung here 1. the battery 2. the charging unit.
Rule out charger by purchasing new battery if that does not work purchase charger. At least you will have a extra battery folating around.
Sep 29, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Ge cg515 vhs c camcorder
This camera is compatible with panasonic and universal batteries. 6 volts NiCd rechargeable with a dedicated charger.
Nov 27, 2007 | GE CG515 VHS-C Analog Camcorder
Cameras Logo
24 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
