Question about Farmall Toys
Have plow on farmall super A . Plow wont dig in it just slides on top of ground
  • 546 Answers
The angle of the 'mould board' or cutting edge of the plow,and the 'down pressure' or weight applied determine the 'cut'.adjust top of plow towards direction of travel to increase cut.dry,compacted soil can be very resistant.
Posted on Oct 02, 2009
I can hear my fisher plow motor but the plow will not lift or angle
There solinoids on pump. Check wiring and grounds. Make sure all small wires are intact and in good condition. But most likely there's a loose corroded or green wire causing issue
Jan 09, 2015 | Cars & Trucks
I have a 2003 f-250 with a curtis sno-pro 3000 hitch n run plow system. when i go to lift plow or go left or right it kills the truck. the light shut off and every thing else as soon as i hit any of the...
I think you have a problem with the plow motor grounding out. when you raise or turn plow in either direction you have to run the plow motor which is grounded out. ( as in hooking the ground and positive together directly ) the plow is on a gravity drop when you let it down by the weight itself and does not require the motor for the plow to operate. It's your plow motor or the positive feed to selonoids.
Feb 05, 2011 | 2003 Ford F250 Super Duty Crew Cab
My fisher plow wont move
Sounds like pump is not working, check all fuild lines. Unless the plow is all electric, then the ground
Feb 26, 2010 | 1998 Chevrolet C1500
My snow plow keeps lowering to the ground after i
You have a hydraulic valve leaking in the pump.
Jan 28, 2010 | 1991 Chevrolet S-10 Blazer
Ford 2003, F250 Desel, 7.3 Liter Head lights
first thing i would check is the wiring were the plow wiring is spliced in at this is most likly the culprate. or you may have a bad multi function switch in the steering column
Jan 02, 2010 | 2003 Ford F250 Super Duty Crew Cab
Lights on a fisher xtreme plow wont work
I'm guessing that you have already checked to make sure there is power going to the plow lights. If not use a test light and make sure. The most likely problem is the grounds from the plow lights themselves to the frame. Take the lights apart and check and/or replace the grounds, wires inside the case take a lot of vibration and that can cause them to fail.Don't forget to check the bulbs to be sure they're good too. Hope this helps.
Dec 17, 2009 | 2007 GMC Sierra 2500HD
Hi, I have a 2000 dodge ram and when i plug my fisher plow up only one light works on the plow and one on the truck .when the plow is un hooked from the truck all the truck lighs work,and when i hook up...
There is a ground that is deteriorated in the harness. trace the ground lead back from the connection to your truck. Once you find the break, that should take care of your problem.
It is also possible to be a power lead, so check them also, but more often than not it is a ground.l
Hope this helps.
Dec 14, 2009 | 2001 Dodge Ram 2500 Truck
Fisher plow that wont go up and sometime won't turn either way
did you try cleaning the solenoids for the plow? i think this would solve your problem
Mar 09, 2009 | 1996 Dodge Ram 1500 Club Cab
Toys Logo
441 people viewed this question
Top Farmall Toys Experts
Phil Walker
Phil Walker
Bud H
Adam Plug
Adam Plug
Are you a Farmall Toy Expert? Answer questions, earn points and help others
