Question about Gigabyte GA-8I845GVM-RZ Motherboard
I have a few burned out components on the mother board due to a faulty connection of the smps. I think if I can get the components list I can repair the motherboard so I need a full screen view where I can see the part no. so I can replace them. Thanks
    Guru:
  • 355 Answers
Goto motherboard site take th clear picture of your board
Posted on Oct 02, 2009
Inspiron 620 desktop will not power on. Change out of power cord was done whilst under warranty (7/12-7/13). Purchased 7/13. Warranty is up. Have not tried to power on since August--it powered up then....
A computer will not power on in certain conditions follows
  • RAM Failure. i.e, RAM is not properly inserted into the port, or any dust particle presence in its port, I am sorry to say The RAM is in DEAD condition
  • Mother Board Failure. Any overflow of power enters into the motherboard. motherboard will burnout (due to lightning, Voltage level increasing etc)
  • Power Failure
  1. When the power cord is properly functioned or loose connection
  2. SMPS is under malfunctioning (SMPS Burn out)
  3. Power cords from smps to mother board,HDD,CD drive fail
  4. Short circuits etc
Check it out...
Jan 22, 2014 | Dell Inspiron 620 ST Desktop Computer...
My mother is dead no display
You must have meant MOTHER BOARD . but if there is no display then it is possible that the main powerr supply hasa failed. So check this SMPS unit before you can think that the mother board/display panel is faulty ONLY if there is correct voltage supply to the board.
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Jul 14, 2011 | Computers & Internet
Was workin ok but no signal imput now
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
Mar 29, 2011 | Asrock K7VT2 Motherboard
My iphone has just gone off...fully charged
Remove battery and keep aside for few minutes. Now insert back and try to switch on, if there is no action it is possible that the mother board is faulty , possible damage due to component failure. If under warranty please do not attempt to open but seek help.
Jan 18, 2011 | Cell Phones
Tv standby
Possible that the mainbaord is faulty, the output driver is short or a high voltage component is short.
Since the model is not specified , you will have to check the mother board for errors as your SMPS is working but check if the secondary fuse has gone off in the high voltage section of the SMPS.
Sep 26, 2010 | Televison & Video
Cannot turn on cpu
when you say cannot turn on cpu - what do you mean - ?
cannot boot up?
try removing the cmos battery for a minute then replace and try again.
any error beeps ?
working fine before ?
Oct 11, 2009 | E-Machines eMachines Desktop PC
Dear sir, my computer asus sis961 is not working, power is not showing in mother board, technician is telling in mother board short sirkit
Do u know how to assemble a pc
if yes take the mother baord out of cabinet . place the mother bord on an insulating surface with proceesor . then connect smps ... poweron the board by shortin the frnt panel connectors . connect all peripehrals like monitor , kb and mouse etc ..... if this seems to be working try to insulate the cabin whre mother board is fixed ................ SMPS can also cause no power try chekin with another smps too
Aug 05, 2009 | ASUS P4SE Motherboard
I used the wrong adapter by mistake now my laptop wont come on, i'm sure i fried something , the only thing it does, is the power lightly faintly clicks very rapid. Nothing else.
Yes you are correct. Due to wrong adaptor the power supply known as SMPS gets fried and causes mother-board damage too. So you need to repair your laptop's mother-board components and power supply too.
If this solution was helpful to you then please rate 100% (or FIXYA) for this solution, otherwise don't rate at all. It was my pleasure helping you.
With regards,
Shyny Saxena
Jun 30, 2009 | Computers & Internet
Computer will not start
first you connect your harddisk data cable to mother board
connect your hard disk powercode using smps
connect smps 24pine connector threw mother board
connect 12v connector threw mother board
connect cpu&external fan connections
also connect the front panel connections on mother board using mother board details
Jun 17, 2009 | ASUS A7N8X Motherboard
My computer
This is due to either faulty RAM or some corrupted mother-board component. So please replace RAM or repair your computer's mother board.
Dec 10, 2008 | Acer Aspire 5500 5570-2609 Laptop
Gigabyte GA-8I845GVM-RZ Motherboard Logo
64 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
