Question about Kenmore Heating & Cooling
Washer elite he 5t. The power light isbthe only
Only the power light is on no other buttons are working. I cut power to reset and the same issue. No other buttons will work I have also tried to cancel several times no difference.
  • suelto Oct 03, 2009
    Not helpful. I figured it out. I thought my dryer and washer were on the same circuit breaker. Washer breaker was not listed so I cut all power to my house waited 3min. Cut power back on problem solved.
  • 101 Answers
Contact Manufacturer Online or Phone# on Appliance.
Posted on Oct 02, 2009
Control Locked light on
Hi
Thanks for using FixYa. To unlock the controls you’ll need to press and hold the DRAIN/SPIN button for 10-15 seconds. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 11, 2010 | Kenmore Elite 45986 Front Load Washer
I have a Kenmore Elite HE 5t washer. The power
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 11, 2010 | Kenmore Elite HE5t Washer
Kenmore elite he 5t the code f21 comes on, the hose is ok.
This is a Long Drain Issue. Likely that something is stuck in the pump trap. Take off the mottom tree screws under the drum panel. This will remove the drum panel on the front. From under neither you can see the drain pipe trap. Unscrew the trap cap in the from. Clean out all debris and re-install. this should do it.
Feb 15, 2010 | Kenmore Elite HE5t Washer
My Elite Kenmore HE 5t Steam on Bulky setting will not run shows F99 error code what does the code mean?
The F99 error indicates the interface and central control are not compatible.
It means you selected a cycle on the interface that the central control does not recognize.
Usually this means the two controls are not compatible which might happen if an older control was installed in a new machine.
If the washer is brand new then I suggest scheduling a warrantee service call.
The only thing I could suggest you try yourself is to enter and run a service test.
The instructions to do so are in the image below.
(Be sure to press the button for a full 4 seconds.)
Perhaps this will reset and coordinate the interface and control.
http://media.fotki.com/1_p,sskrstwsgdkssbtxgtqsskgwtqkq,vi/rqfqbsgwdxsbftrkdks/1/1303472/5961857/image7062766216422141446img-or.jpg
Jan 25, 2010 | Kenmore Elite 45986 Front Load Washer
My kenmore elite He 5t wash machine is flashing F
This typically indicates slow drain condition. Check for any clogs or kinks in the drain line. Also check that the pump is not clogged and that no pump impeller blades are missing/broken and that the impeller moves freely. Any broken/missing blades or if the impeller won't turn freely will indicate a faulty pump. Hard objects can sometimes make it to the pump and cause damage. Hope this helped and best wishes.
Sep 09, 2009 | Kenmore Elite HE5t Washer
Dying clothes
Dying usually needs the cloth to be submersed in the liquid so it can absorb the dye. These machines do not fill with water to the point the clothing would be submersed and would not work well in my opinion. eric
Jul 02, 2009 | Kenmore Elite 45986 Front Load Washer
KENMORE Elite HE 3T
no but there is a control bd it is probably gone
Jul 30, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite he (5t)
You can wash Shoes in it... But the manufacturer does not recomened it.. I would suggest that you remove the laces and you should be just fine
good luck
May 27, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE 5t
Low or no water supply, hot or cold side or water pressure switch not switching over to indicate fully filled though if this happens drain motor will continue to run continuously while f-20 flashes
Jan 15, 2008 | Kenmore Elite 45986 Front Load Washer
Heating & Cooling Logo
27 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
John Tripp
John Tripp
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
