Question about Bushnell Tour V2 Pinseeker Laser Rangefinder
Need a battery cover
I need a battery cover
  • 115 Answers
Call bushnell at 800-423-3537 option one and you should be able to order this part.
Posted on Oct 06, 2009
How get How get to the batteries in a 600Frascal scooter.
Fold the back of the seat forward, from behind reach both sides of the seat, the right side will have a lever that needs to be pushed forward and lift the seat off.
the cover is snapped into place in the back, I normally grab both sides of the cover and tilt up toward the back and lift. If you should have a docking device mounted to the seat post you may need to disassemble part of it to remove the cover, hopefully not. the batteries should be sitting with the post upright, sometimes the batteries were laid on there side, this is not good for the batteries. unplug one battery replace the cables and reinstall, then go to the next battery and do the same. Turn the key on, to see what state the charge is. then replace the cover and seat. Plug the charger in and allow the batteries to fully charge. Scooter Doctor App
Apr 30, 2016 | Health & Beauty
Cannot open battery compartment to change battery's
All you need to do is slide the battery cover to the Open position, then open the battery cover to access the batteries. If it doesn't open easily you may have some corrosion on the batteries holding the cover closed.
Mar 01, 2016 | Casio Exilim Ex-fh20 20x 9.1mp Digital...
How to open battery compartment on TV remote
Two main types of battery cover, if there is a finger / thumb indent then it is press down and push towards end of remote, the other sort has a little ctch at 1 end that needs pusing before the cover will come off, A finger nail is normally enough to do this. Hope this helps
Jan 12, 2016 | Televison & Video
How do i replace the battery in the garmin streetpilot c330
Follow these steps : 1. Determine that you do have a Garmin GPS with a replaceable battery. Find the information by checking the manual or with a close inspection of the back and sides of the GPS unit. GPS units that have a battery that can be replaced by the owner will have a battery cover lock on the back or side; it looks like a small sliding piece of plastic with slots or ridges.
2 Open and remove the battery cover by sliding the battery cover lock and pulling off the battery cover. In some models, you may have to hold the lock up while simultaneously pulling the battery cover off.
3 Remove the battery by sliding the battery out of the battery cavity. You may need to use gentle pressure to get it to slide out.
4 Put the new battery in by sliding it into the battery compartment. Line up the metal contacts on the battery with the metal contacts in the battery compartment to make sure it is properly installed.
5 Click the battery cover back into place. The battery cover lock should automatically lock and secure the cover. If this does not happen automatically, slide the lock back to the locked position.
May 16, 2011 | GPS
Lens cover would not close. Now camera will not turn on.
Lens cover not close, This will happens due to two reasons.
1) Either your camera battery got died or need to be recharged or replace. or 2) Your camera is malfunctioning and need service (repair).
To resolve the problem. first check battery on your camera, If battery indicator shows battery low, than you need to charge it or you need to replace your battery.
Rating the solution is highly appricaited...Good Luck.
Mar 03, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
Can?t get the back cover off rti T2+ remote control. Need to reattached power plug to circuit board. All screws have been removed seems board snaps in. Any suggestions?
If your talking about the battery cover then you just need to apply pressure to the battery cover near the seam and pull down with your other hand near the bottom of the remote near the battery terminals. If the battery inside has puffed up then the battery cover may be under stress and very hard to remove.
Dec 18, 2009 | Rti Technologies Rti T1 Remote Control
Where is battery
you need to remove 4 covers to replace the battery:
1. Cover over the windshield washer reservoir
2. Cover that says BATTERY on it
3. Cover that holds the battery cover
4. Cover over the bottom edge of the windshield on passenger side
Then you can access the battery easily! Hope this helps. let me know.
Dec 14, 2009 | 2006 Infiniti M35
My 1999 Dodge Intrepid Battery Story
It's called a Battery Mount (base that the battery mounts onto) and a Battery Cover (cover that goes over battery). Prices vary depending on the car, but I believe $40+ for each part.
You should also check to see if there's an issue with your alternator the way you're going through batteries. It should read 13-14V +-.2V across the terminals with the car running and the alternator cranking.. If it's below 13, then it's undercharging your battery. If it's above 14V, then it's overcharging and damaging your battery
Aug 19, 2009 | 1999 Dodge Intrepid
IPaq switches off
You need to examine your battery cover as one of the c hooks in your cover may be bent or broken. Basically, the hooks on the cover actually press a micro-switch that detects if the battery cover is on.
If your battery cover looks fine, then you may have a software problem. Try getting a firmware upgrade or simply doing a hard reset to see if the problem is still present
Nov 20, 2007 | HP iPAQ hw6500 Pocket PC
Battery cover
Sony has bought-out Minolta. Parts for Minolta equipment has become scarce, but try here: http://eservice.sony.com/webrma/web/index.do
Nov 27, 2006 | Konica Minolta DiMAGE Z1 Digital Camera
Bushnell Tour V2 Pinseeker Laser Rangefinder Logo
347 people viewed this question
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Greg Cann
Greg Cann
Mark Campeau
Level 1 Expert
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
