THE WASHER IS FLASHING CODE 51 - Washing Machines
I reciently tried to fix my oasis kenmore elite he model 110.27062603. I researched on this website (fixYa) and learned that the f 51 code is related to the motor rotor position sensor which sences the motors speed and if it is spinning OK. I read some post describing how the connection to the RPS sensor could be worn or coroded or loose. one of the chats on this subject described how to take the sensor out (which is not that difficult if you are a handy person. (It involves taking the motor appart). So, I followed the instructions and took it out and re-assembled it. Stiil had the same problem. I decided to try changing the macine motor control (the computer for the wasing machine) I still had the same f 51 problem. Then I bought a new RPS sensor, and that didn't work either. Finally I kept trying to figure out how to open the top of the clothes washer to look for stuck clothing between the stationionary drum that holds the water and the rotating drum. Someone had described opening the top, but I didn't know how to do this. I did a search on google on how to remove the drum, and there was a photo of the place to pry to open the top of the washer. there are 2 tabs that you have to press in on while lifting up on the top. use a putty knife or a flat screw driver. the place to press is from the outside, on the front of the washer, about 6 inches from each corner.
So, I opened the top cover of the washer, and then was able to un- snap the plastic cover over the drum and I found a bra that was causing enough friction between the drums that it would cause the RPS sensor to think there was a problem.
So, Now the machine works fine again.
Gordan
Posted on Oct 01, 2010
What does a flashing F51 code mean?
Dump the appliance. sears delivers the worst garbage available
Mar 22, 2016 | Kenmore Elite Oasis 27052 Top Load Washer
Lights keep flashing and door locks without finishing cycle
Kenmore HE2 Plus Front Load Washer Keeps unlocking ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
flashing prewash and add garment lights My HE2 Plus will fill with water, but when ...Kenmore HE3 2plus wont finish cycle Washer wont finish the last1 minute of cycle. ...We ran a load twice and it still did not unlock. du is the code for cannot ... Why does the door keep unlocking and locking in between the drum rotating?
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following symptoms: Not Completing all Cycles ...
Washing machines - Ariston
Jan 05, 2016 | Washing Machines
My washer is flashing 5 red and 1 green
E51 suggests insulation on motor down or has got wet it may dry or if very wet need replacing
Jul 20, 2014 | Zanussi Washing Machines
Panasonic na-168vg3 h51 code flashing
Hi Rick, What does H 51 mean on the display of my Panasonic NA 140vg3. However, after that code has flashed a circle symbol will appear, then it will disappear. The door won't open. I would appreciate your help. Cheers
Jan 16, 2013 | Washing Machines
I have code 51 flashing. Where is the air bag diagnostic module located?
Hi, the code 51 flashing means that the internal fuse is blown and the short to ground is no longer present. If the short to ground returns, the code will change to 13 (air back circuit shorted to ground) or 14 (primary crash sensor circuit shorted to ground), but it will only flash 13 or 14 when the short is present. If the code remains 51, then first find and repair short before replacing the diagnostic monitor (what people call air bag module).
Take care
Aug 03, 2010 | 1994 Mercury Grand Marquis
F-51 code on kenmore elite oasis washer - how to prevent and or fix
Please see the following Whirlpool Cabrio installation and service manual, the Oasis is essentially the same washer.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
The F and 51 code relates to the motor rotor.
"F then 51 flashes when there is a motor rotor position sensor (RPS) failure. See TEST #3."
The "test #3 is a bit complicated but can be completed if you are reasonably comfortable with test equipment.
Oct 20, 2009 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
Cabrio washer is giving an F 51 Code
The "F51" error code is common problem with the Cabrio. This is an RPS sensor error. The sensor is mounted along the motor windings under the washer and detects the rotation spin speed. The sensors on these units can go bad, causing the error code, and it has been a frequent problem. I would recommend you contact Whirlpool first (due to the unit only being a year old) and see if there is a recall or upgrade on this part. I believe there is. The repair would then be covered by the manufacturer. If I give you the steps to access and/or replace the sensor at this point, you may be voiding any existing warranty you may still have. Some components carry a longer warranty than your normal one year limited warranty from the manufacturer. Something you may consider.
If you have further questions, please let me know. I hope this helps you in some way.
Jun 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Airbag dash light flashing code 51
Common fault on FORD
Usually due to a poor connection in the YELLOW PLASTIC CONNECTOR underneath the passenger seat.
Just push it together properly and it should clear the AirBag fault
May 18, 2009 | 2003 Ford Focus
Washing Machines Logo
116 people viewed this question
Top Washing Machines Experts
