Question about Briggs & Stratton Garden
Murray Ultra LT widebody 17.5 hp tuscumengine runs
Murray Ultra LT widebody 17.5 hp tecumseh engine runs pully does not turn
  • 472 Answers
WICH ONE IS NOT TURNING
Posted on Oct 02, 2009
I have a Murray 20 model 20213A with a Tecumseh engine. The lawnmower will start but it dies a few minutes later. What could cause this and where can I get a manual for this model lawnmower?
Use high test fuel without ethanol, and
Murray 22" Lawn Mower - Carburetor Cleaning, Nasty ...
? 7:33
www.youtube.com/watch?v=_dzcDZUh1MY
May 10, 2013 - Uploaded by mountainbikekayak But here is the link for the start up of this Murray had to replace the plug as well also ... as well: Murray 22" Lawn Mower 6.5 HP OHV -- First Start after Carburetor Cleaning - Part III - May 9, 2013 ... When I start it, it runs for 3-4 seconds and dies. ... Youcan also find you engine Model # online and view the ...
Sep 09, 2015 | Tecumseh Garden
Looking for a manual & parts list for a 13hp Tecumseh Enduro 38506x engine that is on a Murray riding lawnmower.
Try e-bay under your brand of mower or engine, or go to craigslist in your area under BOOKS, if not go to your local Murray dealer who should be able to help you. GOOD LUCK FRIEND.
Nov 28, 2014 | Murray Garden
Murray select
Drill the center of the broken off bolt to a depth of about 1/2 inch and use an easy out to remove it. You should soak it with PB Blaster for about a hour before trying to remove it and dont forget to use WD40 to keep the drill bit cool while drilling. Good Luck
George
Aug 03, 2013 | Briggs & Stratton Garden
Tecumseh starter 13.5 hp wont turn over only a click on murray 405005x99a
It might be the start solenoid, or the starter motor. Best way to tell is to Jumper across the heavy (High Current) solenoid terminals. If the starter turns, the solenoid is bad. If not, the starter is bad.
May 01, 2011 | Tecumseh 100% 12v Starter 35765 32468...
Carburators are not getting fuel
have a murray 20 hp tecumseh has gas in the bowl but wont start unless u spray the carb then it dies when u stop spraying any ideas
Apr 14, 2011 | Tecumseh Enduro VTwin Vertical Engine with...
5 hp tecumseh snow king engine on a murray snowthrower. How far should I unscrew the float screw?
Turn it in all the way gently until it stops then turn out 11/4 turns out.Then tou can fine tune from there.
Dec 15, 2010 | Mtd Garden
What type oil and what level should I put in my 6-7yr old Murrary riding garden tractor. Model=?, but 25 HP, 2cyl 52 inch deck.
You didn't specify what engine is on your Murray, but most of them were either Briggs & Stratton or Tecumseh. Both of these engine take SAE HD30 weight motor oil. Appoximately 48 ounces will fill these from a complete drain.
If your Murray has an imported engine (honda or kawasaki) then they would use 10W30 oil.
Aug 30, 2010 | Garden
Murray quattro ultra mower
Murray for the Mower and I imagine its a Briggs engine, go to Briggs.....If any other engine go to the maker of that engine.
Jun 04, 2009 | Garden
Need to change the back tire or put it back on the rim
Find someone with a racheting cargo strap. Jack up the mower (put a stand under it) and place the strap in the center of the tire and tighten it up...the tire side walls will push out againts the wheel and you should be able to get it to seal and hold air.
Mar 21, 2009 | Garden
Garden Logo
536 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
