Question about Gateway FPD1975W 19" LCD Monitor
It is a Gateway FPD1960TFT LCD monitor. The red is acting up, sometimes none, sometimes to much, occationally flickers. I've checked all external computer connections none are loose. Moving the wiring where it enters the monitor has no impact. A light rap to the monitor and computer is no help. I?m Soluciting opinions. Monitor, driver, or card. Nvidia PNP GeForce 6100. Gateway GM5972 Computer. Thanks Lou
So I Have 2 of the same Gateway laptops..Screen Was flickering on Wifes,Some one told me try Swaping memory tryed it ,Than Swap Hard drives Now Both wont reconize hard drive .all i did was take out 2
Put them back the way the were originally. Try an external monitor to the laptop and see if it flickers. If it does, more than likely your video card is going bad. If it does not flicker on the external monitor you probably have a loose video cable or lcd inverter cable. Go back inside and remove the 2 cables that go into the LCD Inverter that sits at the bottom of the LCD Screen, then plug them back in. Then unplug the video cable at the top behind the lcd screen, plug it back in and secure it with a piece of tape right where the two connections meet.
Also it wouldn't be a bad idea to remove and plug back in the video cable that plugs into the motherboard. This is the other end of the cable that is behind the lcd screen at the top.
Mar 28, 2012 | Gateway Computers & Internet
Gateway FPD1960TFT LCD monitor does not seem to come on. I cannot see anything on the screen accept a small blinking cursor. I can boot from the windows 7 CD and see things fine but trying to install or...
If you see blinking cursor, the monitor is fine, the computer did not bootup properly from your hard drive, it can be the HD failure or OS failure.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV, Monitors, Caps : http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitor kits: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Oct 30, 2010 | Gateway FPD1975W 19" LCD Monitor
I spilled juice on my gateway T-6330U laptop keyboard. I shut if off and pulled the power cord. I noticed it trying to boot up when cleaning it off, the LCD was fadding, and I heard sizzling under the...
Check the video connectors on the motherboard.
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, this is the most likely case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site :-
www.lcdparts.net
Sep 21, 2009 | Gateway T-6330U Notebook
My Dell flat panel monitor flashes on and off what can i do to fix it...
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out
www.lcdparts.net
Sep 14, 2009 | Gateway FPD 1730 17 in. Flat Panel LCD...
When I turn on my computer, the screen stays black
Check out
www.lcdparts.net
Sep 09, 2009 | Gateway MX6956 Notebook
I have a Gateway M-6843 Notebook PC that won't power up.
Check out
www.lcdparts.net
Sep 06, 2009 | Gateway 7405GX Notebook
Screen flickering when turning on laptop and sometimes the laptop turns on after flickering and sometimes doesn't turn on at all after flickering. Just stays black.
You may have a faulty inverter or loose power inverter connection. OR
Check out
www.lcdparts.net
Sep 01, 2009 | Acer Ferrari 5005WLMi (LXFR506119) PC...
Monitor flickers or 1/3 turns black, have tried wiggling cable, and moving/tapping monitor, sometime it works great, other times i fight this every few min. Doesn't matter if i turn computer all the way...
Check out
www.lcdparts.net
Aug 31, 2009 | ViewSonic VA2226w 22" Widescreen LCD...
Bluish green screen on dell laptop
It might be that your red pin is bent out of shape. Please make sure ALL pins on BOTH ends are straight, and none are broken or missing. Also, make sure that they are firmly secure.
Jul 03, 2009 | Dell E176FP 17" LCD Monitor
My Gateway mx7118 lcd flickers whenever screen is opened,closed,
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a dim image or flicking image on the laptop's LCD screen it means you have a backlight problem.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 13, 2009 | Gateway MX7118 Notebook
Gateway FPD1975W 19" LCD Monitor Logo
133 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
