Jumper pin Settings samsung hard drive SP1604N
  • 93 Answers
Hi frnd...
just have a look at this pic it will help u..
http://common.packardbell.com/PrsPicDwn/08-192-1.gif this is the jumper setting for master... To enable Slave settings just unplug the jumper and leave all the jumpers unplugged....
take care
Posted on Oct 02, 2009
What is the jumper setting for the drive to me a master with a slave?
You can view the jumper settings at this picture:
In case you'd like a better quality image you can go at this link and scroll down to the page 26.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Apr 05, 2011 | Samsung SpinPoint P80 SP1604N 160 GB Hard...
Can i put a samsung non sata sp1604n hard drive in an hp pavilion p6310y desktop as a slave drive ?? the sp1604n is not a sata type hard drive, but the master that came with it is. the master is a western...
Unless the motherboard in your system is different from the one shown on HP's site, the answer is no, you can't install the drive. At least you can't install it without additional hardware, which I'll describe in a moment. It looks like this board only has SATA connections for drives, which is becoming more common. So there is no conventional (i.e., old-fashioned) IDE connector for the data cable used by your Samsung drive. There's no place to plug the in the drive.
What you'll need if you want to use a parallel IDE drive is an expansion card like this one. There are many similar cards; I'm just using this one as a sample. The card installs in one of the PCI-E slots on your motherboard, and it provides the IDE connection you need. In addition to the card, you'll need an 80-conductor ATA-133 IDE cable.
With SATA drives, there isn't the master/slave designation since each SATA device has a direct connection to the motherboard. With the parallel cable, you can have two devices connected, so one needs to be designated as the master and the other one as the slave. The master is the drive connected to the plug physically at the end of the cable, and the slave is the middle plug. When you install your Samsung drive, set it for "master" or "single" drive as required. Some drives have a special jumper setting when used alone, while others need to be set as master even if there is no slave drive present. The jumper settings are usually marked on the drive, or you can check at Samsung's website.
Hope this has helped. Thanks for using Fixya!
Jan 20, 2011 | Samsung SpinPoint P80 SP1604N 160 GB Hard...
Spinpoint hard drive need so set up jumpers as master drive
These can be a pain to find but I managed to dig through all the other info in Samsungs site and get you a direct link to a page with the jumper settings and diagrams.
http://www.samsung.com/global/business/hdd/support/userguide/Support_Setting.html
this link will demonstrate all the jumper settings you should need. If you have any trouble figuring out which ones to use, drop me a reply on this answer and I can help you sort out any additional questions you have.
Hope this helps FixYa,
Chris
favicon.ico PR: wait... favicon.ico I: wait... favicon.ico L: wait... favicon.ico LD: wait... favicon.ico I: wait... wait... favicon.ico Rank: wait... favicon.ico Traffic: wait... favicon.ico Price: wait... favicon.ico C: wait... close.gif close.gif
Jan 02, 2011 | Samsung SpinPoint P80 SP1604N 160 GB Hard...
Jumper settings when used as a slave in a HP pavilion 6835
There are 3 pairs of pins:
* MA(ster)
* SL(ave)
* C(able)S(elect)
Move the jumper to connect the two 'SL' pins, if you want to use the drive as a "slave" drive.
Or, move the jumper to the 'CS' pins, and the drive will auto-configure itself.
Sep 21, 2010 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Just need a samsung sp1604n driver
Any drivers needed will be on the samsung website, but unless you are using an old motherboard and windows xp (may need drivers loaded off a floppy drive) no drivers are needed.
If you are using Vista, your problem may lie in your motherboards bios, it may need an update
Jul 17, 2010 | Samsung SpinPoint P80 SP1604N 160 GB Hard...
Jumper setting for hard drive
Dear Friend,
To make Master Hard drive Look here..To make Slave unplug jumper from the Hard drive..... Hope this Helped you..Thanks for Contacting FixYa...
May 21, 2010 | Samsung SpinPoint P80 SP1604N 160 GB Hard...
Jumper pin settings
Hold the samsung SP1203N hard drive in your left hand with the lable facing upwards (then power cable connectors will be on your right hand side and the IDE cable connector will be on your left ahnd side). There are two raws of jumper pins in between the above two connectors
Master - join the first two column of pins on the left with a vertical jumper
Slave - leave all pins free (without jumpers)
Cable Select - join the third column of pins from the left with a vertical jumper
job done !!
Udai De Silva
Oct 16, 2008 | Samsung (SP1203N) 120 GB Hard Drive
ATA133 refusing to be accepted
Obviously mobo error, have you tried re setting bios from 'JBAT1' terminal, jumper from pins 1-2 to pins 2-3 then back on 1-2. Start up again and set time and select the auto detect HDD in standard bios settings see if correctly identified. save settings and restart pc
Jan 15, 2007 | Samsung SpinPoint P80 SP1604N 160 GB Hard...
Computers & Internet Logo
4,625 people viewed this question
David Payne
David Payne
