Question about Maytag Neptune MAH5500B Front Load Washer
Maytag neptune mah5500bbw wont spin going through cycle
  • bcschadrie Oct 02, 2009
    Maytag Neptune MAH5500BBW won't go into "SPIN" after going through all of the wash cycles. After the last rinse, water pump turns on, drains water....then pump continues to run for approx 30-40 seconds. Timer is timing down from 9 -7 at this time,....after pump shuts down, about 1 minute goes by, then the diplay turns to 0 and washer beeps signifying that the load is complete. Clothes are soaked!
  • drewrobinson Mar 29, 2014
    Water drain line is kinked, I'll bet. That was our cheap, easy and painless fix!
  • 3 Answers
My Maytag Neptune MAH5500B or MAH5500BWW wouldn't spin either. It would go all the way through the wash cycle, agitation and all, as mentioned before, the spin cycle would start at the 9 minute mark, and get down to the 7 minutes then drop directly to 0 with no spin at all.
After hours of investigation it turned out the balance load switch was corroded. This switch is accessible through the front panel of the washer. The door must be removed and the front panel comes off, this switch is directly under the wash drum where there is a little electrical plug and switch which rests on top of stabilizer styrofoam. The connection was being made but there was green corrosion, and evidently the switch box was corroded within. When bypassed, the washer spun perfectly.
Hope this helps someone else out there - I was horrified to think that this washer would end up more landfill as it wouldn't be worthwhile to pay hundreds for a new motor control board as had been suggested was the problem.
Posted on Jan 19, 2010
  • msrachelr
    msrachelr Jan 08, 2013
    I noticed that the R-11boogeyman that is mentioned so much doesn't even exist in the 2005 model. The R-11 found on the control board now cannot be replaced, it is stamped into the circuit board. I disconnected my door latch assembly (3 plugs) and left it overnight. Then I hooked it back up and went into service mode. I ran the board output tests for the door lock and unlock, and my washer runs like a champ again. I almost paid $70 for the part and $20 for shipping. Not to say that all repairs are as simple and cheap as mine, but run the simple tests. The wiring diagram and test instructions are under thre top plastic cover on the right side as you look at it from the front.
    President:
  • 1,304 Answers
Dou you see the lock ligt
if not you will need a new wax motor lock
and main control
if no light open the control panal visualy inspect control
for burnt resistor r-11
Posted on Oct 05, 2009
Eratic, sometimes door lock doesnt activate, when it does wahser starts but stop mid cycle and wont continue. Replaced door switch and pump
Repair needed on Maytag Neptune washer - Home Improvement ...
www.dslreports.com > ... > Home Improvement
DSLReports
Aug 5, 2007 - 19 posts - ‎8 authors
Forum discussion: We have a Maytag Neptune front-loader washing machine that ...the drain/spin cycle after a wash even though the timer continues to ... related circuit board failure" their Neptune washer will lock the door, turn on the ... then will either not start tumbling or will stop operation mid-spin cycle.
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - The absolute first thing to do to your washing machine that will notspin or drain (whether it. ... I was so fed up with the machine sometimes refusing to spin or drain the .... I just did a load and it stopped midcycle with e and f error codes.... I tried different cycles but all that happens is the door lock engages ...
Maytag Washer Troubleshooting - YouTube
Dec 02, 2015 | Maytag Washing Machines
Neptune washer mah3000aww skips to spin cycle and wont drain
It sounds like the "repaired" main control board is still the issue with it being intermittent.
Nov 20, 2012 | Maytag Neptune Washer
Maytag Neptune washing machine - wont drain & spin
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 21, 2010 | Maytag Neptune MAH5500B Front Load Washer
I need a diagram for a maytag neptune mah5500bbw washer
There are a few links here that not only have the diagrams, it shows step by step photos how you can get to the pump, remove it and clean it out along with other photos and diagrams for the do-it-yourselfer on your neptune front loader!
http://www.applianceaid.com/neptune3.html
Mar 15, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag door wont lock and go into spin cycle
You will need to replace the door interlocking device.
Oct 26, 2007 | Maytag MAH6500 Neptune Front Loading...
Maytag Neptune doesn't spin at end
Of course, did you find anything clogging your outlet filter, this is most likely the problem. The outlet filter needs periodic cleaning, according to your usage.
Jun 18, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
694 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
