IT Technician canon 1060p fax machine - when incoming faxes after to stand there and hit button after each page to make it continue.
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
I have lost my user manual for my canon laserclass 1060p G3 fax machine and I am unable to find one on canons website or online. Would you happen to know where I can find it?
I hope this is the one your are looking for. Click HERE. It's a pdf file, and the document should open up in your browser or you'll be prompted to download/save. Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Mar 14, 2011 | Canon LaserClass 2060 Fax
How do you stop an incoming fax?
hit the stop button or unplug the phone line, power off etc.
Feb 24, 2011 | Canon Office Equipment & Supplies
How to recieve a fax on the Canon PIXMA MX340 Wireless Office All-in-One Printer
Take your incoming phone line and plug it into the place that says "line" on your fax machine. Plug another phone cord into where it says "phone" and connect this to your telephone. Test to make sure you have chosen the right places by dialing a phone number to fax to and listen for the dial tone. If you get a dial tone, then you have set it up correctly.
On the fax machine look for the button that says "menu". Push it and use the up and down arrows to navigate the options on the display. Look for fax set up and press "ok" or "enter" on the fax machines keyboard to access this area. Look for "number of rings" and change the fax machine to a number of rings that is less then your voice mail box if you have one. Then close and save your choices.
Have someone send a test fax by dialing your phone number for the line connected to the machine. The fax machine will pick up on the number of rings set and automatically begin receiving and printing a copy of your incoming fax.
You cannot use magic jack.
You can also choose to manually answer an incoming fax if you see that your display on the fax machine says "ringing" or incoming" you can push the "start" button and this will start receiving your incoming fax.
Sep 30, 2010 | Canon imageCLASS MF7480 Laser Printer
On my Canon MX310, the display says "Waiting for Report". Fax Memory is clear, but the In Use/Memory light stays on.
Try this step ... found it on Canon's website
Solution: Set [AUTO PRINT RX] to ON (MX300 / MX310)
AUTO PRINT RX When [AUTO PRINT RX] is set to [OFF], incoming received faxes will be temporarily stored to memory and transaction reports (TX, RX and Activity) remain in memory. The default setting is [ON], which means incoming received faxes and transaction reports will automatically print. The fax machine will not automatically print a received fax and will store it in memory in the following conditions.
  • Ink is low or has run out
  • The paper size and type is not set correctly
  • Paper has run out
  • The Output Tray is closed
To set AUTO PRINT to ON, please follow these steps.
  1. Press the <FAX> button to enter the Fax menu.
  2. Press the <Menu> button. [FAX SETTINGS] is displayed
  3. Press the left or right arrow button to select [RX SETTINGS] , then press <OK> two times.
  4. Press the left arrow to select [ON], then press <OK>.
    Note: When AUTO PRINT RX is set ON, a sub-menu will appear to PRINT WHEN NO INK.
  5. At sub-menu PRINT WHEN NO INK, decide if you'd like the machine to continue to print incoming received faxes if ink is low.
    CAUTION: When this option is set ON, the fax machine will not monitor the ink level of the ink cartridges. If ink is low or out, received faxes will print with streaks or blank. Furthermore, once the fax is printed, it will be deleted from memory.
    1. To print received faxes when ink is low or out, press the left or right arrow to select [ON] and then press <OK>.
    2. To store received faxes in memory when ink is low or out, press the left or right arrow to select [OFF] and then press <OK>.
  6. Press the <Stop/Reset> repeatedly to return to Fax standby mode.
Nov 17, 2009 | Canon PIXMA MX310 All-In-One Printer
Our canon laser fax 1060p receives faxes fine but send out a total black page (also the copy function is a total black page)
No power/failed contact image sensor. If under contract get replaced. It is poss. that a "standard white setting adj." could fix it, but doubtful with a black copy. -Carl
Jul 17, 2009 | Canon L220 Plain Paper Laser Fax
Cannot receive auto faxes
This is a known problem with the MX850 - Canon thinks it works, but it needs to be FAX Only when you're out of the office and TEL PRIORITY when you're in the office - then you hit "Hook" when you hear an incoming call as a fax tone. It's a manual answer machine when in TELEPHONE Priority
Mar 18, 2009 | Canon PIXMA MX850 Multifunction Printer
I just changed the cartridge in the canon laser class 1060P and now all the faxes are coming out black. It looks like I took the toner and spread it out on the page. The manual does not help me fix this...
Ok just cause you put in a NEW CARTRIDGE DOESN'T mean it was a good one, if your getting black pages this tells me that tour toner is getting no charge, this tells me that your charge roller isn't charging, either your cartidge is no good, yup= this could be defective or your charging unit on your printer become defective- replace ctg first, if it doesn't correct it then CALL FOR SERVICE, r u in Ct if so we can help you !!!!!
Mar 06, 2009 | Canon LaserClass 2060P Plain Paper Fax
L170 Canon Fax Sound and volume control issues
Sunds as though you have the handset that came with the machine attached to it and the handset ring volume is still on. To turn that off there are 2 black inset switches on the handset itself turn those down or off.
Apr 09, 2008 | Canon FAXPHONE L170 Plain Paper Laser
Canon 710 fax machine
Reset the machine to print reports. If it continues not to try reseting the circuits from the panel.
Mar 12, 2008 | Canon LaserCLASS Fax 710 Printer
180 people viewed this question
