Question about Linksys Wireless-G WRT54G Router
How do i find the pin number for the wrt54g V 8
  • 404 Answers
HI! i will be glad to assist you, if you are referring to the wireless security password in order for you to access the wireless connection, from the url type http://192.168.1.1 then it will ask the username and password, for the username, type admin and the password just leave it blank or 1234, then the setup page will pop up, go to the wireless connection setting , from there it will show the type of wireless security that you have it could be one of the ff: wep, wpa, wpa2 then it will show also the password or the pin that your referring. if you cant access the setup page of the router then you have to do this steps in order to setup again your router, here are the steps u need to do: 1. press the reset button on the back of the router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer..
3. pull up ur browser then type at the url:192.168.1.1.or 192.168.0.1 or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank
4. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet.
b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url:192.168.1.1 and u can setup the wireless settings, u need to create a ssid or wireless name and a security..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe
6. If ur isp gives u a static ip address settings, u need to set the router to isp setup.
a. how to check the isp of the isp given to u..
1. click on start
2. run
3. type cmd
4. it will show a dos prompt
5. from the dos prompt type ipconfig/all
6. it will list the ip address, subnet, default gateway, dns server
this settings should be type in to the settings on the router for static ip addressing..
7. Once your done on the internet setting, go to your wireless connection settings and you can create a wireless network name or ssid, set a security by selecting wep, wpa, wpa2.
8. once all is set. save the settings and to check if your laptop can access the wireless network that you did, turn on the wireless switch of your laptop, once its on, it will show the wireless network icon on the lower right of the taskbar, right click it and select on view available network, the network name that u did should list, just select it and connect and it will ask for the password, just type the password and connect, you should be connected to the wireless network and have internet access..
9. If you are going to hook up your desktop to the wireless connection, you need to install a wireless network adapter, install the driver and do the same thing as u did to the laptop, for the desktop no need of turning on the wireless switch, once you install the driver correctly, it will show a network icon..
if you have any query pls feel free to get in touch.. good luck
Posted on Oct 03, 2009
Where can i find the 8 digit setup key number on a tv
if you are trying to find 8 digit number on your t.v. then you need to go to wlan settings on your t.v. and click on wireless protected setup . there , now you will able to see your 8 digit pin
Jun 20, 2014 | Linksys Wireless-G WRT54G Router
What are the 4-8 diget number in linksys wrt54g
The default IP address for the router is 192.168.1.1. If the router IP number was changed, then it will have to be reset to the default to access it. You can access the router from your computer using the URL: http://192.168.1.1 (the default IP number).
Apr 03, 2014 | Linksys Wireless-G WRT54G Router
Pin number for router
You should be able to see the 8 digit security PIN on the back of the side of the router. It will have three numbers , MAC, SERIAL and SECURITY PIN. it will be clearly visible if you see the label attached to the router.
Jul 01, 2013 | Computers & Internet
My network setup is asking for a pin number that is on my router. Obviously there is no pin number for this particular router and my network is asking for a 4 or 8 digit number. What do I do?
If its asking for a pin number I would check the sticker on the bottom of the router. it may have the router PIN you are looking for. If not trying typing in your internet browser address bar 192.168.1.1 and find the network settings and see if there is a pin set up, if so write it down or clear it to have no PIN
Feb 28, 2011 | Linksys Wireless-G WRT54G Router
The internet guy was just here today in my new place but i wasn't here with him.To connect to the internet it is asking for a 8 digit pin code located on the bottom of the router. I can seee several...
When you say, "IT is asking for..." exactly what is "it?"
It sounds to me like you have a Linksys wireless interface (possibly USB) on your PC which assumes it is going to connect to a Linksys router, which would have that PIN code on it... but you don't own a Linksys router and therefore the whole PIN code protocol is futile.
Bypass the proprietary PIN code nonsense and enter the WEP or WPA password the installer gave you (if any; it's possible he didn't set any) to connect to your access point from your PC.
Nov 01, 2010 | Linksys Wireless-G WRT54G Router
Can't find PIN for or on my Linksys Wireless Router
There is a small red button on the back - Press it gently for 30 or more seconds to reset to default.
Default password is "Admin"
Get the software at www.linksys.com/support
Feb 14, 2010 | Linksys Wireless-G WRT54G Router
Which number is the PIN number
I do not know what you mean by PIN number, but if you want to access the web interface of the router enter http://192.168.1.1.
user name is admin, paswaord is admin. These are the defaults the router returns to if you RESET it.
Hope it helps.
Sep 23, 2009 | Linksys Wireless-G WRT54G Router
I am also facing the same
you have to create that pin but it is a 10 diget number not 8. 64 bit encryption is 10 numbers log into the router if you dont know how go to linksys web site they have great wolk through guides with pictures and everything. very easy.
Jul 17, 2009 | Linksys Wireless-G WRT54G Router
How do I find the PIN number for my linksys WRT54G2 router
I have had this problem. Go to the website and get the free phone number and ring them. They were able to help me (twice as I forgot after the first time).
Jan 01, 2009 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
194 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
