Question about HP Compaq FS 7550 17 in.CRT Conventional Monitor
"out of frequency range" message nothing works
Get the "out of frequency range" message. have changed frequency in safe mode to 800x600 and it still repeats the same message. can't go any lower. it has worked fine for years and just now started with message
  • 3,940 Answers
Try booting to the ENABLE VGA mode off the F8 menu if you can get to the desktop and then you can go to display properties and see if you can reset the resolution to normal. If no go, try updating the video driver
Posted on Oct 02, 2009
My hp monitor S5500 when boot on it desplay out of frequency range and set resolution lower or see monitor users guide. What can i do to clear this information.
It means that the resolution set in the pc is higher than what your monitor can handle. Boot in Safe Mode, go to Control Panel > Display and in the Settings put a lower resolution - 800x600.
Jul 15, 2011 | HP Computers & Internet
Has a blue dialog box that says out of range
Hello
It sounds like you have two separate problems.
The first one is the "out of range" issue. This means you are trying to display a screen resolution that is too high or too low and your monitor cannot display any image. Reboot your computer with another monitor or into safe boot mode and change the resolution to an industry standard (800x600 / 1024x786) and then see if your monitor will display the image. Once you can see the image on your monitor, you can make adjustments and it will automatically revert back if you cannot see the new display settings.
Update your video graphics card drivers to get the best possible resolution.
As for the buttons on the front of the monitor not working, this may be caused by the "out of range" issue above. It could also indicate that your monitor may be going bad. Try the above steps - if you get no image from the monitor, try moving the monitor to another known good computer and see if the button functionality works after it displays an image.
May 04, 2010 | AOC 193FW LCD Monitor
When computer boots up my screen says out of range but if I go to safe mode it works . What is out of range
When you boot up normally your computer sets the screen at the resolution you choose. In safe mode the screen's resolution is by default 800X600.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct FiXya link: http://www.fixya.com/users/technical114
Mar 11, 2010 | Compaq Presario 5000 PC Desktop
Out of range message on my monitor.
Boot your computer to safe mode and change the display settings to either 800x600 or 1024x768 then save and reboot once it comes back up you can change the display setting to what you prefer.
To get into safe mode press F8 on you keyboard every second while it is first booting up.
Mar 08, 2010 | Computers & Internet
DELL E153FPf doesn't show the image
OSD Warning Messages A warning message may appear on the screen indicating that the monitor is out of sync range.
Cannot Display This Video Mode
This means that the monitor cannot synchronize with the signal that it is receiving from the computer. Either the signal is too high or too low for the monitor to use. See Specifications for the Horizontal and Vertical frequency ranges addressable by this monitor. Recommended mode is 1024x768 @ 60Hz.
Occasionally, no warning message appears, but the screen is blank. This could also indicate that the monitor is not synchronizing with the computer or the monitor is in a power save mode.
Jan 18, 2010 | Dell E153FPf 15" TFT LCD Flat Panel...
I get a message, "Frequency out of range. Nothibng else. The menue and other buttons don't do anything. Nothing else shows. I swapped out the monitor and the new one works.
This problem arise when your computer AGP driver not adjust monitor frequency.you fix it restart your computer and run safe mode settings resolution area(must be choice less area)or select 1024X768 pixel monitor frequency 60Hz press apply set OK.restart your computer.Run again normal mode.May be fix your problem.
Dec 27, 2009 | Princeton Digital VL1916 19" LCD Monitor
Out of Frequency error
1. Start Windows in safe mode by pressing F8 and Change the display properties to 800 x 600 16bit
2. Restart in normal mode
3. If the 800x600 screen resolution doesn't work try going into safe mode and trying a lower resolution
Jul 17, 2009 | Gateway FPD 1730 17" Flat Panel LCD...
Intstalled starlogic moniter to PC and got error message
the "Out of Range" message usually appears when the video card is putting out a video resolution or frequency that the monitor isn't able to handle. You should reboot your computer and BEFORE the Windows screen shows up, press the F8 button once every half-second. THis will bring up the boot menu for Windows. Select "Enable VGA Mode" and press enter. THis will load Windows in VGA mode where the screen resolution will be 800x600 @ 60Hz. Any modern monitor is able to use this. Once you log into Windows with the basic video settings, you can go into the Display properties within Windows and bump up your resolution and frequency as needed.
May 11, 2009 | Computers & Internet
KVM Monitor resolution out of frequency and will not display
Restart your system in a VGA mode (you will find this below Safe Mode, by pressing F8 before windows is loading) This way yours screen resolution will be at the very low frequency then you can change it back to the resolution you like. Eg. 800x600 or 1024x768. Remember to keep your Screen refresh rate lower like 75Mhz
Oct 30, 2007 | Compaq (242697-001) 8-port KVM Switch
HP Compaq FS 7550 17 in.CRT Conventional Monitor Logo
241 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
