Question about Garden
I Have a 13hp B&S diamond in my MTD mower. It
I Have a 13hp B&S diamond in my MTD mower. It runs fine and works well, i have an acre block and when i get towards finishing the engine runs rough and misfires. once allowed to cool it is fine. Is this an overheating problem? It has had services regulary and always gargaged. Cooling fins are not blocked or dirty.
  • 474 Answers
It could be a cooling problem. try mowing in the next lower gear.
Posted on Oct 02, 2009
Replaced solenoid replaced starter motor still makes clicking noise under seat battery fully charged mtd 13hp ride on mower
Batteries are great at corroding the connections with a hard coating. Disconnect the cables and scrape the connection surfaces to get a shiny surface and reconnect.
Feb 14, 2015 | Mtd Garden
Greenfiled ride mower 13hp
the mesh cover should have screws in it or the center cup holds it in place. youll have to remove center nut or bolt to get flywheel off
May 26, 2014 | Mtd Garden
Replacing a MTD spindle assembly
Yes, most spindles come with non threaded holes. The metal is soft and you can just use regular bolts. Once you start them, they cut their own threads.
Jun 02, 2012 | Mtd Garden
MTD 13hp lawn tractor . Belt problem
If you have the manual look and see if you are missing a spring on an idler. They sometimes break or get weak. Next how old is the belt because they will stretch. If you have a little play in the belt I would say it is stretched. If a lot of play then you are probably looking at a spring that is bad.
Aug 12, 2009 | Garden
Can you point me to the wiring diagram for the above mower
The flywheel black (negative) and red (positive) wires are the magneto output. Red goes to ignition to charge the battery, and also burn the headlights -- so the red will go to the headlight switch as well, maybe through the ignition.
There should be an in-line fuse on the charging/headlight wire coming from the magneto.
There should be a safety switch under the seat which energizes the fuel cutoff solenoid on the bottom of the carburetor.
There are also interlock switches on blade engage mechanism, and the brake pedal, These prevent engine from starting if brake is not applied or if blades are engaged -- these would control current to the ignition module.
This is not complete, but it'll give you some clues -- good luck -- it's a ton of work.
May 08, 2009 | Mtd Garden
Garden Logo
101 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
