Question about Maytag MER6772 Gemini Electric Kitchen Range
My Maytag Gemini MER 6772 Range has an F1-4 code. This occured after a cleaning cycle. Oven doors are now locked and resetting doesn't work. What do I check next?
  • 80 Answers
Try unplugging the range you might get lucky. If not there is a sensor that will need to be replaced.
Posted on Oct 02, 2009
Getting a F1-4 error code on my Maytag Gemini model # 6772. Came home to the upper oven at full heat with the control panel beeping. Extremely dangerous situation where the oven would not shut off at the...
Hi greg_shanoia,
The F1:-4 error code means "Runaway Clean Lower oven". You need to check the oven temperature sensor, replace if necessary.
Hope it helps.
Thank you for using FixYa.
Sep 21, 2011 | Maytag MER6772 Gemini Electric Kitchen...
My Maytag Gemini oven is displaying an F9-2 error code...I believe this has to do with the upper oven door lock mechanism...anything I can do, or does this require a service call?
F9-2 error code indicates:
  1. Door latch motor failure/jammed. Latch motor switch failure.
  2. Oven control software failure, or component failure(stuck relay).
  3. Wiring problem.
  • Press the clear key.
  • If the Clear key does not eliminate the problem, turn off the power to the range for 30 seconds, then turn the power back on.
  • It is most likely to have a failed or misaligned door lock switch.
Feb 06, 2011 | Maytag Gemini 30" Self-Cleaning...
The Maytag Gemini is didplaying an f9-3 code, what does this mean?
somthing wrong with upper door lock, bent, door misaligned, problem with lock itself
Dec 25, 2009 | Maytag Gemini 30" Self-Cleaning...
Heat in lower oven will not exceed 185 degrees
Several possibilities:
1. Bake/broil elements are bad - can you see them glow red?
2. Temperature sensor is out of wack - does the temperature displayed agree with the actual oven temperature? The sensor can be tested by measuring its resistance.
3. If the elements and sensors check out and the oven "thinks" it is hot when it's not, then it is probably your control board. In this case we may be able to help you, we repair these at www.fixyourboard.com.
Sep 30, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Lower oven door on range won't unlock after clean/cool cycle
try unpluging the stovr let set plug back in might reset itself if not u can remove the back to get to the lock then check to see if that good or bad u might need that locklatch or possibly a erc
Mar 17, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Maytag Gemini Electric Oven - Lower is not locked, but will not open.
Usually, starting with a COLD oven, turn the self clean on. Wait 3 minutes, then turn it off [cancel] WAIT 1 minute at least, do not immediately pull on the door. This should reset the lock sync. If you cannot get it open still, you may have a faulty sensor that thinks the oven is overheated, or at this point you could have a bent actuator rod from all the tugging!
May 01, 2017 | Maytag MER6772 Gemini Electric Kitchen...
Maytag Gemini Stove Code F1-4 (bottom door won't open)
F-1 error is a Temperature Runaway. It Maytag's way of letting you know that oven overheated. Nothing you have done but it may have shorted out the oven sensor or the keypad. Check the sensor and see if it's closed. If it's okay, replace the keypad.
Oct 25, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Self cleaning MAytag Gemini GAS oven
A wonderful feature is that the ovens self-clean with the press of a few buttons. Only one oven can be programmed to self-clean at a time. Remove the oven racks. Turn off the oven light and close the door. Press the "Clean" button and then press "Auto Set" to automatically clean the oven for 3 hours. Press the "Auto Set" pad again to set the oven for a 4-hour clean cycle, or press the button one more time for a 2-hour cleaning. The oven locks when in cleaning mode. When the oven is finished cleaning, the word "Cleaned" will be displayed on the control panel, and the oven will remain locked until the oven has cooled, which takes about an hour. To cancel the self-clean cycle, just press the "Cancel" button. Simple!
Dec 28, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Maytag gemini self cleaning oven feature
Close door on lower oven (upper oven is not self clean). Press "Clean" pad. Press More pad or Less Pad. H is 4 hour clean, M is a 3 hour clean cycle and L is a 2 hour clean cycle. The door will lock and cleaning will begin. Good Luck!
Dec 18, 2007 | Maytag MER6872BAS Gemini Electric Kitchen...
Maytag MER6772 Gemini Electric Kitchen Range Logo
258 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
