the amp just quit. no smoke or burning smell. will not power up at all. internal fuse checks okay. any type of reset to look for that I may be overlooking?
Ok there is a few steps to check in this case.
1. Make sure the positive cable is secured proply on the battery termnial also while you are there as well check to make sure the fuse on the positive cable isn't blown.
2.Make sure your ground cable is secured proply down on the frame of the car or if you are runing a negitive cable back to the battery(the same apply,s as step 1 - less the fuse).
3.Check to make sure the remote turn on cable is not lose on the amp connection.
Hope this will help a bit.
Alex
Was this helpful?
Yes
No
Popular Solutions for Yamaha STEREO POWER AMPLIFIER
ive got a ma audio 7oo watt amp when i turn it on it will come on but no music comes the speakers...
(More)
ive got a ma audio 7oo watt amp when i turn it on it will come on but no music comes the speakers just go bump bump bump what do i do
my phoenix gold xenon 100/2 keeps blinking and putting a loud buzzing sound into my speakers, it...
(More)
my phoenix gold xenon 100/2 keeps blinking and putting a loud buzzing sound into my speakers, it went into protect mode, whats wrong with her just got it.
have a jl audio 500/1 i think something is wrong with the ground on the amp i intalled it and it was...
(More)
have a jl audio 500/1 i think something is wrong with the ground on the amp i intalled it and it was load sounded good but after a couple days i would turn it up and it would cut out until i turned it down so i relocated the ground then it worked good again but the same thing happened after a couple days the amp would only work at low volume would could be causing this
We have a LG air conditioner. Model - B36AHYUH61 with outside sound power level 72. The unit is in...
(More)
We have a LG air conditioner. Model - B36AHYUH61 with outside sound power level 72. The unit is in our rear courtyard as per strata instructions. We have had this unit for 12 months and very happy BUT now new neighbours have moved in and are complaining about noise level and hot air blowing over the 6 ft dividing brick fence. Is there some sort of insulated cover that could go over the unit to cut down the noise level or what other suggestions would you have ? thanx
