Want start when thermostat is turn up. The purge
I have a goodman heater model number GMS91155DXA Want start when thermostat is turn up. The purge motor does not start. I get three blinking lights. The board is not sending current to the purge motor to start. I can connect from the transformer to the purge motor and it work. Is the problem the main board
  • 80 Answers
Check to see if there is a Bad relay on the board that sends power to the purge motor.
Posted on Oct 02, 2009
Goodman Furnace gms91155dxa not staying on. The system ignites, but shuts off after 3 minutes. 1 blink LED system light
100% sounds like an electrical problem, something is not allowing it to go into a duty cycle.
Dec 04, 2016 | Goodman Heating & Cooling
Goodman furnace GMP075-3 The thermostat was in the off position over night and sometime during the night, the induced blower and blower motor came on. The trouble light on board blinks 5 times. I checked...
Need your model # to check the codes but, this coming back on after turning the t-stat off is rare. You may have been in a lockout and the furnace re-started. Some furnaces try to start three times , then lock out. Time out, then re-start. The codes should be on your furnace blower door. Write back with this info and i could help.
Oct 12, 2011 | Goodman GMS90703BXA Heater
My furnace tries three times then red light blinks once
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Your furnace has a diagnostic chart on the reverse of the lower panel incorporated in the wiring diagram. One blink tells you that it is a failure but wont tell you where to start looking.
Nov 27, 2009 | Goodman GMS90703BXA Heater
When I turn my furnace on, the purge blower starts as normal, then after 15 seconds the ignitor starts to glow but when the gas valve should turn on it only turns on for a split second and then you can...
Nov 19, 2009 | Goodman GMS90703BXA Heater
It will only cycle once and then it shuts off.. i have to turn off and then back on through the thermostat to get it it through another cycle , the system is three years old. i have tried two other...
Your furnace has a diagnostic light in the unit. Look for a small see-thru window either on the top panel or the bottom panel. Look for a blinking light. Record the number of blinks. Now remove the bottom panel and look at the wiring diagram. There will be a error code list explaining what the blinks represent. If you open the panel prior to looking thru the window, you will erase the code. Changing the thermostat is not the solution. Good Luck.
Sep 07, 2009 | Goodman GMS90703BXA Heater
Just bought a home with a Honewell trol atemp universal mini zone
because it dosent have a duct sensor - should not be a problem
Sep 03, 2009 | Honeywell Electronic Programmable...
Three blinks - what does it mean
The safety limit inside the blower section has tripped.
Oct 31, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
107 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
